- Hardware: Jetson AGX Orin
- Deesptream7.0
- Jetpack 6.0 (6.0+b106 and 6.0+b87 both are installed) L4T 36.3.0
- TensorRT 8.6.2
- NVRM version: NVIDIA UNIX Open Kernel Module for aarch64 540.3.0
- Issue : i am trying to use a person attribute recognition model as sgie on a video after using a person detector as primary detector and i am using custom parser for using buffer of the secondary model but i am getting a segmentation fault and i am not able to understand its cause and how can i then resolve it.
- the secondary model that i am using is in pth form and i converted it to onnx using a separate python script.
- below drive contains all the files that i am using for my deepstream-app -c command and the secondary model as the primary one is YOLOv8s for person detection: PAR_forum - Google Drive
- Also currently the custom parser for secondary is just a print statement and yet i am getting the segmentation fault as you can see below:
You can try to use gdb
tool to do a preliminary analysis of where the crash was.
$gdb deepstream-app
$r -c <your_config_file>
after the crash
$bt
