separableConvolution mirroring edges
Hi all,
I am trying to modify the CUDA SDK separableConvolution[1] example to use mirroring behavior, rather than constant 0 for pixels near the edges of the image. This whitepaper [2] mentions that it is possible to do this, but it’s not clear how to actually do that. The code is fairly difficult to understand. I believe I have to change the following line in each row/column kernel:
data[smemPos] =
     ((loadPos >= apronStartClamped) && (loadPos <= apronEndClamped)) ?
     d_Data[rowStart + loadPos] : 0;
Using d_Data[rowStart] instead of 0 almost works for the top of the image, but not the bottom, as one might expect. I’m not sure what the correct index is for the bottom of the image.
Thank you!
[1] http://docs.nvidia.com/cuda/cuda-samples/index.html#cuda-separable-convolution
[2] http://igm.univ-mlv.fr/~biri/Enseignement/MII2/Donnees/convolutionSeparable.pdf
here is the full code:
//24-bit multiplication is faster on G80,
//but we must be sure to multiply integers
//only within [-8M, 8M - 1] range
#define IMUL(a, b) __mul24(a, b)
// Kernel configuration
#define KERNEL_RADIUS 8
#define      KERNEL_W (2 * KERNEL_RADIUS + 1)
__device__ __constant__ float d_Kernel[KERNEL_W];
// Assuming ROW_TILE_W, KERNEL_RADIUS_ALIGNED and dataW
// are multiples of maximum coalescable read/write size,
// all global memory operations are coalesced in convolutionRowGPU()
#define            ROW_TILE_W 128
#define KERNEL_RADIUS_ALIGNED 16
// Assuming COLUMN_TILE_W and dataW are multiples
// of maximum coalescable read/write size, all global memory operations
// are coalesced in convolutionColumnGPU()
#define COLUMN_TILE_W 16
#define COLUMN_TILE_H 48
// Loop unrolling templates, needed for best performance
template<int i> __device__ float convolutionRow(float *data){
    return
        data[KERNEL_RADIUS - i] * d_Kernel[i]
        + convolutionRow<i - 1>(data);
template<> __device__ float convolutionRow<-1>(float *data){
    return 0;
template<int i> __device__ float convolutionColumn(float *data){
    return
        data[(KERNEL_RADIUS - i) * COLUMN_TILE_W] * d_Kernel[i]
        + convolutionColumn<i - 1>(data);
template<> __device__ float convolutionColumn<-1>(float *data){
    return 0;
// Row convolution filter
__global__ void convolutionRowGPU(
    float *d_Result,
    float *d_Data,
    int dataW,
    int dataH
    //Data cache
    __shared__ float data[KERNEL_RADIUS + ROW_TILE_W + KERNEL_RADIUS];
    //Current tile and apron limits, relative to row start
    const int         tileStart = IMUL(blockIdx.x, ROW_TILE_W);
    const int           tileEnd = tileStart + ROW_TILE_W - 1;
    const int        apronStart = tileStart - KERNEL_RADIUS;
    const int          apronEnd = tileEnd   + KERNEL_RADIUS;
    //Clamp tile and apron limits by image borders
    const int    tileEndClamped = min(tileEnd, dataW - 1);
    const int apronStartClamped = max(apronStart, 0);
    const int   apronEndClamped = min(apronEnd, dataW - 1);
    //Row start index in d_Data[]
    const int          rowStart = IMUL(blockIdx.y, dataW);
    //Aligned apron start. Assuming dataW and ROW_TILE_W are multiples
    //of half-warp size, rowStart + apronStartAligned is also a
    //multiple of half-warp size, thus having proper alignment
    //for coalesced d_Data[] read.
    const int apronStartAligned = tileStart - KERNEL_RADIUS_ALIGNED;
    const int loadPos = apronStartAligned + threadIdx.x;
    //Set the entire data cache contents
    //Load global memory values, if indices are within the image borders,
    //or initialize with zeroes otherwise
    if(loadPos >= apronStart){
        const int smemPos = loadPos - apronStart;
        data[smemPos] =
    //Ensure the completness of the loading stage
    //because results, emitted by each thread depend on the data,
    //loaded by another threads
    __syncthreads();
    const int writePos = tileStart + threadIdx.x;
    //Assuming dataW and ROW_TILE_W are multiples of half-warp size,
    //rowStart + tileStart is also a multiple of half-warp size,
    //thus having proper alignment for coalesced d_Result[] write.
    if(writePos <= tileEndClamped){
        const int smemPos = writePos - apronStart;
        float sum = 0;
#ifdef UNROLL_INNER
        sum = convolutionRow<2 * KERNEL_RADIUS>(data + smemPos);
#else
        for(int k = -KERNEL_RADIUS; k <= KERNEL_RADIUS; k++)
            sum += data[smemPos + k] * d_Kernel[KERNEL_RADIUS - k];
#endif
        d_Result[rowStart + writePos] = sum;
// Column convolution filter
__global__ void convolutionColumnGPU(
    float *d_Result,
    float *d_Data,
    int dataW,
    int dataH,
    int smemStride,
    int gmemStride
    //Data cache
    __shared__ float data[COLUMN_TILE_W * (KERNEL_RADIUS + COLUMN_TILE_H + KERNEL_RADIUS)];
    //Current tile and apron limits, in rows
    const int         tileStart = IMUL(blockIdx.y, COLUMN_TILE_H);
    const int           tileEnd = tileStart + COLUMN_TILE_H - 1;
    const int    tileEndClamped = min(tileEnd, dataH - 1);
    const int   apronEndClamped = min(apronEnd, dataH - 1);
    //Current column index
    const int       columnStart = IMUL(blockIdx.x, COLUMN_TILE_W) + threadIdx.x;
    //Shared and global memory indices for current column
    int smemPos = IMUL(threadIdx.y, COLUMN_TILE_W) + threadIdx.x;
    int gmemPos = IMUL(apronStart + threadIdx.y, dataW) + columnStart;
    //Cycle through the entire data cache
    //or initialize with zero otherwise
    for(int y = apronStart + threadIdx.y; y <= apronEnd; y += blockDim.y){
        data[smemPos] =
        ((y >= apronStartClamped) && (y <= apronEndClamped)) ?
        d_Data[gmemPos] : 0;
        smemPos += smemStride;
        gmemPos += gmemStride;
    __syncthreads();
    smemPos = IMUL(threadIdx.y + KERNEL_RADIUS, COLUMN_TILE_W) + threadIdx.x;
    gmemPos = IMUL(tileStart + threadIdx.y , dataW) + columnStart;
    //Cycle through the tile body, clamped by image borders
    //Calculate and output the results
    for(int y = tileStart + threadIdx.y; y <= tileEndClamped; y += blockDim.y){
        float sum = 0;
#ifdef UNROLL_INNER
        sum = convolutionColumn<2 * KERNEL_RADIUS>(data + smemPos);
#else
            sum +=
                data[smemPos + IMUL(k, COLUMN_TILE_W)] *
#endif
        d_Result[gmemPos] = sum;
invoked like:
printf("%i x %i\n", DATA_W, DATA_H);
    printf("Initializing data...\n");
        h_Kernel    = (float *)malloc(KERNEL_SIZE);
        h_DataA     = (float *)malloc(DATA_SIZE);
        h_DataB     = (float *)malloc(DATA_SIZE);
        h_ResultGPU = (float *)malloc(DATA_SIZE);
        CUDA_SAFE_CALL( cudaMalloc( (void **)&d_DataA, DATA_SIZE) );
        CUDA_SAFE_CALL( cudaMalloc( (void **)&d_DataB, DATA_SIZE) );
        CUDA_SAFE_CALL( cudaMalloc( (void **)&d_Temp , DATA_SIZE) );
        float kernelSum = 0;
        for(i = 0; i < KERNEL_W; i++){
            float dist = (float)(i - KERNEL_RADIUS) / (float)KERNEL_RADIUS;
            h_Kernel[i] = expf(- dist * dist / 2);
            kernelSum += h_Kernel[i];
            h_Kernel[i] /= kernelSum;
        srand((int)time(NULL));
        for(i = 0; i < DATA_W * DATA_H; i++)
            h_DataA[i] = (float)rand() / (float)RAND_MAX;
        CUDA_SAFE_CALL( cudaMemcpyToSymbol(d_Kernel, h_Kernel, KERNEL_SIZE) );
        CUDA_SAFE_CALL( cudaMemcpy(d_DataA, h_DataA, DATA_SIZE, cudaMemcpyHostToDevice) );
    dim3 blockGridRows(iDivUp(DATA_W, ROW_TILE_W), DATA_H);
    dim3 blockGridColumns(iDivUp(DATA_W, COLUMN_TILE_W), iDivUp(DATA_H, COLUMN_TILE_H));
    dim3 threadBlockRows(KERNEL_RADIUS_ALIGNED + ROW_TILE_W + KERNEL_RADIUS);
    dim3 threadBlockColumns(COLUMN_TILE_W, 8);
   convolutionRowGPU<<<blockGridRows, threadBlockRows>>>(
            d_DataB,
            d_DataA,
            DATA_W,
            DATA_H
        CUT_CHECK_ERROR("convolutionRowGPU() execution failed\n");
        convolutionColumnGPU<<<blockGridColumns, threadBlockColumns>>>(
            d_DataA,
            d_DataB,
            DATA_W,
            DATA_H,
            COLUMN_TILE_W * threadBlockColumns.y,
            DATA_W * threadBlockColumns.y
