Today I checked using nvidia recording tool. But same problems occur.
(timestamp of CAN and Camera are different)
Here is my rig configuration
“rig”: {
“properties”: {
“layout”: “Hyperion 7.0”
“sensors”: [
“correction_rig_T”: [
0.0,
0.0,
0.0
“correction_sensor_R_FLU”: {
“roll-pitch-yaw”: [
0.03438815474510193,
-3.7623074054718018,
0.16219370067119598
“name”: “camera:front:center:60fov”,
“nominalSensor2Rig_FLU”: {
“roll-pitch-yaw”: [
-5.798638449050486e-05,
1.1458930969238281,
-0.5729333758354187
“t”: [
1.7489999532699585,
-0.10000000149011612,
1.4700000286102295
“parameter”: “camera-type=ar0231-rccb-bae-sf3324,camera-group=a,camera-count=4,siblingIndex=0,slave=0,format=h264,fifo-size=4,isp-mode=yuv420-uint8,bitrate=8000000,framerate=10,type=disk,file=video1.h264”,
“properties”: {
“Model”: “ftheta”,
“bw-poly”: “0.0 0.000545421498827636 -1.6216719633103e-10 -4.64720492990289e-12 2.85224527762934e-16”,
“cx”: “960”,
“cy”: “604”,
“height”: “1208”,
“width”: “1920”
“protocol”: “camera.gmsl”
0.0,
0.0,
0.0
“roll-pitch-yaw”: [
0.16219370067119598
“name”: “camera:front:left:60fov”,
“roll-pitch-yaw”: [
1.1458930969238281,
-0.5729333758354187
“t”: [
1.7489999532699585,
1.4700000286102295
“parameter”: “camera-type=ar0231-rccb-bae-sf3324,camera-group=a,camera-count=4,siblingIndex=1,slave=0,format=h264,fifo-size=4,isp-mode=yuv420-uint8,bitrate=8000000,framerate=10,type=disk,file=video2.h264”,
“properties”: {
“Model”: “ftheta”,
“cx”: “960”,
“cy”: “604”,
“height”: “1208”,
“width”: “1920”
0.0,
0.0,
0.0
“roll-pitch-yaw”: [
0.16219370067119598
“name”: “camera:front:right:60fov”,
“roll-pitch-yaw”: [
1.1458930969238281,
-0.5729333758354187
“t”: [
1.7489999532699585,
1.4700000286102295
“parameter”: “camera-type=ar0231-rccb-bae-sf3324,camera-group=a,camera-count=4,siblingIndex=2,slave=0,format=h264,fifo-size=4,isp-mode=yuv420-uint8,bitrate=8000000,framerate=10,type=disk,file=video3.h264”,
“properties”: {
“Model”: “ftheta”,
“cx”: “960”,
“cy”: “604”,
“height”: “1208”,
“width”: “1920”
0.0,
0.0,
0.0
“roll-pitch-yaw”: [
0.16219370067119598
“name”: “camera:front:rear:60fov”,
“roll-pitch-yaw”: [
1.1458930969238281,
-0.5729333758354187
“t”: [
1.7489999532699585,
1.4700000286102295
“parameter”: “camera-type=ar0231-rccb-bae-sf3324,camera-group=a,camera-count=4,siblingIndex=3,slave=0,format=h264,fifo-size=4,isp-mode=yuv420-uint8,bitrate=8000000,framerate=10,type=disk,file=video4.h264”,
“properties”: {
“Model”: “ftheta”,
“cx”: “960”,
“cy”: “604”,
“height”: “1208”,
“width”: “1920”
“name”: “can:vehicle:generic”,
“parameter”: “device=can1,type=disk,file=can1.bin,serialize=true”,
“protocol”: “can.socket”,
“properties”: null,
“nominalSensor2Rig”: { “quaternion”: [ 0.0, 0.0, 0.0, 1.0 ], “t”: [ 0.0, 0.0, 0.0 ] },
“sensor2Rig”: { “quaternion”: [ 0.0, 0.0, 0.0, 1.0 ], “t”: [ 0.0, 0.0, 0.0 ] }
“vehicle”: {
“valid”: true,
“value”: {
“axlebaseFront”: 1.582419991493225,
“axlebaseRear”: 1.5748000144958496,
“bumperFront”: 0.9120000004768372,
“bumperRear”: 1.1090999841690063,
“centerOfMassToRearAxle”: 1.5644999742507935,
“driveByWireTimeConstant”: 0.25999999046325684,
“driveByWireTimeDelay”: 0.10999999940395355,
“frontCorneringStiffness”: 30654.0,
“height”: 1.4731999635696411,
“inertia”: 1780.800048828125,
“length”: 4.871719837188721,
“mass”: 1779.4000244140625,
“rearCorneringStiffness”: 36407.0,
“steeringCoefficient”: 14.800000190734863,
“wheelDiameter”: 0.672702968120575,
“wheelbase”: 2.8498799800872803,
“width”: 1.8516600131988525,
“widthWithMirrors”: 0.0,
“driveByWireTimeDelay”: 0.11,
“aerodynamicDragCoeff”: 0.7,
“frontalArea”: 1.0,
“centerOfMassHeight”: 1.5,
“aeroHeight”: 1.5,
“rollingResistanceCoeff”: 0.015,
“maxEnginePower”: 134e3,
“throttleActuatorTimeConstant”: 1.0,
“brakeActuatorTimeConstant”: 0.5,
“centerOfMassToFrontAxle”: 1.286,
“throttleStateInput”: [0, 0.07, 0.14, 0.21, 0.29, 0.36, 0.43, 0.50, 0.57, 0.64, 0.71, 0.79, 0.86, 0.93, 1.00],
“throttleForceOutput”: [0, 312, 623, 1086, 2646, 4272, 5370, 6052, 6363, 6556, 6730, 6905, 7092, 7283, 7473],
“brakeStateInput”: [0, 0.07, 0.14, 0.21, 0.29, 0.36, 0.43, 0.50, 0.57, 0.64, 0.71, 0.79, 0.86, 0.93, 1.00],
“brakeForceOutput”: [0, 714, 1423, 2143, 2857, 3571, 4286, 5000, 5714, 6429, 7143, 7857, 8571, 9286, 10000]
“version”: 2
