Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”):
Software Version
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.5.0.7774
other
Host Machine Version
native Ubuntu 18.04
other
I have written two custom sensor plugins using dwSensorIMUPlugin
and dwSensorGPSPlugin
Both are working as expected with sample_imu_logger --driver imu.custom
and sample_gps_logger --driver gps.custom
I have also written respective .json rig files, and the recorder
tool saves the data succssfully.
However, only the IMU plugin can be played back using sample_imu_logger --driver imu.virtual
. The GPS plugin does not work when trying to play back using sample_gps_logger --driver gps.virtual
Both plugins were implemented in a nearly identical way. In fact, readRawData
and pushData
are identical between the two.
I did realise that parseData
in IMU plugin requires return DW_NOT_AVAILABLE
when there is not enough data to parse, whereas GPS plugin requires return DW_FAILURE
when there is not enough data to parse. Both plugins require return DW_SUCCESS
when there is more data to parse. This is a strange inconsistency and I noticed the documentation in DriveWorks 2.2 is wrong because it says GPS parseData should return DW_NOT_AVAILABLE
rather than DW_FAILURE
Debugging into what is going on when playing back gps.virtual
, it starts from pushData
, skipping readRawData
since the raw data comes from file instead. It seems that size
is 0, which is causing the problem. However it is strange that in imu.virtual
, size
is correct and therefore it can be played back.
Perhaps this is to do with the strange requirement for readRawData
to output to data
pointer a header consisting of uint32_t
size and dwTime_t
timestamp before payload. It is strange because size is also output to size
pointer. It is even more strange because I tested IMU plugin without the header, and it still works in live, recording and imu.virtual playback. It is clear that for IMU plugin, size is taken from the size
pointer rather than from the data header.
So maybe the problem is related to the strange GPS plugin inconsistencies? Maybe the size field in data header is used by GPS but not by IMU plugin? But for GPS plugin, gps.virtual playback does not work (size 0 in pushData) even with and without the size header.
