Send detected object info
**• Jetson Xavier Nx
**• DeepStream 5.1
**• JetPack. 4.5.1
Hello everyone,
I am trying to inference a number of rtsp stream source by using reference application and this config file : source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
Is there any plugin or config that i can use to send detected object info( Bbox and Class ) to server ?
Could you please help me ?
You can find an example in the below folder:
/opt/nvidia/deepstream/deepstream-5.1/sources/apps/sample_apps/deepstream-test5
The corresponding document can be found here:
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_ref_app_test5.html
