./video_decode H264 --input-nalu --disable-rendering nosps.264
Set governor to performance before enabling profiler
run cnt 0
Failed to query video capabilities: Inappropriate ioctl for device
NvMMLiteOpen : Block : BlockType = 261
TVMR: NvMMLiteTVMRDecBlockOpen: 7647: NvMMLiteBlockOpen
NvMMLiteBlockCreate : Block : BlockType = 261
Starting decoder capture loop thread
Could not read nal unit from file. EOF or file corrupted
Input file read complete
TVMR: NvMMLiteTVMRDecDoWork: 6531: NVMMLITE_TVMR: EOS detected
TVMR: TVMRBufferProcessing: 5486: Processing of EOS
TVMR: TVMRBufferProcessing: 5563: Processing of EOS Done
The “nosps.264” file was manually generated, just wanted to reproduce this issue. In practice, we can not check whether there are errors in the bitstream in the application.
We debug it by gdb and find that is a bug in “libnvmm_utils.so”. Could you fix it?
Thread 10 “video_decode” received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0x7fac8901d0 (LWP 17272)]
0x0000007fb3c2eb28 in NvMMQueueGetNumEntries () from /usr/lib/aarch64-linux-gnu/tegra/libnvmm_utils.so
(gdb) bt #0 0x0000007fb3c2eb28 in NvMMQueueGetNumEntries () from /usr/lib/aarch64-linux-gnu/tegra/libnvmm_utils.so #1 0x0000007fb3c9c5dc in ?? () from /usr/lib/aarch64-linux-gnu/tegra/libtegrav4l2.so #2 0x0000007fb7651628 in ?? () from /usr/lib/aarch64-linux-gnu/tegra/libnvos.so #3 0x0000007fb7f8a088 in start_thread (arg=0x7fffffe55f) at pthread_create.c:463 #4 0x0000007fb7ae54ec in thread_start () at …/sysdeps/unix/sysv/linux/aarch64/clone.S:78
