I am sending a video file (.mov file) from a jetson nano to raspberry pi with Ubuntu Server OS.
I’ve written the client and server application to communicate via TCP. I send the file over to Pi in 1024 byte chunks. I have the proper handling in place for packets that are smaller than that size on the sending and receiving ends.
When sending and receiving, I am getting the appropriate amount of bytes that is equivalent to the size of the file, so I am not losing any packets/information.
When I run command below on the jetson nano
ffprobe -i test.mov
I get a correct output from the command:
Input #0, mov, mp4, m4a, 3gp, 3g2, mj2, from 'test.mov'
When I run the same ffprobe() command on the raspberry pi, I get the following errors:
ffprobe version 4.3.2-0+deb11u1ubuntu1 Copyright (c) 2007-2021 the FFmpeg developers
built with gcc 10 (Ubuntu 10.2.1-20ubuntu1)
configuration: --prefix=/usr --extra-version=0+deb11u1ubuntu1 --toolchain=hardened --libdir=/usr/lib/aarch64-linux-gnu --incdir=/usr/include/aarch64-linux-gnu --arch=arm64 --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librabbitmq --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-pocketsphinx --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared
libavutil 56. 51.100 / 56. 51.100
libavcodec 58. 91.100 / 58. 91.100
libavformat 58. 45.100 / 58. 45.100
libavdevice 58. 10.100 / 58. 10.100
libavfilter 7. 85.100 / 7. 85.100
libavresample 4. 0. 0 / 4. 0. 0
libswscale 5. 7.100 / 5. 7.100
libswresample 3. 7.100 / 3. 7.100
libpostproc 55. 7.100 / 55. 7.100
[mov,mp4,m4a,3gp,3g2,mj2 @ 0xaaaac833b960] Format mov,mp4,m4a,3gp,3g2,mj2 detected only with low score of 1, misdetection possible!
[mov,mp4,m4a,3gp,3g2,mj2 @ 0xaaaac833b960] moov atom not found
test.mov: Invalid data found when processing input
Even though I have received the correct amount of bytes and created a file with the same amount of bytes on the Pi’s side, is there any suggestion as to why the video is unable to be properly decoded/read after file transmission?
Any suggestion will help.
Thank you.
