Semantic Segmentation Crash
I am trying to add semantic segmentation, not sure about the base way to do this through the SIM or through the code - I figured I would start with the SIM and then try to do it in code. I clicked on Synthetic Data > Schema Editor and then Generate Labels > Apply without modifying anything and get this nasty crash. How can I understand it? It doesn’t happen all the time, more like 1/3 times.
Regards,
Dennis
Generating Labels!
2022-01-14 12:51:02 [2,000,312ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.events.plugin.so!carbOnPluginStartup
2022-01-14 12:51:02 [2,000,316ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.tasking.plugin.so!std::thread::_State_impl<std::thread::_Invoker<std::tuple<void (carb::tasking::Scheduler::*)(unsigned int, int, carb::cpp20::latch*), carb::tasking::Scheduler*, unsigned int, int, carb::cpp20::latch*> > >::_M_run()
2022-01-14 12:51:02 [2,000,320ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.usd.so!std::_Function_base::_Base_manager<omni::usd::OmniUsdMessenger::Impl::Impl(omni::usd::UsdContext*)::{lambda(carb::events::IEvent*)#1}>::_M_manager(std::_Any_data&, std::_Function_base::_Base_manager<omni::usd::OmniUsdMessenger::Impl::Impl(omni::usd::UsdContext*)::{lambda(carb::events::IEvent*)#1}> const&, std::_Manager_operation)
2022-01-14 12:51:02 [2,000,325ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpthread.so.0!funlockfile
2022-01-14 12:51:02 [2,000,329ms] [Fatal] [carb.crashreporter-breakpad.plugin] libstdc++.so.6!std::_Rb_tree_increment(std::_Rb_tree_node_base*)
2022-01-14 12:51:02 [2,000,331ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.isaac.dynamic_control.plugin.so!carbOnPluginShutdown
2022-01-14 12:51:02 [2,000,334ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.stageupdate.plugin.so!carbOnPluginShutdown
2022-01-14 12:51:02 [2,000,337ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.usd.so!std::deque<std::string, std::allocator<std::string> >::~deque()
2022-01-14 12:51:02 [2,000,341ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.usd.so!std::_Function_base::_Base_manager<omni::usd::LayerUtils::mergePrimSpec(pxrInternal_v0_20__pxrReserved__::TfRefPtr<pxrInternal_v0_20__pxrReserved__::SdfLayer>, pxrInternal_v0_20__pxrReserved__::TfRefPtr<pxrInternal_v0_20__pxrReserved__::SdfLayer> const&, std::string const&, bool)::{lambda(pxrInternal_v0_20__pxrReserved__::SdfPath const&)#3}>::_M_manager(std::_Any_data&, std::_Function_base::_Base_manager<omni::usd::LayerUtils::mergePrimSpec(pxrInternal_v0_20__pxrReserved__::TfRefPtr<pxrInternal_v0_20__pxrReserved__::SdfLayer>, pxrInternal_v0_20__pxrReserved__::TfRefPtr<pxrInternal_v0_20__pxrReserved__::SdfLayer> const&, std::string const&, bool)::{lambda(pxrInternal_v0_20__pxrReserved__::SdfPath const&)#3}> const&, std::_Manager_operation)
2022-01-14 12:51:02 [2,000,345ms] [Fatal] [carb.crashreporter-breakpad.plugin] libtf.so!pxrInternal_v0_20__pxrReserved__::Tf_NoticeRegistry::_Deliver(pxrInternal_v0_20__pxrReserved__::TfNotice const&, pxrInternal_v0_20__pxrReserved__::TfType const&, pxrInternal_v0_20__pxrReserved__::TfWeakBase const*, void const*, std::type_info const&, std::vector<pxrInternal_v0_20__pxrReserved__::TfWeakPtr<pxrInternal_v0_20__pxrReserved__::TfNotice::Probe>, std::allocator<pxrInternal_v0_20__pxrReserved__::TfWeakPtr<pxrInternal_v0_20__pxrReserved__::TfNotice::Probe> > > const&, std::pair<std::list<pxrInternal_v0_20__pxrReserved__::TfNotice::_DelivererBase*, std::allocator<pxrInternal_v0_20__pxrReserved__::TfNotice::_DelivererBase*> >*, std::_List_iterator<pxrInternal_v0_20__pxrReserved__::TfNotice::_DelivererBase*> > const&)
2022-01-14 12:51:02 [2,000,349ms] [Fatal] [carb.crashreporter-breakpad.plugin] libtf.so!pxrInternal_v0_20__pxrReserved__::Tf_NoticeRegistry::_Send(pxrInternal_v0_20__pxrReserved__::TfNotice const&, pxrInternal_v0_20__pxrReserved__::TfType const&, pxrInternal_v0_20__pxrReserved__::TfWeakBase const*, void const*, std::type_info const&)
2022-01-14 12:51:02 [2,000,354ms] [Fatal] [carb.crashreporter-breakpad.plugin] libtf.so!pxrInternal_v0_20__pxrReserved__::TfNotice::_Send(pxrInternal_v0_20__pxrReserved__::TfWeakBase const*, void const*, std::type_info const&) const
2022-01-14 12:51:02 [2,000,358ms] [Fatal] [carb.crashreporter-breakpad.plugin] libusd.so!pxrInternal_v0_20__pxrReserved__::UsdStage::_HandleLayersDidChange(pxrInternal_v0_20__pxrReserved__::SdfNotice::LayersDidChangeSentPerLayer const&)
2022-01-14 12:51:02 [2,000,362ms] [Fatal] [carb.crashreporter-breakpad.plugin] libusd.so!pxrInternal_v0_20__pxrReserved__::TfNotice::_StandardDeliverer<pxrInternal_v0_20__pxrReserved__::TfNotice::_Deliverer<pxrInternal_v0_20__pxrReserved__::TfWeakPtr<pxrInternal_v0_20__pxrReserved__::UsdStage>, pxrInternal_v0_20__pxrReserved__::TfWeakPtr<pxrInternal_v0_20__pxrReserved__::SdfLayer>, void (pxrInternal_v0_20__pxrReserved__::UsdStage::*)(pxrInternal_v0_20__pxrReserved__::SdfNotice::LayersDidChangeSentPerLayer const&), pxrInternal_v0_20__pxrReserved__::SdfNotice::LayersDidChangeSentPerLayer> >::_SendToListener(pxrInternal_v0_20__pxrReserved__::TfNotice const&, pxrInternal_v0_20__pxrReserved__::TfType const&, pxrInternal_v0_20__pxrReserved__::TfWeakBase const*, void const*, std::type_info const&, std::vector<pxrInternal_v0_20__pxrReserved__::TfWeakPtr<pxrInternal_v0_20__pxrReserved__::TfNotice::Probe>, std::allocator<pxrInternal_v0_20__pxrReserved__::TfWeakPtr<pxrInternal_v0_20__pxrReserved__::TfNotice::Probe> > > const&)
2022-01-14 12:51:02 [2,000,366ms] [Fatal] [carb.crashreporter-breakpad.plugin] libtf.so!pxrInternal_v0_20__pxrReserved__::Tf_NoticeRegistry::_Deliver(pxrInternal_v0_20__pxrReserved__::TfNotice const&, pxrInternal_v0_20__pxrReserved__::TfType const&, pxrInternal_v0_20__pxrReserved__::TfWeakBase const*, void const*, std::type_info const&, std::vector<pxrInternal_v0_20__pxrReserved__::TfWeakPtr<pxrInternal_v0_20__pxrReserved__::TfNotice::Probe>, std::allocator<pxrInternal_v0_20__pxrReserved__::TfWeakPtr<pxrInternal_v0_20__pxrReserved__::TfNotice::Probe> > > const&, std::pair<std::list<pxrInternal_v0_20__pxrReserved__::TfNotice::_DelivererBase*, std::allocator<pxrInternal_v0_20__pxrReserved__::TfNotice::_DelivererBase*> >*, std::_List_iterator<pxrInternal_v0_20__pxrReserved__::TfNotice::_DelivererBase*> > const&)
2022-01-14 12:51:02 [2,000,370ms] [Fatal] [carb.crashreporter-breakpad.plugin] libtf.so!pxrInternal_v0_20__pxrReserved__::Tf_NoticeRegistry::_Send(pxrInternal_v0_20__pxrReserved__::TfNotice const&, pxrInternal_v0_20__pxrReserved__::TfType const&, pxrInternal_v0_20__pxrReserved__::TfWeakBase const*, void const*, std::type_info const&)
2022-01-14 12:51:02 [2,000,374ms] [Fatal] [carb.crashreporter-breakpad.plugin] libtf.so!pxrInternal_v0_20__pxrReserved__::TfNotice::_Send(pxrInternal_v0_20__pxrReserved__::TfWeakBase const*, void const*, std::type_info const&) const
2022-01-14 12:51:02 [2,000,379ms] [Fatal] [carb.crashreporter-breakpad.plugin] libsdf.so!pxrInternal_v0_20__pxrReserved__::Sdf_ChangeManager::_SendNotices()
2022-01-14 12:51:02 [2,000,383ms] [Fatal] [carb.crashreporter-breakpad.plugin] libsdf.so!pxrInternal_v0_20__pxrReserved__::Sdf_ChangeManager::CloseChangeBlock()
2022-01-14 12:51:02 [2,000,387ms] [Fatal] [carb.crashreporter-breakpad.plugin] libsdf.so!void pxrInternal_v0_20__pxrReserved__::SdfLayer::_PrimSetField<pxrInternal_v0_20__pxrReserved__::VtValue>(pxrInternal_v0_20__pxrReserved__::SdfPath const&, pxrInternal_v0_20__pxrReserved__::TfToken const&, pxrInternal_v0_20__pxrReserved__::VtValue const&, pxrInternal_v0_20__pxrReserved__::VtValue const*, bool, bool)
2022-01-14 12:51:02 [2,000,391ms] [Fatal] [carb.crashreporter-breakpad.plugin] libsdf.so!pxrInternal_v0_20__pxrReserved__::SdfLayerStateDelegateBase::SetField(pxrInternal_v0_20__pxrReserved__::SdfPath const&, pxrInternal_v0_20__pxrReserved__::TfToken const&, pxrInternal_v0_20__pxrReserved__::VtValue const&, pxrInternal_v0_20__pxrReserved__::VtValue const*, bool)
2022-01-14 12:51:02 [2,000,395ms] [Fatal] [carb.crashreporter-breakpad.plugin] libsdf.so!void pxrInternal_v0_20__pxrReserved__::SdfLayer::_PrimSetField<pxrInternal_v0_20__pxrReserved__::VtValue>(pxrInternal_v0_20__pxrReserved__::SdfPath const&, pxrInternal_v0_20__pxrReserved__::TfToken const&, pxrInternal_v0_20__pxrReserved__::VtValue const&, pxrInternal_v0_20__pxrReserved__::VtValue const*, bool, bool)
2022-01-14 12:51:02 [2,000,400ms] [Fatal] [carb.crashreporter-breakpad.plugin] libsdf.so!pxrInternal_v0_20__pxrReserved__::SdfLayer::SetField(pxrInternal_v0_20__pxrReserved__::SdfPath const&, pxrInternal_v0_20__pxrReserved__::TfToken const&, pxrInternal_v0_20__pxrReserved__::VtValue const&)
2022-01-14 12:51:02 [2,000,404ms] [Fatal] [carb.crashreporter-breakpad.plugin] libsdf.so!pxrInternal_v0_20__pxrReserved__::SdfSpec::SetField(pxrInternal_v0_20__pxrReserved__::TfToken const&, pxrInternal_v0_20__pxrReserved__::VtValue const&)
2022-01-14 12:51:02 [2,000,408ms] [Fatal] [carb.crashreporter-breakpad.plugin] libsdf.so!pxrInternal_v0_20__pxrReserved__::SdfSpec::SetInfo(pxrInternal_v0_20__pxrReserved__::TfToken const&, pxrInternal_v0_20__pxrReserved__::VtValue const&)
2022-01-14 12:51:02 [2,000,412ms] [Fatal] [carb.crashreporter-breakpad.plugin] libusd.so!pxrInternal_v0_20__pxrReserved__::UsdPrim::AddAppliedSchema(pxrInternal_v0_20__pxrReserved__::TfToken const&) const
2022-01-14 12:51:02 [2,000,417ms] [Fatal] [carb.crashreporter-breakpad.plugin] libusd.so!pxrInternal_v0_20__pxrReserved__::UsdPrim::_ApplyAPI(pxrInternal_v0_20__pxrReserved__::TfType const&, pxrInternal_v0_20__pxrReserved__::TfToken const&) const
2022-01-14 12:51:02 [2,000,420ms] [Fatal] [carb.crashreporter-breakpad.plugin] libsemanticAPI.so!pxrInternal_v0_20__pxrReserved__::SemanticsSemanticsAPI::Apply(pxrInternal_v0_20__pxrReserved__::UsdPrim const&, pxrInternal_v0_20__pxrReserved__::TfToken const&)
2022-01-14 12:51:02 [2,000,424ms] [Fatal] [carb.crashreporter-breakpad.plugin] _semanticAPI.so!boost::python::objects::caller_py_function_impl<boost::python::detail::caller<pxrInternal_v0_20__pxrReserved__::SemanticsSemanticsAPI (*)(pxrInternal_v0_20__pxrReserved__::UsdPrim const&, pxrInternal_v0_20__pxrReserved__::TfToken const&), boost::python::default_call_policies, boost::mpl::vector3<pxrInternal_v0_20__pxrReserved__::SemanticsSemanticsAPI, pxrInternal_v0_20__pxrReserved__::UsdPrim const&, pxrInternal_v0_20__pxrReserved__::TfToken const&> > >::operator()(_object*, _object*)
2022-01-14 12:51:02 [2,000,428ms] [Fatal] [carb.crashreporter-breakpad.plugin] libboost_python37.so.1.68.0!boost::python::objects::function::call(_object*, _object*) const
2022-01-14 12:51:02 [2,000,432ms] [Fatal] [carb.crashreporter-breakpad.plugin] libboost_python37.so.1.68.0!boost::detail::function::void_function_ref_invoker0<boost::python::objects::(anonymous namespace)::bind_return, void>::invoke(boost::detail::function::function_buffer&)
2022-01-14 12:51:02 [2,000,437ms] [Fatal] [carb.crashreporter-breakpad.plugin] libboost_python37.so.1.68.0!boost::python::handle_exception_impl(boost::function0<void>)
2022-01-14 12:51:02 [2,000,441ms] [Fatal] [carb.crashreporter-breakpad.plugin] libboost_python37.so.1.68.0!function_call
2022-01-14 12:51:02 [2,000,445ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyObject_Call
2022-01-14 12:51:02 [2,000,449ms] [Fatal] [carb.crashreporter-breakpad.plugin] libtf.so!boost::python::objects::full_py_function_impl<boost::python::detail::raw_dispatcher<pxrInternal_v0_20__pxrReserved__::Tf_ModuleProcessor::_InvokeWithErrorHandling>, boost::mpl::vector1<_object*> >::operator()(_object*, _object*)
2022-01-14 12:51:02 [2,000,454ms] [Fatal] [carb.crashreporter-breakpad.plugin] libboost_python37.so.1.68.0!boost::python::objects::function::call(_object*, _object*) const
2022-01-14 12:51:02 [2,000,458ms] [Fatal] [carb.crashreporter-breakpad.plugin] libboost_python37.so.1.68.0!boost::detail::function::void_function_ref_invoker0<boost::python::objects::(anonymous namespace)::bind_return, void>::invoke(boost::detail::function::function_buffer&)
2022-01-14 12:51:02 [2,000,462ms] [Fatal] [carb.crashreporter-breakpad.plugin] libboost_python37.so.1.68.0!boost::python::handle_exception_impl(boost::function0<void>)
2022-01-14 12:51:02 [2,000,466ms] [Fatal] [carb.crashreporter-breakpad.plugin] libboost_python37.so.1.68.0!function_call
2022-01-14 12:51:02 [2,000,471ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyObject_FastCallKeywords
2022-01-14 12:51:02 [2,000,475ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2022-01-14 12:51:02 [2,000,480ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_init
2022-01-14 12:51:02 [2,000,484ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyEval_EvalFrameDefault
2022-01-14 12:51:02 [2,000,489ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_init
2022-01-14 12:51:02 [2,000,493ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyFunction_FastCallDict
2022-01-14 12:51:02 [2,000,498ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!_PyObject_Call_Prepend
2022-01-14 12:51:02 [2,000,502ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.7m.so.1.0!PyObject_Call
2022-01-14 12:51:02 [2,000,505ms] [Fatal] [carb.crashreporter-breakpad.plugin] _ui.cpython-37m-x86_64-linux-gnu.so!void omni::ui::StyleContainer::_initializeBlock<omni::ui::StyleColorProperty, char const*>(std::string const&, omni::ui::StyleColorProperty, char const*)
2022-01-14 12:51:02 [2,000,508ms] [Fatal] [carb.crashreporter-breakpad.plugin] _ui.cpython-37m-x86_64-linux-gnu.so!void omni::ui::StyleContainer::_initializeBlock<omni::ui::StyleColorProperty, char const*>(std::string const&, omni::ui::StyleColorProperty, char const*)
2022-01-14 12:51:02 [2,000,511ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ui.so!omni::ui::InvisibleButton::_drawContent(float)
2022-01-14 12:51:02 [2,000,514ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ui.so!omni::ui::Button::_drawContent(float)
2022-01-14 12:51:02 [2,000,517ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ui.so!omni::ui::Widget::draw(float)
2022-01-14 12:51:02 [2,000,520ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ui.so!omni::ui::Stack::_drawContent(float)
2022-01-14 12:51:02 [2,000,523ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ui.so!omni::ui::Widget::draw(float)
2022-01-14 12:51:02 [2,000,526ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ui.so!omni::ui::Frame::_drawContent(float)
2022-01-14 12:51:02 [2,000,529ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ui.so!omni::ui::Widget::draw(float)
2022-01-14 12:51:02 [2,000,532ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ui.so!omni::ui::Stack::_drawContent(float)
2022-01-14 12:51:02 [2,000,535ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ui.so!omni::ui::Widget::draw(float)
2022-01-14 12:51:02 [2,000,538ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ui.so!omni::ui::Stack::_drawContent(float)
2022-01-14 12:51:02 [2,000,541ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ui.so!omni::ui::Widget::draw(float)
2022-01-14 12:51:02 [2,000,544ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ui.so!omni::ui::Frame::_drawContent(float)
2022-01-14 12:51:02 [2,000,547ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ui.so!omni::ui::Widget::draw(float)
2022-01-14 12:51:02 [2,000,550ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ui.so!omni::ui::Frame::_drawContent(float)
2022-01-14 12:51:02 [2,000,553ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ui.so!omni::ui::Widget::draw(float)
2022-01-14 12:51:02 [2,000,556ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ui.so!omni::ui::Stack::_drawContent(float)
2022-01-14 12:51:02 [2,000,559ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ui.so!omni::ui::Widget::draw(float)
2022-01-14 12:51:02 [2,000,562ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ui.so!omni::ui::Frame::_drawContent(float)
2022-01-14 12:51:02 [2,000,565ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ui.so!omni::ui::ScrollingFrame::_drawContent(float)
2022-01-14 12:51:02 [2,000,568ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ui.so!omni::ui::Widget::draw(float)
2022-01-14 12:51:02 [2,000,571ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ui.so!omni::ui::Frame::_drawContent(float)
2022-01-14 12:51:02 [2,000,574ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ui.so!omni::ui::Widget::draw(float)
2022-01-14 12:51:02 [2,000,577ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ui.so!omni::ui::Window::_updateWindow(char const*, float, bool)
2022-01-14 12:51:02 [2,000,580ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ui.so!omni::ui::Window::_draw(char const*, float)
2022-01-14 12:51:02 [2,000,583ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ui.so!omni::ui::DockSpace::getDockFrame() const
2022-01-14 12:51:02 [2,000,586ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ui.windowmanager.plugin.so!carbOnPluginStartup
2022-01-14 12:51:02 [2,000,590ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.imgui_renderer.plugin.so!void std::vector<unsigned long, std::allocator<unsigned long> >::_M_realloc_insert<unsigned long const&>(__gnu_cxx::__normal_iterator<unsigned long*, std::vector<unsigned long, std::allocator<unsigned long> > >, unsigned long const&)
2022-01-14 12:51:02 [2,000,593ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.imgui_renderer.plugin.so!carbOnPluginPostShutdown
2022-01-14 12:51:02 [2,000,597ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.events.plugin.so!void std::this_thread::sleep_for<long, std::ratio<1l, 1000000l> >(std::chrono::duration<long, std::ratio<1l, 1000000l> > const&)
2022-01-14 12:51:02 [2,000,601ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.renderer.plugin.so!void std::vector<unsigned long, std::allocator<unsigned long> >::_M_realloc_insert<unsigned long const&>(__gnu_cxx::__normal_iterator<unsigned long*, std::vector<unsigned long, std::allocator<unsigned long> > >, unsigned long const&)
2022-01-14 12:51:02 [2,000,604ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.renderer.plugin.so!carbOnPluginRegisterEx
2022-01-14 12:51:02 [2,000,607ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.renderer.plugin.so!std::__future_base::_State_baseV2::_M_is_deferred_future() const
2022-01-14 12:51:02 [2,000,612ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.events.plugin.so!void std::this_thread::sleep_for<long, std::ratio<1l, 1000000l> >(std::chrono::duration<long, std::ratio<1l, 1000000l> > const&)
2022-01-14 12:51:02 [2,000,615ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.loop-default.plugin.so!std::thread::_State_impl<std::thread::_Invoker<std::tuple<omni::kit::RunLoopThread::run()::{lambda()#1}> > >::~_State_impl()
2022-01-14 12:51:02 [2,000,620ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.app.plugin.so!_init
2022-01-14 12:51:02 [2,000,624ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.app.plugin.so!carbOnPluginPostShutdown
2022-01-14 12:51:02 [2,000,624ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit!_init
2022-01-14 12:51:02 [2,000,629ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!__libc_start_main
2022-01-14 12:51:02 [2,000,629ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit!_init
Not sure if related but on startup I get this 2022-01-14 12:52:39 [5,012ms] [Error] [carb] Failed to create change watch for /home/dennisushi/.local/share/ov/pkg/isaac_sim-2021.1.0/exts/omni.isaac.app.setup: errno=28, No space left on device . Which is weird because I have lots of memory but may be if I have ran CUDA-enabled torch models previously? Not sure, but they are definitely not used when I start IsaacSim.
