No I’m using the Driveworks IPC. The plan is to have a buffer or something that is initialized in the main function that can be passed to the runServer function to access the buffer and send it to a client (not implemented yet). Check my code below:
#include <dw/core/Context.h>
#include <dw/core/VersionCurrent.h>
#include <dw/ipc/SocketClientServer.h>
#include "../framework/Log.hpp"
#include "../framework/Checks.hpp"
#include <signal.h>
#include <iostream>
#include <thread>
#include <dw/core/Logger.h>
#include <dw/core/NvMedia.h>
// HAL
#include <dw/sensors/Sensors.h>
#include <dw/sensors/SensorSerializer.h>
#include <dw/sensors/camera/Camera.h>
// Image
#include <dw/image/ImageStreamer.h>
// Renderer
#include <dw/visualization/Renderer.h>
// Variables of working/debugging status of the program.
static volatile bool g_run = true;
// Method declarations
void sig_int_handler(int)
g_run = false;
void loggerCallback(dwContextHandle_t context, dwLoggerVerbosity type,
const char* msg)
fprintf(stdout, "%s", msg);
fflush(stdout);
dwStatus runServer(dwContextHandle_t ctx)
auto status = DW_FAILURE;
auto port = static_cast<uint16_t>(49252);
auto socketServer = dwSocketServerHandle_t{DW_NULL_HANDLE};
CHECK_DW_ERROR(dwSocketServer_initialize(&socketServer, port, 2, ctx));
// accept two connections (use two connections for illustration,
// a single connection can also be used bi-directionally)
auto socketConnectionRead = dwSocketConnectionHandle_t{DW_NULL_HANDLE},
socketConnectionWrite = dwSocketConnectionHandle_t{DW_NULL_HANDLE};
do {
status = dwSocketServer_accept(&socketConnectionRead, 10000, socketServer);
} while (status == DW_TIME_OUT);
do {
status = dwSocketServer_accept(&socketConnectionWrite, 10000, socketServer);
if (status != DW_FAILURE) {
while (g_run) {
size_t data;
auto size = sizeof(decltype(data));
// receive data
std::this_thread::sleep_for(std::chrono::milliseconds(std::rand() % 500));
if ((status = dwSocketConnection_recv(reinterpret_cast<uint8_t *>(&data), &size,
socketConnectionRead)) == DW_END_OF_STREAM)
break;
CHECK_DW_ERROR(status);
if (size != sizeof(decltype(data)))
break;
std::cout << "Socket Server received " << data << std::endl;
// SEND CAMERA DATA HERE
// send data back
if ((status = dwSocketConnection_send(reinterpret_cast<uint8_t *>(&data), &size,
socketConnectionWrite)) == DW_END_OF_STREAM)
break;
break;
std::cout << "Socket Server send " << data << std::endl;
CHECK_DW_ERROR(dwSocketConnection_release(socketConnectionWrite));
CHECK_DW_ERROR(dwSocketConnection_release(socketConnectionRead));
CHECK_DW_ERROR(dwSocketServer_release(socketServer));
return DW_SUCCESS;
dwStatus get_camera(dwContextHandle_t m_sdk)
// handles
dwSALHandle_t m_sal = DW_NULL_HANDLE;
//dwRendererHandle_t m_renderer = DW_NULL_HANDLE;
dwSensorSerializerHandle_t m_serializer;
dwLogger_initialize(loggerCallback);
dwLogger_setLogLevel(DW_LOG_VERBOSE);
dwContextParameters sdkParams = {};
dwVersion sdkVersion;
dwGetVersion(&sdkVersion);
dwStatus status = dwInitialize(&m_sdk, sdkVersion, &sdkParams);
if (status != DW_SUCCESS)
std::cerr << "Cannot init SDK" << std::endl;
return status;
std::cout << "Context of Driveworks SDK successfully initialized." << std::endl;
//Initialize SAL
dwSAL_initialize(&m_sal, m_sdk);
// Create sensor parameters
dwSensorHandle_t m_camera = DW_NULL_HANDLE;
dwSensorParams params;
params.parameters = "output-format=yuv,camera-type=ar0231-rccb-bae-sf3324,camera-group=a";
params.protocol = "camera.gmsl";
dwSAL_createSensor(&m_camera, params, m_sal);
//Start the sensor
dwSensor_start(m_camera);
//Initialize serializer
dwSerializerParams serializerParams;
serializerParams.parameters = "";
std::string newParams = "";
newParams += std::string("format=") + std::string("h264");
newParams += std::string(",bitrate=") + std::string("8000000");
newParams += std::string(",framerate=") + std::string("30");
newParams += std::string(",type=disk,file=") + std::string("/home/nvidia/ddpx.h264");
newParams += std::string(",slave=") + std::string("0");
serializerParams.parameters = newParams.c_str();
serializerParams.onData = nullptr;
CHECK_DW_ERROR(dwSensorSerializer_initialize(&m_serializer, &serializerParams, m_camera));
CHECK_DW_ERROR(dwSensorSerializer_start(m_serializer));
bool loop = true;
dwCameraFrameHandle_t frame = DW_NULL_HANDLE;
dwTime_t timeout = 33000;
while (loop)
dwStatus status = DW_NOT_READY;
do
status = dwSensorCamera_readFrame(&frame, 0, timeout, m_camera);
} while (status == DW_NOT_READY);
// get an image with the desired output format
dwImageHandle_t image;
dwSensorCamera_getImage(&image, DW_CAMERA_OUTPUT_NATIVE_PROCESSED, frame);
//dwSensorSerializer_serializeCameraFrameAsync(frame, m_serializer);
dwSensorSerializer_serializeImageAsync(image, m_serializer);
dwSensorCamera_returnFrame(&frame);
// release used objects in correct order
if (m_camera)
CHECK_DW_ERROR(dwSensor_stop(m_camera));
CHECK_DW_ERROR(dwSAL_releaseSensor(m_camera));
CHECK_DW_ERROR(dwSAL_release(m_sal));
CHECK_DW_ERROR(dwRelease(m_sdk));
CHECK_DW_ERROR(dwLogger_release());
std::cout << "*** Program exiting ***\n"
<< std::endl;
return status;
int main(int argc, const char **argv)
(void)argv;
(void)argc;
#if (!WINDOWS)
struct sigaction action = {};
action.sa_handler = sig_int_handler;
sigaction(SIGHUP, &action, NULL); // controlling terminal closed, Ctrl-D
sigaction(SIGINT, &action, NULL); // Ctrl-C
sigaction(SIGQUIT, &action, NULL); // Ctrl-\, clean quit with core dump
sigaction(SIGABRT, &action, NULL); // abort() called.
sigaction(SIGTERM, &action, NULL); // kill command
sigaction(SIGSTOP, &action, NULL); // kill command
#endif
g_run = true;
// Initialize context
auto ctx = dwContextHandle_t{DW_NULL_HANDLE};
CHECK_DW_ERROR(dwLogger_initialize(loggerCallback));
CHECK_DW_ERROR(dwLogger_setLogLevel(DW_LOG_VERBOSE));
CHECK_DW_ERROR(dwInitialize(&ctx, DW_VERSION, nullptr));
get_camera(ctx);
//runServer(ctx);
CHECK_DW_ERROR(dwRelease(ctx));
return 0;
