Sensor driver problem
Hello, Why is the actual reading inconsistent with my Settings, I want to set 1080P 30fps, 1080P 60fps, 4k 30fps, 4k 60fps, how to modify it, thank you
Current duplicate size would cause confuse.
I would suggest report only one 1080p@60 and use the set_framerate to set the frame rate instead of report 1080p@30 and 1080p@60 two modes.
ok,i will try, but how to set dtb mode ? Because pixclk is different at different frame rates
