Send camera_id to kafka
I used the new element gst-nvmultiurisrcbin. Looking at the tutorial, i saw that it take the camera_id as the input parameter when using REST api to add new stream. I also use Kafka to send metadata but I want to send the camera_id provided by the REST api through kafka instead of the id contain in dstest5_msgconv_sample_config.txt. How can i do this ?
Looking forward for your help !
• DeepStream Version 6.2
Could you try to set the id parameter in dstest5_msgconv_sample_config.txt to the camera_id in REST api?
