Dear all,
We are developing a developmental robotics framework called Aquila (see the recent article on NVidia), which compiles just fine when I use CUDA Toolkit 3.0 but gives me a segmentation fault when I use the latest version 3.2. It will be realted to the actual toolkit since I can run the latest drivers 260.19.21 with the old toolkit, which is obviously not something I want to do :)
I have no clue what is wrong, could someone please help me to understand what is going on?
This is my project file, the bottom part of which I am not entirely sure about as it deals with linking the nvcc compiler to .cu files so perhaps something wrong there?
# Aquila - CUDA enabled AI system #
# Copyright (C) 2010 Martin Peniak(www.martinpeniak.com) and Anthony Morse(anthony.morse@plymouth.ac.uk) #
# This program is free software: you can redistribute it and/or modify it under the terms of the GNU #
# General Public License as published by the Free Software Foundation, either version 3 of the License, #
# or (at your option) any later version. #
QT += opengl \
xml
CONFIG += opengl
TARGET = Aquila
TEMPLATE = app
SOURCES += src/main.cpp \
src/mainwindow.cpp \
src/splashscreen.cpp \
src/yarp.cpp \
src/modi.cpp \
src/plots.cpp \
src/iCub_control.cpp \
src/custom_som.cpp \
src/speech.cpp \
src/xml.cpp \
src/development.cpp
CUSOURCES += src/cuda_mtrnn.cu \
src/cuda_som.cu \
src/cuda_esn.cu \
src/cuda_image_processing.cu
OTHER_FILES += src/cuda_esn.cu \
src/cuda_mtrnn.cu \
src/cuda_som.cu \
HEADERS += src/mainwindow.h \
src/splashscreen.h \
src/yarp.h \
src/globals.h \
src/modi.h \
src/cuda_mtrnn.h \
src/cuda_som.h \
src/plots.h \
src/iCub_control.h \
src/cuda_image_processing.h \
src/cuda_esn.h \
src/custom_som.h \
src/yarp.h \
src/cuda_esn.h \
src/speech.h \
src/xml.h \
src/development.h
FORMS += ui/mainwindow.ui
RESOURCES += res/resources.qrc
DESTDIR = bin
OBJECTS_DIR = bld/obj
MOC_DIR = bld/moc
UI_DIR = bld/ui
RCC_DIR = bld/rcc
QMAKE_CXXFLAGS += -fopenmp
# get the user name
UNAME = $$system(whoami)
INCLUDEPATH += ./src \
/home/$$UNAME/Dev/Lib/yarp2/src/libYARP_dev/include \
/home/$$UNAME/Dev/Lib/yarp2/src/libYARP_OS/include \
/home/$$UNAME/Dev/Lib/yarp2/src/libYARP_sig/include \
/home/$$UNAME/Dev/Lib/yarp2/src/libYARP_math/include \
/home/$$UNAME/Dev/Lib/yarp2/generated_include \
/home/$$UNAME/Dev/Lib/qwtplot3d/include \
/home/$$UNAME/Dev/Lib/qwt-5.2.1/src \
/usr/local/cuda/include
LIBPATH += /home/$$UNAME/NVIDIA_GPU_Computing_SDK/shared/lib \
/home/$$UNAME/Dev/Lib/qwtplot3d/lib \
/home/$$UNAME/Dev/Lib/qwt-5.2.1/lib \
/home/$$UNAME/Dev/Lib/yarp2/lib
LIBS += -lYARP_dev \
-lYARP_OS \
-lYARP_sig \
-lYARP_math \
-lYARP_init \
-lyarpcar \
-lyarpmod \
-lACE \
-fopenmp \
-lqwtplot3d \
-lqwt
# NVCC SETTINGS
QMAKE_CUC = /usr/local/cuda/bin/nvcc
cuda.input = CUSOURCES
INCLUDEPATH += /home/$$UNAME/NVIDIA_GPU_Computing_SDK/shared/inc
LIBPATH += /usr/local/cuda/lib64
LIBS += -lcudart
isEmpty(CU_DIR):CU_DIR = .
isEmpty(QMAKE_CPP_MOD_CU):QMAKE_CPP_MOD_CU =
isEmpty(QMAKE_EXT_CPP_CU):QMAKE_EXT_CPP_CU = .cu
ReleaseBuild:QMAKE_CUFLAGS += $$QMAKE_CXXFLAGS_RELEASE
message(QMAKE_CUFLAGS: $$QMAKE_CUFLAGS)
QMAKE_CUEXTRAFLAGS += $(DEFINES) \
$(INCPATH)
QMAKE_CUEXTRAFLAGS += -c \
-use_fast_math
# use -deviceemu to test the code by emulation by uncommenting the line below
# this mode is only available with CUDA 3.0 and lower
#QMAKE_CUEXTRAFLAGS += -deviceemu
QMAKE_EXTRA_VARIABLES += QMAKE_CUEXTRAFLAGS
cuda.commands = $$QMAKE_CUC \
$(EXPORT_QMAKE_CUEXTRAFLAGS) \
-o \
$$OBJECTS_DIR/$${QMAKE_CPP_MOD_CU}${QMAKE_FILE_BASE}$${QMAKE_EXT_OBJ} \
${QMAKE_FILE_NAME}$$escape_expand(\n\t)
cuda.output = $$OBJECTS_DIR/$${QMAKE_CPP_MOD_CU}${QMAKE_FILE_BASE}$${QMAKE_EXT_OBJ}
QMAKE_EXTRA_COMPILERS += cuda
This is the error I get:
Running build steps for project Aquila...
Starting: "/usr/bin/make" clean -w
make: Entering directory `/home/mpeniak/Desktop/Aquila'
rm -f bld/obj/cuda_mtrnn.o bld/obj/cuda_som.o bld/obj/cuda_esn.o bld/obj/cuda_image_processing.o
rm -f bld/moc/moc_mainwindow.cpp bld/moc/moc_splashscreen.cpp
rm -f bld/rcc/qrc_resources.cpp
rm -f bld/ui/ui_mainwindow.h
rm -f bld/obj/cuda_mtrnn.o bld/obj/cuda_som.o bld/obj/cuda_esn.o bld/obj/cuda_image_processing.o bld/obj/main.o bld/obj/mainwindow.o bld/obj/splashscreen.o bld/obj/yarp.o bld/obj/modi.o bld/obj/plots.o bld/obj/iCub_control.o bld/obj/custom_som.o bld/obj/speech.o bld/obj/xml.o bld/obj/development.o bld/obj/moc_mainwindow.o bld/obj/moc_splashscreen.o bld/obj/qrc_resources.o
rm -f *~ core *.core
make: Leaving directory `/home/mpeniak/Desktop/Aquila'
The process "/usr/bin/make" exited normally.
Configuration unchanged, skipping qmake step.
Starting: "/usr/bin/make" -w
/usr/bin/uic-qt4 ui/mainwindow.ui -o bld/ui/ui_mainwindow.h
Warning: name frame is already used
/usr/local/cuda/bin/nvcc -DQT_XML_LIB -DQT_OPENGL_LIB -DQT_GUI_LIB -DQT_CORE_LIB -DQT_SHARED -I/usr/share/qt4/mkspecs/linux-g++ -I. -I/usr/include/qt4/QtCore -I/usr/include/qt4/QtGui -I/usr/include/qt4/QtOpenGL -I/usr/include/qt4/QtXml -I/usr/include/qt4 -Isrc -I../../Dev/Lib/yarp2/src/libYARP_dev/include -I../../Dev/Lib/yarp2/src/libYARP_OS/include -I../../Dev/Lib/yarp2/src/libYARP_sig/include -I../../Dev/Lib/yarp2/src/libYARP_math/include -I../../Dev/Lib/yarp2/generated_include -I../../Dev/Lib/qwtplot3d/include -I../../Dev/Lib/qwt-5.2.1/src -I/usr/local/cuda/include -I../../NVIDIA_GPU_Computing_SDK/shared/inc -I/usr/X11R6/include -Ibld/moc -Ibld/ui -c -use_fast_math -o bld/obj/cuda_mtrnn.o src/cuda_mtrnn.cu
Segmentation fault
make: *** [bld/obj/cuda_mtrnn.o] Error 139
The process "/usr/bin/make" exited with code %2.
Error while building project Aquila (target: Desktop)
When executing build step 'Make'
So it seems as if the compilation crashes right after it has to do anything with CUDA files.
Any help very much appreciated,
Martin Peniak
