SEGV during cudaMemcpyToSymbol()
const __constant__ SomeType some_instance = {0};
…successfully compiles, but fails at runtime on the emu target. Backtrace:
#0  0x0000003331c7b391 in memcpy () from /lib64/libc.so.6
#1  0x00002aaaaaae3e88 in cudaMemcpyToSymbol () from /usr/local/cuda/lib/libcudart.so
#2  0x000000000040c5df in cudaMemcpyToSymbol<SomeType> (symbol=@0x61d960, src=0x7fffeef0a100, count=136, offset=0,
    kind=cudaMemcpyHostToDevice) at /usr/local/cuda/bin/../include/cuda_runtime.h:148
Relevant portion of symbol table:
$ objdump -t emu/blah |grep some_instance
000000000040f140 l     O .rodata        0000000000000088              some_instance
000000000061d960 l     O .bss   0000000000000088              __shadow_some_instance
So the SEGV is because I shouldn’t be writing to a read-only page, right? Ok, I can live w/that. But if I do this:
__constant__ SomeType some_instance_non_const = {0};
…then I get this compiler error:
./foo.cu:145:1: error: pasting "{" and "__constant__" does not give a valid preprocessing token
Also,
const __constant__ SomeType no_init;
…fails to compile, with:
error: const variable "no_init"
          requires an initializer -- class "SomeType" has no explicitly
          declared default constructor
  const __attribute__((__constant__)) SomeType no_init;
SomeType is declared like:
typedef struct
    int some_member;
    float some_other_member;
} SomeType;
I’m using “–host-compilation=c++”, btw.
I have also tried declaring SomeType as:
struct SomeType
    int some_member;
Unfortunately, I fear that my case is more complex than I present here, since I’m unable to reproduce it with a simpler example. Can anyone suggest any hints on where to look next?
Which of the above examples is more appropriate for declaring constant GPU memory?
