I have setup a pipeline for doing some analytics using trakcer . I want to send Metadata for eg: in deepstrem_nvdsanalytics_test.cpp , I want to send objInROIcnt metadata information to a different client pc via UDP/TCP . This should happen continuously and whenever there is a change in objInROIcnt over the frames . How can I do that ? Can you please share sample code ?
• Hardware Platform (Jetson / GPU) Orin
• DeepStream Version 6
• JetPack Version (valid for Jetson only) 5.1
• TensorRT Version
• Issue Type( questions, new requirements, bugs) Questtion
