I am trying to run selinux on AGX in enforcing mode.
Jetson runs fine when the mode is permissive/disabled. However, once selinux is activated (i.e. changing mode to enforcing), on reboot the system is stuck. Boot is unsuccessful. The only way to get AGX running again is by re-installing Jetpack. This seems to be a common problem, but no good solution exists. Is there a solution to this?
Instructions for installing selinux:
sudo apt install policycoreutils selinux-utils selinux-basics
sudo selinux-activate
To change mode from permissive to enforcing, modify /etc/selinux/config following line:
SELINUX=permissive
TO:
SELINUX=enforcing
Thank you,
Tejas
