Hello.
I’m trying semantic segmentation with tlt v3 on custom dataset.
I use a resnet18 backbone, however when launching training i got the following error :
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/unet/scripts/train.py", line 403, in <module>
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/unet/scripts/train.py", line 397, in main
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/unet/scripts/train.py", line 298, in run_experiment
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/unet/scripts/train.py", line 133, in train_unet
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/unet/model/build_unet_model.py", line 75, in build_model
AssertionError: Freeze blocks is only possible if a pretrained model file is provided.
I launch training as follows :
tlt unet train --gpus=2 \
-e /workspace/tlt-experiments/specs/resnet18.txt \
-r /output/runs/resnet18_run1 \
-m /output/pretrained_resnet18/tlt_semantic_segmentation_vresnet18/resnet_18.hdf5 \
-n resnet18_lip \
-k $KEY
here is my spec file if it can help, I put a freeze_blocks field but I also provided a pretrained model path via the training command above, so I don’t understand why it is saying freezing is only possible for pretrained model provided :
random_seed: 42
model_config {
model_input_width: 224
model_input_height: 224
model_input_channels: 3
num_layers: 18
all_projections: true
arch: "resnet"
use_batch_norm: true
freeze_blocks: 0
freeze_blocks: 1
training_precision {
backend_floatx: FLOAT32
training_config {
batch_size: 64
epochs: 1
log_summary_steps: 10
checkpoint_interval: 1
loss: "cross_entropy"
learning_rate:0.0001
regularizer {
type: L2
weight: 3.00000002618e-09
optimizer {
adam {
epsilon: 9.99999993923e-09
beta1: 0.899999976158
beta2: 0.999000012875
dataset_config {
dataset: "custom"
augment: False
input_image_type: "color"
train_images_path: "/data1/TrainVal_images/TrainVal_images/train_images/"
train_masks_path: "/data1/TrainVal_parsing_annotations/TrainVal_simplified_annotations/train_segmentations/"
val_images_path: "/data1/TrainVal_images/TrainVal_images/val_images/"
val_masks_path: "/data1/TrainVal_parsing_annotations/TrainVal_simplified_annotations/val_segmentations/"
test_images_path: "/data1/Testing_images/testing_images/"
data_class_config {
target_classes {
label_id: 0
mapping_class: 'Background'
target_classes {
label_id: 1
mapping_class: 'Hat'
target_classes {
label_id: 2
mapping_class: 'Hair'
target_classes {
label_id: 3
mapping_class: 'Glove'
target_classes {
label_id: 4
mapping_class: 'Sunglasses'
target_classes {
label_id: 5
mapping_class: 'UpperClothes'
target_classes {
label_id: 6
mapping_class: 'Dress'
target_classes {
label_id: 7
mapping_class: 'Coat'
target_classes {
label_id: 8
mapping_class: 'Socks'
target_classes {
label_id: 9
mapping_class: 'Pants'
target_classes {
label_id: 10
mapping_class: 'Jumpsuits'
target_classes {
label_id: 11
mapping_class: 'Scarf'
target_classes {
label_id: 12
mapping_class: 'Skirt'
target_classes {
label_id: 13
mapping_class: 'Face'
target_classes {
label_id: 14
mapping_class: 'Left-arm'
target_classes {
label_id: 15
mapping_class: 'Right-arm'
target_classes {
label_id: 16
mapping_class: 'Left-leg'
target_classes {
label_id: 17
mapping_class: 'Right-leg'
target_classes {
label_id: 18
mapping_class: 'Left-shoe'
target_classes {
label_id: 19
mapping_class: 'Right-shoe'
