We made our own baseboard and inserted NVIDIA Agx Xavier board.
However, when starting up, the serial port will print the following information and keep printing this paragraph repeatedly.
Does anyone know why?
[0000.025] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0000.034] I> MB1 (prd-version: 1.5.1.7-t194-41334769-98030a79)
[0000.039] I> Boot-mode: Coldboot
[0000.042] I> Chip revision : A02P
[0000.045] I> Bootrom patch version : 15 (correctly patched)
[0000.050] I> ATE fuse revision : 0x200
[0000.054] I> Ram repair fuse : 0x0
[0000.057] I> Ram Code : 0x1
[0000.059] I> rst_source : 0x0
[0000.062] I> rst_level : 0x0
[0000.065] I> Boot-device: QSPI
[0000.068] I> Qspi flash params source = brbct
[0000.072] I> Qspi using bpmp-dma
[0000.075] I> Qspi clock source : pllp
[0000.079] I> QSPI Flash Size = 64 MB
[0000.082] I> Qspi initialized successfully
[0000.086] W> No valid slot number is found in scratch register
[0000.092] W> Return default slot: _a
[0000.095] I> Active Boot chain : 0
[0000.098] I> Boot-device: QSPI
[0000.101] I> Qspi flash params source = brbct
[0000.107] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.114] I> Temperature = 23500
[0000.117] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.122] W> Skipping boost for clk: BPMP_APB
[0000.126] W> Skipping boost for clk: AXI_CBB
[0000.130] W> Skipping boost for clk: AON_CPU_NIC
[0000.134] W> Skipping boost for clk: CAN1
[0000.138] W> Skipping boost for clk: CAN2
