I want to compile a Fortran code including “select case” with many branches, e.g.
module TEST
contains
subroutine LIB__Set( id )
implicit none
integer, intent(in) :: id
select case (id)
case (1)
case (2)
case (3)
case (9998)
case (9999)
case (10000)
case default
stop
end select
end subroutine LIB__Set
end module TEST
Compiling the above code, I met an error message:
pgfortran-Fatal-f901 completed with exit code 128
Are there any pgfortran options to compile such a code with many branches?
Regards,
Tetsuo
