I’m porting some code that used to work on TX2 (Jetpack 3.3).
I am now compiling and running it on Xavier (Jetpack 4.2 rev1).
We attached a USB camera and run the following pipeline:
gst-launch-1.0 v4l2src device=/dev/video0 \
! 'video/x-raw,width=1280,height=720,framerate=(fraction)5/1' \
! nvvidconv ! 'video/x-raw(memory:NVMM), format=(string)I420' \
! nvvidconv output-buffers=16 ! 'video/x-raw(memory:NVMM), format=(string)I420' \
! my-plugin \ # This is the one!
! nvjpegenc \
! multifilesink location="snapshot-%05d.jpg" max-files=10
So my-plugin accepts I420 buffers in (memory:NVMM).
In all plugins that try to access the pixel information, I usually do the following steps:
GstMapInfo in_map_info;
if (gst_buffer_map(buf, &in_map_info, (GstMapFlags)GST_MAP_READWRITE) == FALSE) {
std::cout << "Failed to map gstbuffer data for read_write" << std::endl;
std::exit(1);
int in_dmabuf_fd = -1;
if (ExtractFdFromNvBuffer(in_map_info.data, &in_dmabuf_fd) != 0) {
std::cout << "Failed to map hardware buffer on gstbuffer data" << std::endl;
std::exit(1);
NvBufferParams param;
if (NvBufferGetParams(in_dmabuf_fd, ¶m) != 0) {
std::cout << "Failed to get buffer params\n";
std::exit(1);
* Do fun stuff with the pixels
if (NvReleaseFd(in_dmabuf_fd) != 0) {
std::cout << "Failed to release Fd=" << in_dmabuf_fd << '\n';
std::exit(1);
gst_buffer_unmap(buf, &in_map_info);
This piece of code inside the chain chain function of my custom plugin causes a segmentation fault. Turns out the culprit is the call to NvReleaseFd. It actually crashed when calling this function. The checking of the return value does not even happen anymore.
Commenting it out appears to be fine but can someone from NVIDIA comment on this behavior?
Note that the “NvReleaseFd” is also used in gstdsexample.cpp
To me it makes sense that ExtractFdFromNvBuffer would acquire a non-owning reference to some buffer so Release should not be called on it, but is this reflected somewhere in the documentation and why does it not crash on the pipelines we have been running for months on the older TX2 with the older Jetpack version?
