I am not sure where to start with debugging this problem. I have a fortran code that is using a structure such as below.
When I then declare an array of structure variables that has 3000 elements, I get segmentation fauls. If I limit the size to 2000, the program runs fine. The overall memory requirement of this code is not very large (a few MB) and there is plenty memory on the machine (5 GB).
Am I doing something obviously wrong?
Thanks, Jan
TYPE :: objstruc
SEQUENCE
REAL(KIND=RP),DIMENSION(44) :: par
REAL(KIND=RP),DIMENSION(NLMX) :: z
REAL(KIND=RP),DIMENSION(3) :: g
REAL(KIND=RP),DIMENSION(3) :: gp
REAL(KIND=RP),DIMENSION(3,3) :: Chat,Chati
REAL(KIND=RP) :: detChat
INTEGER(KIND=IB) :: k
INTEGER(KIND=IB) :: NFP
REAL(KIND=RP) :: logL
REAL(KIND=RP) :: logPr
REAL(KIND=RP) :: lognorm
END TYPE objstruc
TYPE(objstruc),DIMENSION(3000) :: particles
