• Hardware Platform (Jetson / GPU): GPU: RTX Titan or RTX 2080
• DeepStream Version: 6.0
• NVIDIA GPU Driver Version (valid for GPU only): 465.31
• Issue Type( questions, new requirements, bugs): Question
• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing): Send an empty array such as np.ones((4, 0))
I have a triton model for object detection, some times I need to send empty tensors (in case no objects were detected) but when I do, I get the following errors.
/opt/tritonserver/backends/python/startup.py:308: DeprecationWarning: `np.object` is a deprecated alias for the builtin `object`. To silence this warning, use `object` by itself. Doing this will not modify any behavior and is safe.
Deprecated in NumPy 1.20; for more details and guidance: https://numpy.org/devdocs/release/1.20.0-notes.html#deprecations
if output_np_array.dtype == np.object or output_np_array.dtype.type is np.bytes_:
pytorch-test-app: infer_cuda_utils.cpp:91: nvdsinferserver::CudaTensorBuf::CudaTensorBuf(const nvdsinferserver::InferDims&, nvdsinferserver::InferDataType, int, const string&, nvdsinferserver::InferMemType, int, bool): Assertion `bufBytes > 0' failed.
Usually the numpy tensors has the shape of [1,0,6].
I have tried sending empty arrays or just not including the output in the inferenceResponse object. In both cases I am not able to send results. The only way I can use is send invalid result and check if it is valid or not. What is the best way of sending empty tensors in this case?
