Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”):
Software Version
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.5.0.7774
other
Host Machine Version
native Ubuntu 18.04
other
Hello, I would like to get images from my Sekonix 3324 camera at rates lower than 30Hz. (E.g. 10 or 20 Hz). I get my images like so :
status_ = dwSensorCamera_readFrameNew(&cameraFrameHandle_, 0, sensorHandle_);
if (status_ == DW_NOT_READY)
std::this_thread::sleep_for(std::chrono::milliseconds(5));
return false;
if (status_ == DW_TIME_OUT)
ROS_WARN_STREAM("DROPPED FRAME FOR : " << frame_.str());
return false;
if (status_ != DW_SUCCESS)
ROS_FATAL_STREAM("FAILED TO READ FRAME FOR : " << frame_.str());
CHECK_DW_ERROR_ROS(status_);
return false;
// Get image from cameraFrameHandle
status_ = dwSensorCamera_getImage(&imageHandleOriginal_, DW_CAMERA_OUTPUT_NATIVE_PROCESSED, cameraFrameHandle_);
ROS_FATAL_STREAM("dwSensorCamera_getImage() Failed");
return false;
But I get those errors when I run the above code at 20 Hz :
NOTIF_WARN_ICP_FRAME_DROP
Which doesn’t seem normal. I shouldn’t get those errors.
Another thing. The function dwSensorCamera_readFrameNew
will get a frame from the camera frame buffer. (Please correct me if I’m wrong.)
When polling at less than 30Hz this buffer will contain a list of images and dwSensorCamera_readFrameNew
will get the oldest from this buffer. So dwSensorCamera_readFrameNew
will always read old frame when the polling rate is below 30 hz. (Please correct me if I’m wrong.)
How do you solve this problem ? Right now I call dwSensorCamera_readFrameNew
until I get DW_TIME_OUT
so I know I got the last frame.
What’s the good practice ?
Thanks !
