Semantic IDs not consistent over multiple datasets generated using BasicWriter
Hey there,
I just noticed, that the semantic Ids of my classes are not consistent if I restart the script or use a different script with the same classes. As I have a real dataset with the matched IDs from one of the runs, I would like to set all the IDs to that specific number each, so that I don’t have to relabel any of the datasets. So is there a possibility to set a specific ID for each semantic class (for example alphabetical order of the class names). Also is there a way to fuse the BACKGROUND default class with the UNLABLED default class from BasicWriter?
I use the Basic writer like this:
writer = rep.WriterRegistry.get("BasicWriter")
writer.initialize(
    output_dir=output_dir, rgb=True, semantic_segmentation=True, colorize_semantic_segmentation=False,
    semantic_types=['labels'])
writer.attach([render_product])
Thanks in advance.
There is not a way to do this with the current BasicWriter but you can write your own writer using existing Replicator API tools to do so with colorize_segmentation
from omni.replicator.core import Writer, BackendDispatch, WriterRegistry
class MyWriter(Writer):
    def __init__(self, output_dir: str):
        self._frame_id = 0
        self.backend = BackendDispatch({"paths": {"out_dir": output_dir}})
        self.annotators = ["rgb","semantic_segmentation"]
        # Dictionary mapping of label to RGBA color
        self.CUSTOM_LABELS = {
            "unlabelled": (0, 0, 0, 0),
            "sphere": (128, 64, 128, 255),
            "cube": (244, 35, 232, 255),
            "plane": (102, 102, 156, 255),
    def write(self, data):
        render_products = [k for k in data.keys() if k.startswith("rp_")]
        self._write_rgb(data, "rgb")
        self._write_segmentation(data, "semantic_segmentation")
        self._frame_id += 1
    def _write_rgb(self, data, annotator: str):
        # Save the rgb data under the correct path
        rgb_file_path = f"rgb_{self._frame_id}.png"
        self.backend.write_image(rgb_file_path, data[annotator])
    def _write_segmentation(self, data, annotator: str):
        seg_filepath = f"seg_{self._frame_id}.png"
        semantic_seg_data_colorized = rep.tools.colorize_segmentation(
            data[annotator]["data"], data[annotator]["info"]["idToLabels"], mapping=self.CUSTOM_LABELS
        self.backend.write_image(seg_filepath, semantic_seg_data_colorized)
    def on_final_frame(self):
        self.backend.sync_pending_paths()
# Register new writer
WriterRegistry.register(MyWriter)
# Create a new layer for our work to be performed in.
# This is a good habit to develop for later when working on existing Usd scenes
with rep.new_layer():
    light = rep.create.light(light_type='dome')
    # Create a simple camera with a position and a point to look at
    camera = rep.create.camera(position=(0, 500, 1000), look_at=(0, 0, 0))
    # Create some simple shapes to manipulate
    plane = rep.create.plane(semantics=[("class", "plane")], position=(0, -100, 0), scale=(100, 1, 100))
    torus = rep.create.torus(position=(200, 0, 100)) # Torus will be unlabeled
    sphere = rep.create.sphere(semantics=[("class", "sphere")], position=(0, 0, 100))
    cube = rep.create.cube(semantics=[("class", "cube")], position=(-200, 0, 100))
    # Randomize position and scale of each object on each frame
    with rep.trigger.on_frame(num_frames=10):
        # Creating a group so that our modify.pose operation works on all the shapes at once
        with rep.create.group([torus, sphere, cube]):
            rep.modify.pose(
                position=rep.distribution.uniform((-300, 0, -300), (300, 0, 300)),
                scale=rep.distribution.uniform(0.1, 2),
# Initialize render product and attach a writer
render_product = rep.create.render_product(camera, (1024, 1024))
writer = rep.WriterRegistry.get("MyWriter")
writer.initialize(output_dir="myWriter_output")
rep.orchestrator.run()    # Run the simulation
Our KITTI writer has an example of this as well
We do have on our roadmap a feature to make segmentation coloring more consistent across runs.
