Hello Mellanox,
I have ConnectX-3 QSFP Dual Port CX354A Adapter with Windows 7 x64 Pro on PC, I would like to make throughput test between QSFP ports. For this connected 1m fiber cable between ports and set CX354A in Ethernet mode in Device Manager. I also manualy set different IP addresses for 2 Ethernet adapters with the same IP mask:
IP1: 192.168.0.1
mask: 255.255.255.0
IP2: 192.168.0.2
mask: 255.255.255.0
I tried make tcp iperf3 test, but I had only 12 Gbit/s instead of 40 Gbit/s. In your documentation where ib_send_bw utility was recommended for testing the performance.
How make test with ib_send_bw between two Ethernet interfaces on one PC?
For example: to set interface in iperf3 I can choose with key -B: iperf3 -B 192.168.0.1.
Thank you.
With Best Wishes,
Dmitrii
