I sucessfully developed camera sensor driver. The problem is that I used ser-des, so reading fuse id and eeprom can be done after setup the link and sensor only. I do not read these parameters during the probe, because I prefer to read them after camera is running, in set_mode step. Camera framework calls “…fill_string_ctrl” before these parameters are physically read in set_mode. How to make a additional call to “…fill_string_ctrl” function with specified control id in set_mode step?
Thanks for your reply. I would like to use frame grabber based on Jetson Xavier for long term camera tests.
Eeprom should be read many times during the tests. I also need to rea registers from camera, like frames counter, temp sensor…etc
