Here i will paste the two settings objects, so you can see they are the same:
The working job:
###### User
michaelbaggott
###### Comment
(No comment available)
###### Definition
“task_type”: “create-render”,
“task_args”: {},
“task_function”: “render.run”,
“task_function_args”: {
“usd_file”: “omniverse://localhost/Projects/Moreton/Moreton_Save.usd”,
“render_settings”: {
“camera”: “/OmniverseKit_Persp”,
“range_type”: 0,
“capture_every_nth_frames”: 1,
“fps”: “24”,
“start_frame”: 1,
“end_frame”: 1,
“start_time”: 0,
“end_time”: 10,
“res_width”: 1920,
“res_height”: 1080,
“render_preset”: 1,
“debug_material_type”: 0,
“spp_per_iteration”: 1,
“path_trace_spp”: 1,
“ptmb_subframes_per_frame”: 1,
“ptmb_fso”: 0,
“ptmb_fsc”: 1,
“output_folder”: “C:/render_output”,
“file_name”: “Capture”,
“file_name_num_pattern”: “.####”,
“file_type”: “.png”,
“save_alpha”: false,
“hdr_output”: false,
“show_pathtracing_single_frame_progress”: false,
“preroll_frames”: 0,
“overwrite_existing_frames”: false,
“movie_type”: 0,
“sunstudy_start_time”: 0,
“sunstudy_current_time”: 0,
“sunstudy_end_time”: 0,
“sunstudy_movie_length_in_seconds”: 0,
“sunstudy_player”: null,
“real_time_settle_latency_frames”: 0
“render_start_delay”: 10
“task_comment”: “”
The job that isn’t working:
###### User
michaelbaggott
###### Comment
###### Definition
“task_args”: {},
“range_type”: 0,
“fps”: 24,
“start_frame”: 1,
“end_frame”: 1,
“start_time”: 0,
“end_time”: 10,
“res_width”: 1920,
“res_height”: 1080,
“render_preset”: 1,
“ptmb_fso”: 0,
“ptmb_fsc”: 1,
“output_folder”: “C:/render_output/”,
“movie_type”: 0,
“task_comment”: “”
