Segmentation fault with PACK function since pgi/12.X
Hello ( ;-)Again me )
Segmentation fault with basic use of PACK function since pgi/12.X
Sample “test_pack” compile with pgi/11.10 ( or ifort or gfortran) OK
test_pack
IINDEX= 1 2 3
IJINDEX= 1 2 3
Now compiled with pgi/12.5 or over
test_pack
Segmentation fault
Here is the compilation line
pgf90 -g test_pack.f90 -o test_pack
And the test_pack source :
PROGRAM TEST_PACK
  IMPLICIT NONE
  INTEGER, PARAMETER                  :: NI=3
  INTEGER, ALLOCATABLE, DIMENSION(:)  :: IINDEX,IJINDEX
  LOGICAL, ALLOCATABLE, DIMENSION(:)  :: GTRIG
  INTEGER                             :: I
  ALLOCATE (IINDEX(NI),IJINDEX(NI),GTRIG(NI))
  DO I=1,NI
    IINDEX(I) = I
    GTRIG(I)  = .TRUE.
  END DO
  IJINDEX(:) = PACK( IINDEX(:), MASK=GTRIG(:) )
  print*,"  IINDEX=",IINDEX(:)
  print*," IJINDEX=",IJINDEX(:)
END PROGRAM TEST_PACK
A+
Juan
Thanks Jaun,
I submitted TPR#18937 for this error. Interestingly the error does not occur in our internal development compiler. I don’t see other similar reports but our engineers might have already found this error or it was fixed as a side effect of another issue. This means that we should be able to get the fix into the next release.
  • Mat
Hello Mat .
In the original code I don’t alway have the seg fault …
… but must of the time the resulting array IJINDEX is completely wrong …
… and the original array IINDEX is arise with wrong value …
even if it only an input tab ?
A+
Juan
Can you send PGI Customer Support (trs@pgroup.com) the full source? I’d rather us have the full source just in case there are multiple issues here.
  • Mat
Hello Mat …
The original code is 1 million fortran lines , more than 4000 fortran files …
makefiles + 10 tests case ( and need a license agreement … )
but I could put it in a tarball some where …
A+
Juan
Hi Juan,
The size doesn’t bother me, I just can’t get lawyers involved. If the license is just a click-through agreement that I wont do anything other use it internally for investigating this issue, then sure. But if I have to sign something or get and NDA, it’s best if I just work with the simple example.
  • Mat
Hello Mat .
Waiting for a bugfix on the PACK problem which impact a lot of routines/lines in my code …
egrep “= *PACK *(” *.f90 | wc -l
109
… as I’ve seen in an other post it was an optimization made on the pgi/12.5
… perhaps do you have an ‘obscure’ option to inhibit this optimization …
A+
Juan
PS: The code is under License agreement for Research purpose ( not easy/planned to distribute for debugging purpose … )
Hi Juan,
The fix for the PACK problem, TPR#18937, is scheduled for release 12.10 due out on or around October 12th.
Your issue began failing in the 12.1 release and is unrelated to this new optimization.
  • Mat
Ok , thank you Mat .
I will wait for the next release .
A+
Juan
This has been fixed as of 12.10 release.
thanks,
dave
