Select what PhysX Visual Debugger (PVD) logs
I am using the isaacgym gpu pipeline. I set the environment variable “GYM_PVD_FILE” to a filepath to enable logging.
The issue is that the output file grows within 5 minutes to 20GB+.
I was wondering if it is possible to select what to log (like: Debug/Profile/Memory) without the visual interface, as I am using linux?
Thanks for your help!
