Hi All,
In Jetson Tx2, We are using our sensor driver. When sensor driver attach to vi driver, then it gets corrupted as:
272796] wifi_platform_get_country_code_map: could not get country_code_map
[ 13.282440] wifi_plat_dev_drv_probe:platform country code map is not available
[ 13.291001] fpga_hdmi2csi_drv fpga_hdmi2csi: ####### fpga_convert_probe #########
[ 13.291004] fpga_hdmi2csi_drv fpga_hdmi2csi: ### memory allocated ###
[ 13.291005] fpga_hdmi2csi_drv fpga_hdmi2csi: ### device tree node found ###
[ 13.291007] fpga_hdmi2csi_drv fpga_hdmi2csi: #### Device Tree Parameters: ####
[ 13.291008] : In Probe()
[ 13.291018] ***** After media_entity_init() *****
[ 13.291754] fpga_hdmi2csi: fpga_hdmi2csi_enum_mbus_code()
[ 13.291756] fpga_hdmi2csi: code->index:0
[ 13.291757] fpga_hdmi2csi: fpga_hdmi2csi_enum_mbus_code()
[ 13.291758] fpga_hdmi2csi: code->index:1
[ 13.291760] fpga_hdmi2csi: fpga_hdmi2csi_get_fmt():
[ 13.291762] fpga_hdmi2csi: fpga_hdmi2csi_get_fmt(): width=0, height=0, code=0x0000200F, field=1
[ 13.291777] Unable to handle kernel paging request at virtual address 00020177
[ 13.291778] pgd = ffffffc1e2817000
[ 13.291781] [00020177] *pgd=0000000000000000, *pud=0000000000000000
[ 13.291784] Internal error: Oops: 96000045 [#1] PREEMPT SMP
[ 13.291788] Modules linked in: fpga_hdmi2csi_drv(+) bcmdhd(+) pci_tegra bluedroid_pm
[ 13.291792] CPU: 3 PID: 309 Comm: systemd-udevd Not tainted 4.4.38 #159
[ 13.291793] Hardware name: quill (DT)
[ 13.291795] task: ffffffc1e479e400 ti: ffffffc1e2828000 task.ti: ffffffc1e2828000
[ 13.291801] PC is at tegra_channel_s_ctrl+0x164/0x268
[ 13.291805] LR is at v4l2_ctrl_handler_setup+0xf0/0x130
[ 13.291807] pc : [] lr : [] pstate: 80000045
[ 13.291808] sp : ffffffc1e282b8b0
[ 13.291810] x29: ffffffc1e282b8b0 x28: ffffffc1eb6663c8
[ 13.291812] x27: ffffffc1e45b6550 x26: 0000000000000001
[ 13.291813] x25: ffffffc000c24000 x24: ffffffc1eb6664e0
[ 13.291815] x23: ffffffc1eb666510 x22: ffffffc1e5b2d200
[ 13.291816] x21: 0000000000000000 x20: ffffffc1e5b2d200
[ 13.291818] x19: ffffffc1eb666018 x18: 0000000000020000
[ 13.291820] x17: 000000000041a485 x16: 0000000000000001
[ 13.291821] x15: ffffffc0012381e8 x14: 0000000000000000
[ 13.291823] x13: ffffffc1eb6664e0 x12: 0000000000000000
[ 13.291824] x11: 0000000000000000 x10: ffffffc1e282b888
[ 13.291826] x9 : 0000000000000000 x8 : ffffffc1e5ba8780
[ 13.291827] x7 : 0000000000000000 x6 : ffffffc1e5b2d2bc
[ 13.291829] x5 : 0000000000000040 x4 : 00000001f4b36000
[ 13.291830] x3 : 0000000000000000 x2 : 000000000001ffba
[ 13.291832] x1 : ffffffc000c24000 x0 : ffffffc0013c1000
[ 13.291834] Process systemd-udevd (pid: 309, stack limit = 0xffffffc1e2828020)
[ 13.291835] Call trace:
[ 13.291837] [] tegra_channel_s_ctrl+0x164/0x268
[ 13.291840] [] v4l2_ctrl_handler_setup+0xf0/0x130
[ 13.291842] [] tegra_channel_init_subdevices+0x290/0x300
[ 13.291846] [] tegra_vi_graph_notify_complete+0x258/0x658[b][/b]
[ 13.291849] [] v4l2_async_test_notify+0xf0/0x100
[ 13.291851] [] v4l2_async_register_subdev+0x88/0x108
[ 13.291858] [] fpga_convert_probe+0x20c/0x2c0 [fpga_hdmi2csi_drv]
[ 13.291863] [] platform_drv_probe+0x50/0xb8
[ 13.291866] [] driver_probe_device+0xcc/0x428
[ 13.291868] [] __driver_attach+0x9c/0xa0
[ 13.291870] [] bus_for_each_dev+0x60/0xa0
[ 13.291871] [] driver_attach+0x20/0x28
[ 13.291873] [] bus_add_driver+0x210/0x298
[ 13.291874] [] driver_register+0x60/0xf8
[ 13.291876] [] __platform_driver_register+0x4c/0x58
[ 13.291881] [] fpga_convert_driver_init+0x18/0x30 [fpga_hdmi2csi_drv]
[ 13.291884] [] do_one_initcall+0xd0/0x1d8
[ 13.291888] [] do_init_module+0x64/0x1c4
[ 13.291891] [] load_module+0xed8/0x1198
[ 13.291893] [] SyS_finit_module+0xe0/0x110
[ 13.291895] [] el0_svc_naked+0x24/0x28
[ 13.291897] —[ end trace cadace3bdea92d26 ]—
[ 13.746833] Power-up adapter ‘DHD generic adapter’
[ 13.752970] wifi_platform_set_power = 1
Please provide your inputs.
-Thanks.
