Serial Console didn't work
I have connected to serial console with USB to Serial in Windows,
when I open up the Putty and Connect to COM14 in windows, I see the boot output log in putty
here is my boot output:
[0000.326] *** Booting BFS0.
[0000.328] Initialize FailControl
[0000.331] Read PT from (0:3)
[0000.377] Csd NumOfBlocks=0
[0000.413] PT crc32 and magic check passed.
[0000.417] Using BFS PT to query partitions
[0000.421] PT: Partition LNX NOT found !
[0000.425] *** Booting KFS0.
[0000.428] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.434] Rail not supported
[0000.436] BoardID = 2180, SKU = 0x3e8
[0000.440] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.445] Read GPT from (0:3)
[0000.453] Using GPT Primary to query partitions
[0000.458] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.465] Loading Tboot-CPU binary
[0000.471] Verifying TBC in OdmNonSecureSBK mode
[0000.483] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.490] Bootloader downloaded successfully.
[0000.494] Downloaded Tboot-CPU binary to 0xa0000258
[0000.499] MAX77620_GPIO1 Configured.
[0000.502] MAX77620_GPIO5 Configured.
[0000.506] CPU power rail is up
[0000.509] CPU clock enabled
[0000.512] Performing RAM repair
[0000.515] Updating A64 Warmreset Address to 0xa00002e9
[0000.520] BoardID = 2180, SKU = 0x3e8
[0000.524] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.530] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.536] Loading NvTbootBootloaderDTB
[0000.556] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.697] Bootloader DTB Load Address: 0x83000000
[0000.702] BoardID = 2180, SKU = 0x3e8
[0000.705] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.711] Loading NvTbootKernelDTB
[0000.728] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.868] Kernel DTB Load Address: 0x83100000
[0000.873] BoardID = 2180, SKU = 0x3e8
[0000.876] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.882] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.889] Loading cboot binary
[0000.908] Verifying EBT in OdmNonSecureSBK mode
[0000.949] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.956] Bootloader downloaded successfully.
[0000.960] BoardID = 2180, SKU = 0x3e8
[0000.964] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.970] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.976] PT: Partition NCT NOT found !
[0000.980] Warning: Find Partition via PT Failed
[0000.984] Next binary entry address: 0x92c00258
[0000.989] BoardId: 2180
[0000.993] BoardID = 2180, SKU = 0x3e8
[0000.997] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0001.003] NvTbootFailControlDoFailover: No failover; Continuing ...
[0001.018] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0001.164] /bpmp deleted
[0001.166] SC7EntryFw header found loaded at 0xff700000
[0001.730] OVR2 PMIC
[0001.732] Bpmp FW successfully loaded
[0001.736] BoardID = 2180, SKU = 0x3e8
[0001.739] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0001.745] NvTbootFailControlDoFailover: No failover; Continuing ...
[0001.752] WB0 init successfully at 0xff780000
[0001.757] Verifying NvTbootWb0 in OdmNonSecureSBK mode
[0001.762] Set NvDecSticky Bits
[0001.765] GSC2 address ff53fffc value c0edbbcc
[0001.771] GSC MC Settings done
[0001.774] BoardID = 2180, SKU = 0x3e8
[0001.778] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0001.784] TOS Image length 53680
[0001.787]  Monitor size 53680
[0001.790]  OS size 0
[0001.796] Secure Os AES-CMAC Verification Success!
[0001.800] TOS image cipher info: plaintext
[0001.804] Loading and Validation of Secure OS Successful
[0001.820] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.825] NvTbootPackSdramParams: start.
[0001.830] NvTbootPackSdramParams: done.
[0001.834] Tegraboot started after 161757 us
[0001.838] Basic modules init took 872010 us
[0001.842] Sec Bootdevice Read Time = 68 ms, Read Size = 4026 KB
[0001.847] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.853] Next stage binary read took 9021 us
[0001.857] Carveout took -27601 us
[0001.860] CPU initialization took 862845 us
[0001.864] Total time taken by TegraBoot 1716275 us
[0001.869] Starting CPU & Halting co-processor
64NOTICE:  BL31: v1.3(release):f9bf1e1
NOTICE:  BL31: Built : 21:16:40, Jun  8 2023
ERROR:   Error initializing runtime service trusty_fast
[0001.993] RamCode = 0
[0002.032] LPDDR4 Training: found 20 entries (10 nominal, 10 derated)
[0002.038] EMC Training (SRC-freq: 204000; DST-freq: 408000)
[0002.044] EMC Training Successful
[0002.047] EMC Training (SRC-freq: 204000; DST-freq: 665600)
[0002.053] EMC Training Successful
[0002.056] EMC Training (SRC-freq: 204000; DST-freq: 800000)
[0002.068] EMC Training Successful
[0002.071] EMC Training (SRC-freq: 204000; DST-freq: 1065600)
[0002.094] EMC Training Successful
[0002.097] EMC Training (SRC-freq: 204000; DST-freq: 1331200)
[0002.118] EMC Training Successful
[0002.121] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0002.141] EMC Training Successful
[0002.144] EMC Training (SRC-freq: 204000; DST-freq: 408000)
[0002.150] EMC Training Successful
[0002.153] EMC Training (SRC-freq: 204000; DST-freq: 665600)
[0002.159] EMC Training Successful
[0002.162] EMC Training (SRC-freq: 204000; DST-freq: 800000)
[0002.173] EMC Training Successful
[0002.176] EMC Training (SRC-freq: 204000; DST-freq: 1065600)
[0002.199] EMC Training Successful
[0002.202] EMC Training (SRC-freq: 204000; DST-freq: 1331200)
[0002.224] EMC Training Successful
[0002.227] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0002.246] EMC Training Successful
[0002.249] Switching to 800000 KHz Success
[0002.317] RamCode = 0
[0002.322] DT Write: emc-table@40800 succeeded
[0002.330] DT Write: emc-table@68000 succeeded
[0002.338] DT Write: emc-table@102000 succeeded
[0002.345] DT Write: emc-table@204000 succeeded
[0002.353] DT Write: emc-table@408000 succeeded
[0002.361] DT Write: emc-table@665600 succeeded
[0002.369] DT Write: emc-table@800000 succeeded
[0002.376] DT Write: emc-table@1065600 succeeded
[0002.384] DT Write: emc-table@1331200 succeeded
[0002.392] DT Write: emc-table@1600000 succeeded
[0002.400] DT Write: emc-table-derated@40800 succeeded
[0002.408] DT Write: emc-table-derated@68000 succeeded
[0002.417] DT Write: emc-table-derated@102000 succeeded
[0002.425] DT Write: emc-table-derated@204000 succeeded
[0002.434] DT Write: emc-table-derated@408000 succeeded
[0002.442] DT Write: emc-table-derated@665600 succeeded
[0002.451] DT Write: emc-table-derated@800000 succeeded
[0002.459] DT Write: emc-table-derated@1065600 succeeded
[0002.468] DT Write: emc-table-derated@1331200 succeeded
[0002.476] DT Write: emc-table-derated@1600000 succeeded
[0002.481] LPDDR4 Training: Write DT: Number of tables = 20
[0002.548]
[0002.549] Debug Init done
[0002.551] Marked DTB cacheable
[0002.554] Bootloader DTB loaded at 0x83000000
[0002.559] Marked DTB cacheable
[0002.561] Kernel DTB loaded at 0x83100000
[0002.565] DeviceTree Init done
[0002.582] Pinmux applied successfully
[0002.587] gicd_base: 0x50041000
[0002.591] gicc_base: 0x50042000
[0002.594] Interrupts Init done
[0002.599] Using base:0x60005090 & irq:208 for tick-timer
[0002.604] Using base:0x60005098 for delay-timer
[0002.609] platform_init_timer: DONE
[0002.612] Timer(tick) Init done
[0002.617] osc freq = 38400 khz
[0002.622]
[0002.623] Welcome to L4T Cboot
[0002.626]
[0002.627] Cboot Version: 00.00.2018.01-t210-acb23272
[0002.632] calling constructors
[0002.635] initializing heap
[0002.638] initializing threads
[0002.641] initializing timers
[0002.644] creating bootstrap completion thread
[0002.648] top of bootstrap2()
[0002.651] CPU: ARM Cortex A57
[0002.654] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0002.658] initializing platform
[0002.752] Config for emmc ddr50 mode completed
[0002.756] sdmmc bdev is already initialized
[0002.760] Enable APE clock
[0002.763] Un-powergate APE partition
[0002.767] of_register: registering tegra_udc to of_hal
[0002.772] of_register: registering inv20628-driver to of_hal
[0002.777] of_register: registering ads1015-driver to of_hal
[0002.783] of_register: registering lp8557-bl-driver to of_hal
[0002.789] of_register: registering bq2419x_charger to of_hal
[0002.794] of_register: registering bq27441_fuel_gauge to of_hal
[0002.810] gpio framework initialized
[0002.813] of_register: registering tca9539_gpio to of_hal
[0002.819] of_register: registering tca9539_gpio to of_hal
[0002.824] of_register: registering i2c_bus_driver to of_hal
[0002.830] of_register: registering i2c_bus_driver to of_hal
[0002.835] of_register: registering i2c_bus_driver to of_hal
[0002.841] pmic framework initialized
[0002.844] of_register: registering max77620_pmic to of_hal
[0002.850] regulator framework initialized
[0002.854] of_register: registering tps65132_bl_driver to of_hal
[0002.860] initializing target
[0002.867] gpio_driver_register: register 'tegra_gpio_driver' driver
[0002.876] board ID = 884, board SKU = 3E8
[0002.884] fixed regulator driver initialized
[0002.937] initializing OF layer
[0002.940] NCK carveout not present
[0002.943] Skipping dts_overrides
[0002.948] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.973] I2C Bus Init done
[0002.976] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.988] I2C Bus Init done
[0002.991] of_children_init: Ops found for compatible string ti,tca9539
[0003.003] tca9539_init: i2c bus: 2, slave addr: 0xe8
[0003.008] I2C slave not started
[0003.011] I2C write failed
[0003.013] i2c write failed
[0003.016] Slave: 0xe8, Register 0x4 Instance 2, Buffer Size: 0
[0003.022] tca9539_device_init: failed to write polar reg
[0003.027] tca9539_init: failed to init device!
[0003.032] of_children_init: Ops found for compatible string ti,tca9539
[0003.043] tca9539_init: i2c bus: 2, slave addr: 0xee
[0003.048] I2C slave not started
[0003.051] I2C write failed
[0003.054] i2c write failed
[0003.057] Slave: 0xee, Register 0x4 Instance 2, Buffer Size: 0
[0003.062] tca9539_device_init: failed to write polar reg
[0003.068] tca9539_init: failed to init device!
[0003.072] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0003.085] I2C Bus Init done
[0003.087] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0003.100] I2C Bus Init done
[0003.103] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0003.115] I2C Bus Init done
[0003.118] of_children_init: Ops found for compatible string maxim,max77620
[0003.131] max77620_init using irq 118
[0003.136] register 'maxim,max77620' pmic
[0003.140] gpio_driver_register: register 'max77620-gpio' driver
[0003.146] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0003.159] I2C Bus Init done
[0003.164] NCK carveout not present
[0003.179] Find /i2c@7000c000's alias i2c0
[0003.183] get eeprom at 1-a2, size 256, type 0
[0003.188] get eeprom at 1-ae, size 256, type 0
[0003.200] Find /i2c@7000c400's alias i2c1
[0003.204] get eeprom at 2-a0, size 256, type 0
[0003.217] Find /i2c@7000c500's alias i2c2
[0003.221] get eeprom at 3-a0, size 256, type 0
[0003.225] get eeprom at 3-ae, size 256, type 0
[0003.235] Find /host1x/i2c@546c0000's alias i2c6
[0003.240] get eeprom at 7-a8, size 256, type 0
[0003.244] pm_ids_update: Updating 1,a2, size 256, type 0
[0003.250] I2C slave not started
[0003.253] I2C write failed
[0003.255] Writing offset failed
[0003.258] eeprom_init: EEPROM read failed
[0003.262] pm_ids_update: eeprom init failed
[0003.266] pm_ids_update: Updating 1,ae, size 256, type 0
[0003.272] I2C slave not started
[0003.275] I2C write failed
[0003.277] Writing offset failed
[0003.280] eeprom_init: EEPROM read failed
[0003.284] pm_ids_update: eeprom init failed
[0003.288] pm_ids_update: Updating 2,a0, size 256, type 0
[0003.294] I2C slave not started
[0003.297] I2C write failed
[0003.299] Writing offset failed
[0003.302] eeprom_init: EEPROM read failed
[0003.306] pm_ids_update: eeprom init failed
[0003.310] pm_ids_update: Updating 3,a0, size 256, type 0
[0003.341] pm_ids_update: The pm board id is 2180-1000-100
[0003.348] Adding plugin-manager/ids/2180-1000-100=/i2c@7000c500:module@0x50
[0003.356] pm_ids_update: pm id update successful
[0003.361] pm_ids_update: Updating 3,ae, size 256, type 0
[0003.366] I2C slave not started
[0003.369] I2C write failed
[0003.372] Writing offset failed
[0003.375] eeprom_init: EEPROM read failed
[0003.379] pm_ids_update: eeprom init failed
[0003.383] pm_ids_update: Updating 7,a8, size 256, type 0
[0003.390] GPIO driver for phandle 0xf3 could not be found
[0003.395] I2C slave not started
[0003.398] I2C write failed
[0003.401] Writing offset failed
[0003.404] eeprom_init: EEPROM read failed
[0003.408] pm_ids_update: eeprom init failed
[0003.413] GPIO driver for phandle 0xf3 could not be found
[0003.446] updating /chosen/nvidia,wifi-mac node 00:04:4b:5a:e0:21
[0003.454] updating /chosen/nvidia,bluetooth-mac node 00:04:4b:5a:e0:22
[0003.464] updating /chosen/nvidia,ethernet-mac node 00:04:4b:5a:e0:23
[0003.470] Plugin Manager: Parse ODM data 0x000a4000
[0003.483] shim_cmdline_install: /chosen/bootargs:
[0003.501] Find /i2c@7000c000's alias i2c0
[0003.505] get eeprom at 1-a2, size 256, type 0
[0003.509] get eeprom at 1-ae, size 256, type 0
[0003.522] Find /i2c@7000c400's alias i2c1
[0003.526] get eeprom at 2-a0, size 256, type 0
[0003.539] Find /i2c@7000c500's alias i2c2
[0003.542] get eeprom at 3-a0, size 256, type 0
[0003.547] get eeprom at 3-ae, size 256, type 0
[0003.557] Find /host1x/i2c@546c0000's alias i2c6
[0003.561] get eeprom at 7-a8, size 256, type 0
[0003.566] pm_ids_update: Updating 1,a2, size 256, type 0
[0003.571] I2C slave not started
[0003.574] I2C write failed
[0003.577] Writing offset failed
[0003.580] eeprom_init: EEPROM read failed
[0003.584] pm_ids_update: eeprom init failed
[0003.588] pm_ids_update: Updating 1,ae, size 256, type 0
[0003.593] I2C slave not started
[0003.596] I2C write failed
[0003.599] Writing offset failed
[0003.602] eeprom_init: EEPROM read failed
[0003.606] pm_ids_update: eeprom init failed
[0003.610] pm_ids_update: Updating 2,a0, size 256, type 0
[0003.615] I2C slave not started
[0003.618] I2C write failed
[0003.621] Writing offset failed
[0003.624] eeprom_init: EEPROM read failed
[0003.628] pm_ids_update: eeprom init failed
[0003.632] pm_ids_update: Updating 3,a0, size 256, type 0
[0003.662] pm_ids_update: The pm board id is 2180-1000-100
[0003.669] Adding plugin-manager/ids/2180-1000-100=/i2c@7000c500:module@0x50
[0003.676] pm_ids_update: pm id update successful
[0003.681] pm_ids_update: Updating 3,ae, size 256, type 0
[0003.686] I2C slave not started
[0003.689] I2C write failed
[0003.692] Writing offset failed
[0003.695] eeprom_init: EEPROM read failed
[0003.699] pm_ids_update: eeprom init failed
[0003.703] pm_ids_update: Updating 7,a8, size 256, type 0
[0003.710] GPIO driver for phandle 0xf3 could not be found
[0003.715] I2C slave not started
[0003.718] I2C write failed
[0003.721] Writing offset failed
[0003.724] eeprom_init: EEPROM read failed
[0003.728] pm_ids_update: eeprom init failed
[0003.733] GPIO driver for phandle 0xf3 could not be found
[0003.765] Add serial number:0321516060175 as DT property
[0003.776] Applying platform configs
[0003.785] platform-init is not present. Skipping
[0003.790] calling apps_init()
[0003.809] Found 22 GPT partitions in "sdmmc3_user"
[0003.813] Proceeding to Cold Boot
[0003.816] starting app android_boot_app
[0003.820] Device state: unlocked
[0003.823] display console init
[0003.831] status of dsi node is not okay
[0003.839] enabling 'vdd-hdmi' regulator
[0003.843] GPIO driver for phandle 0xf4 could not be found
[0003.870] DT entry for leds-pwm not found
[0003.874] hdmi cable not connected
[0003.877] is_hdmi_needed: HDMI not connected, returning false
[0003.883] hdmi is not connected
[0003.886] display_console_init: no valid display out_type
[0003.896] Gpio keyboard init success
[0003.943] found decompressor handler: lz4-legacy
[0003.956] decompressing blob (type 1)...
[0003.992] display_resolution: No display init
[0003.996] Failed to retrieve display resolution
[0004.001] Could not load/initialize BMP blob...ignoring
[0004.006] -------> se_aes_verify_sbk_clear: 747
[0004.010] se_aes_verify_sbk_clear: Error
[0004.014] SE operation failed
[0004.017] bl_battery_charging: connected to external power supply
[0004.028] fastboot: usb cable is not connected
[0004.032] display_console_ioctl: No display init
[0004.037] switch_backlight failed
[0004.046] device_query_partition_size: failed to open partition sdmmc3_user:MSC !
[0004.053] MSC Partition not found
[0004.075] blob_init: USP partition does not have valid Blob
[0004.080] kfs_getpartname: name = LNX
[0004.084] Loading kernel from LNX
[0004.145] load kernel from storage
[0004.155] decompressor handler not found
[0004.190] Successfully loaded kernel and ramdisk images
[0004.195] board ID = 884, board SKU = 3E8
[0004.201] display_resolution: No display init
[0004.205] Failed to retrieve display resolution
[0004.210] bmp blob is not loaded and initialized
[0004.214] Failed to display boot-logo
[0004.218] NCK carveout not present
[0004.221] Skipping dts_overrides
[0004.224] NCK carveout not present
[0004.240] Find /i2c@7000c000's alias i2c0
[0004.244] get eeprom at 1-a2, size 256, type 0
[0004.248] get eeprom at 1-ae, size 256, type 0
[0004.261] Find /i2c@7000c400's alias i2c1
[0004.265] get eeprom at 2-a0, size 256, type 0
[0004.278] Find /i2c@7000c500's alias i2c2
[0004.282] get eeprom at 3-a0, size 256, type 0
[0004.286] get eeprom at 3-ae, size 256, type 0
[0004.296] Find /host1x/i2c@546c0000's alias i2c6
[0004.301] get eeprom at 7-a8, size 256, type 0
[0004.305] pm_ids_update: Updating 1,a2, size 256, type 0
[0004.310] I2C slave not started
[0004.313] I2C write failed
[0004.316] Writing offset failed
[0004.319] eeprom_init: EEPROM read failed
[0004.323] pm_ids_update: eeprom init failed
[0004.327] pm_ids_update: Updating 1,ae, size 256, type 0
[0004.332] I2C slave not started
[0004.335] I2C write failed
[0004.338] Writing offset failed
[0004.341] eeprom_init: EEPROM read failed
[0004.345] pm_ids_update: eeprom init failed
[0004.349] pm_ids_update: Updating 2,a0, size 256, type 0
[0004.354] I2C slave not started
[0004.357] I2C write failed
[0004.360] Writing offset failed
[0004.363] eeprom_init: EEPROM read failed
[0004.367] pm_ids_update: eeprom init failed
[0004.371] pm_ids_update: Updating 3,a0, size 256, type 0
[0004.401] pm_ids_update: The pm board id is 2180-1000-100
[0004.409] Adding plugin-manager/ids/2180-1000-100=/i2c@7000c500:module@0x50
[0004.417] pm_ids_update: pm id update successful
[0004.422] pm_ids_update: Updating 3,ae, size 256, type 0
[0004.427] I2C slave not started
[0004.430] I2C write failed
[0004.433] Writing offset failed
[0004.436] eeprom_init: EEPROM read failed
[0004.440] pm_ids_update: eeprom init failed
[0004.444] pm_ids_update: Updating 7,a8, size 256, type 0
[0004.450] GPIO driver for phandle 0xf3 could not be found
[0004.456] I2C slave not started
[0004.459] I2C write failed
[0004.461] Writing offset failed
[0004.464] eeprom_init: EEPROM read failed
[0004.468] pm_ids_update: eeprom init failed
[0004.474] GPIO driver for phandle 0xf3 could not be found
[0004.507] updating /chosen/nvidia,wifi-mac node 00:04:4b:5a:e0:21
[0004.515] updating /chosen/nvidia,bluetooth-mac node 00:04:4b:5a:e0:22
[0004.524] updating /chosen/nvidia,ethernet-mac node 00:04:4b:5a:e0:23
[0004.531] Plugin Manager: Parse ODM data 0x000a4000
[0004.544] shim_cmdline_install: /chosen/bootargs:
[0004.549] Add serial number:0321516060175 as DT property
[0004.562] "bpmp" doesn't exist, creating
[0004.569] Updated bpmp info to DTB
[0004.575] Updated initrd info to DTB
[0004.579] "proc-board" doesn't exist, creating
[0004.585] Updated board info to DTB
[0004.588] "pmu-board" doesn't exist, creating
[0004.594] Updated board info to DTB
[0004.597] "display-board" doesn't exist, creating
[0004.604] Updated board info to DTB
[0004.607] "reset" doesn't exist, creating
[0004.612] Updated reset info to DTB
[0004.615] display_console_ioctl: No display init
[0004.619] display_console_ioctl: No display init
[0004.624] display_console_ioctl: No display init
[0004.629] Cmdline: tegraid=21.1.2.0.0 ddr_die=2048M@2048M ddr_die=2048M@4096M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 gpt
[0004.665] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1 nv-auto-config
[0004.682] Updated bootarg info to DTB
[0004.686] Adding uuid 00000001640d06c82400000004ff01c0 to DT
[0004.692] Adding eks info 0 to DT
[0004.699] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0004.705] Updated memory info to DTB
[0004.717] set vdd_core voltage to 1075 mv
[0004.721] setting 'vdd-core' regulator to 1075000 micro volts
[0004.727] Found secure-pmc; disable BPMP
U-Boot 2020.04-g4335beb (Jun 08 2023 - 21:16:44 -0700)
SoC: tegra210
Model: NVIDIA P2371-2180
Board: NVIDIA P2371-2180
DRAM:  4 GiB
MMC:   sdhci@700b0000: 1, sdhci@700b0600: 0
Loading Environment from MMC... *** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
579 bytes read in 30 ms (18.6 KiB/s)
L4T boot options
1:      SD Card
2:      Internal EMMC
Enter choice: 1:        SD Card
Retrieving file: /boot/initrd
7159654 bytes read in 330 ms (20.7 MiB/s)
Retrieving file: /boot/Image
34707464 bytes read in 1522 ms (21.7 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=2048M@2048M ddr_die=2048M@4096M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 gpt  root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1 nv-auto-config quiet root=/dev/mmcblk2p1 rw rootwait rootfstype=ext4 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1 nv-auto-config
## Flattened Device Tree blob at 83100000
   Booting using the fdt blob at 0x83100000
ERROR: reserving fdt memory region failed (addr=83410000 size=10000)
ERROR: reserving fdt memory region failed (addr=83400000 size=10000)
ERROR: reserving fdt memory region failed (addr=0 size=0)
   Using Device Tree in place at 0000000083100000, end 00000000831bbfff
Starting kernel ...
[    0.545836] pca953x 1-0074: failed reading register
[    0.546494] pca953x 1-0077: failed reading register
[    1.045761] tegradc tegradc.1: dc_hdmi_hotplug_init: couldn't get regulator vdd_hdmi_5v0, -517
[    1.268454] FAN: coudln't get the regulator
[    1.296810] ina3221x 1-0042: ina3221 reset failure status: 0xffffff87
[    1.303869] ina3221x 1-0043: ina3221 reset failure status: 0xffffff87
[    2.496999] cgroup: cgroup2: unknown option "nsdelegate"
[    3.982522] random: systemd: uninitialized urandom read (16 bytes read)
[    4.062849] random: systemd: uninitialized urandom read (16 bytes read)
[    4.069624] random: systemd: uninitialized urandom read (16 bytes read)
[    4.466764] random: crng init done
[    4.470168] random: 144 urandom warning(s) missed due to ratelimiting
[    6.118611] using random self ethernet address
[    6.123102] using random host ethernet address
[    9.660613] using random self ethernet address
[    9.665118] using random host ethernet address
[   17.878931] Bridge firewalling registered
Ubuntu 18.04.6 LTS ubuntu ttyS0
[   22.258977] tegra-i2c 7000c000.i2c: no acknowledge from address 0x50
[   22.265756] tegra-i2c 7000c400.i2c: no acknowledge from address 0x50
▒>>>▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒_▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒[  666.630072] watchdog: watchdog0: watchdog did not stop!
[  666.640771] systemd-shutdow: 47 output lines suppressed due to ratelimiting
[  667.113284] reboot: Restarting system
[0000.196] [L4T TegraBoot] (version 00.00.2018.01-l4t-b1625959)
[0000.202] Processing in cold boot mode Bootloader 2
[0000.206] A02 Bootrom Patch rev = 63
[0000.210] Power-up reason: software reset
[0000.213] No Battery Present
[0000.216] pmic max77620 reset reason
[0000.219] pmic max77620 NVERC : 0x0
[0000.223] RamCode = 0
[0000.225] Platform has Ddr4 type ram
[0000.228] max77620 disabling SD1 Remote Sense
[0000.232] Setting Ddr voltage to 1125mv
[0000.236] Serial Number of Pmic Max77663: 0x1f3
[0000.244] Entering ramdump check
[0000.247] Get RamDumpCarveOut = 0x0
[0000.250] RamDumpCarveOut=0x0,  RamDumperFlag=0xe59ff3f8
[0000.255] Last reboot was clean, booting normally!
[0000.260] Sdram initialization is successful
[0000.264] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.270] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.276] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.282] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.288] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.293] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.299] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.305] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.321] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.327] Platform-DebugCarveout: 0
[0000.330] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.336] Non secure mode, and RB not enabled.
[0000.340] *** Booting BFS0.
[0000.343] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.349] Read PT from (0:3)
[0000.394] Csd NumOfBlocks=0
[0000.431] PT crc32 and magic check passed.
[0000.435] Using BFS PT to query partitions
[0000.439] PT: Partition LNX NOT found !
[0000.443] *** Booting KFS0.
[0000.445] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.451] Rail not supported
[0000.454] BoardID = 2180, SKU = 0x3e8
[0000.457] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.463] Read GPT from (0:3)
[0000.471] Using GPT Primary to query partitions
[0000.475] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.482] Loading Tboot-CPU binary
[0000.489] Verifying TBC in OdmNonSecureSBK mode
[0000.500] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.507] Bootloader downloaded successfully.
[0000.511] Downloaded Tboot-CPU binary to 0xa0000258
[0000.516] MAX77620_GPIO1 Configured.
[0000.520] MAX77620_GPIO5 Configured.
[0000.523] CPU power rail is up
[0000.526] CPU clock enabled
[0000.530] Performing RAM repair
[0000.533] Updating A64 Warmreset Address to 0xa00002e9
[0000.538] BoardID = 2180, SKU = 0x3e8
[0000.541] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.547] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.554] Loading NvTbootBootloaderDTB
[0000.574] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.715] Bootloader DTB Load Address: 0x83000000
[0000.719] BoardID = 2180, SKU = 0x3e8
[0000.723] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.728] Loading NvTbootKernelDTB
[0000.745] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.886] Kernel DTB Load Address: 0x83100000
[0000.890] BoardID = 2180, SKU = 0x3e8
[0000.894] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.900] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.907] Loading cboot binary
[0000.925] Verifying EBT in OdmNonSecureSBK mode
[0000.967] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.974] Bootloader downloaded successfully.
[0000.978] BoardID = 2180, SKU = 0x3e8
[0000.982] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.987] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.994] PT: Partition NCT NOT found !
[0000.997] Warning: Find Partition via PT Failed
[0001.002] Next binary entry address: 0x92c00258
[0001.006] BoardId: 2180
[0001.011] BoardID = 2180, SKU = 0x3e8
[0001.015] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0001.021] NvTbootFailControlDoFailover: No failover; Continuing ...
[0001.036] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0001.182] /bpmp deleted
[0001.184] SC7EntryFw header found loaded at 0xff700000
[0001.748] OVR2 PMIC
[0001.750] Bpmp FW successfully loaded
[0001.753] BoardID = 2180, SKU = 0x3e8
[0001.757] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0001.763] NvTbootFailControlDoFailover: No failover; Continuing ...
[0001.770] WB0 init successfully at 0xff780000
[0001.774] Verifying NvTbootWb0 in OdmNonSecureSBK mode
[0001.779] Set NvDecSticky Bits
[0001.783] GSC2 address ff53fffc value c0edbbcc
[0001.789] GSC MC Settings done
[0001.792] BoardID = 2180, SKU = 0x3e8
[0001.795] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0001.802] TOS Image length 53680
[0001.805]  Monitor size 53680
[0001.808]  OS size 0
[0001.813] Secure Os AES-CMAC Verification Success!
[0001.818] TOS image cipher info: plaintext
[0001.822] Loading and Validation of Secure OS Successful
[0001.838] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.842] NvTbootPackSdramParams: start.
[0001.847] NvTbootPackSdramParams: done.
[0001.851] Tegraboot started after 176243 us
[0001.855] Basic modules init took 875590 us
[0001.859] Sec Bootdevice Read Time = 68 ms, Read Size = 4026 KB
[0001.865] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.871] Next stage binary read took 9021 us
[0001.875] Carveout took -27611 us
[0001.878] CPU initialization took 862861 us
[0001.882] Total time taken by TegraBoot 1719861 us
[0001.887] Starting CPU & Halting co-processor
[0002.011] RamCode = 0
[0002.050] LPDDR4 Training: found 20 entries (10 nominal, 10 derated)
[0002.056] EMC Training (SRC-freq: 204000; DST-freq: 408000)
[0002.062] EMC Training Successful
[0002.065] EMC Training (SRC-freq: 204000; DST-freq: 665600)
[0002.071] EMC Training Successful
[0002.074] EMC Training (SRC-freq: 204000; DST-freq: 800000)
[0002.085] EMC Training Successful
[0002.088] EMC Training (SRC-freq: 204000; DST-freq: 1065600)
[0002.111] EMC Training Successful
[0002.114] EMC Training (SRC-freq: 204000; DST-freq: 1331200)
[0002.136] EMC Training Successful
[0002.139] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0002.158] EMC Training Successful
[0002.161] EMC Training (SRC-freq: 204000; DST-freq: 408000)
[0002.167] EMC Training Successful
[0002.171] EMC Training (SRC-freq: 204000; DST-freq: 665600)
[0002.176] EMC Training Successful
[0002.179] EMC Training (SRC-freq: 204000; DST-freq: 800000)
[0002.191] EMC Training Successful
[0002.194] EMC Training (SRC-freq: 204000; DST-freq: 1065600)
[0002.217] EMC Training Successful
[0002.220] EMC Training (SRC-freq: 204000; DST-freq: 1331200)
[0002.241] EMC Training Successful
[0002.244] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0002.264] EMC Training Successful
[0002.267] Switching to 800000 KHz Success
[0002.334] RamCode = 0
[0002.340] DT Write: emc-table@40800 succeeded
[0002.348] DT Write: emc-table@68000 succeeded
[0002.355] DT Write: emc-table@102000 succeeded
[0002.363] DT Write: emc-table@204000 succeeded
[0002.371] DT Write: emc-table@408000 succeeded
[0002.379] DT Write: emc-table@665600 succeeded
[0002.386] DT Write: emc-table@800000 succeeded
[0002.394] DT Write: emc-table@1065600 succeeded
[0002.402] DT Write: emc-table@1331200 succeeded
[0002.410] DT Write: emc-table@1600000 succeeded
[0002.418] DT Write: emc-table-derated@40800 succeeded
[0002.426] DT Write: emc-table-derated@68000 succeeded
[0002.434] DT Write: emc-table-derated@102000 succeeded
[0002.443] DT Write: emc-table-derated@204000 succeeded
[0002.451] DT Write: emc-table-derated@408000 succeeded
[0002.460] DT Write: emc-table-derated@665600 succeeded
[0002.468] DT Write: emc-table-derated@800000 succeeded
[0002.477] DT Write: emc-table-derated@1065600 succeeded
[0002.485] DT Write: emc-table-derated@1331200 succeeded
[0002.494] DT Write: emc-table-derated@1600000 succeeded
[0002.499] LPDDR4 Training: Write DT: Number of tables = 20
[0002.566]
[0002.567] Debug Init done
[0002.569] Marked DTB cacheable
[0002.572] Bootloader DTB loaded at 0x83000000
[0002.577] Marked DTB cacheable
[0002.580] Kernel DTB loaded at 0x83100000
[0002.584] DeviceTree Init done
[0002.600] Pinmux applied successfully
[0002.605] gicd_base: 0x50041000
[0002.609] gicc_base: 0x50042000
[0002.612] Interrupts Init done
[0002.617] Using base:0x60005090 & irq:208 for tick-timer
[0002.623] Using base:0x60005098 for delay-timer
[0002.627] platform_init_timer: DONE
[0002.630] Timer(tick) Init done
[0002.635] osc freq = 38400 khz
[0002.640]
[0002.641] Welcome to L4T Cboot
[0002.644]
[0002.645] Cboot Version: 00.00.2018.01-t210-acb23272
[0002.650] calling constructors
[0002.653] initializing heap
[0002.656] initializing threads
[0002.659] initializing timers
[0002.662] creating bootstrap completion thread
[0002.666] top of bootstrap2()
[0002.669] CPU: ARM Cortex A57
[0002.672] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0002.677] initializing platform
[0002.770] Config for emmc ddr50 mode completed
[0002.774] sdmmc bdev is already initialized
[0002.779] Enable APE clock
[0002.781] Un-powergate APE partition
[0002.785] of_register: registering tegra_udc to of_hal
[0002.790] of_register: registering inv20628-driver to of_hal
[0002.795] of_register: registering ads1015-driver to of_hal
[0002.801] of_register: registering lp8557-bl-driver to of_hal
[0002.807] of_register: registering bq2419x_charger to of_hal
[0002.812] of_register: registering bq27441_fuel_gauge to of_hal
[0002.828] gpio framework initialized
[0002.832] of_register: registering tca9539_gpio to of_hal
[0002.837] of_register: registering tca9539_gpio to of_hal
[0002.842] of_register: registering i2c_bus_driver to of_hal
[0002.848] of_register: registering i2c_bus_driver to of_hal
[0002.853] of_register: registering i2c_bus_driver to of_hal
[0002.859] pmic framework initialized
[0002.862] of_register: registering max77620_pmic to of_hal
[0002.868] regulator framework initialized
[0002.872] of_register: registering tps65132_bl_driver to of_hal
[0002.878] initializing target
[0002.885] gpio_driver_register: register 'tegra_gpio_driver' driver
[0002.894] board ID = 884, board SKU = 3E8
[0002.902] fixed regulator driver initialized
[0002.957] initializing OF layer
[0002.960] NCK carveout not present
[0002.964] Skipping dts_overrides
[0002.968] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.994] I2C Bus Init done
[0002.996] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0003.009] I2C Bus Init done
[0003.011] of_children_init: Ops found for compatible string ti,tca9539
[0003.023] tca9539_init: i2c bus: 2, slave addr: 0xe8
[0003.028] I2C slave not started
[0003.031] I2C write failed
[0003.034] i2c write failed
[0003.036] Slave: 0xe8, Register 0x4 Instance 2, Buffer Size: 0
[0003.042] tca9539_device_init: failed to write polar reg
[0003.047] tca9539_init: failed to init device!
[0003.052] of_children_init: Ops found for compatible string ti,tca9539
[0003.064] tca9539_init: i2c bus: 2, slave addr: 0xee
[0003.069] I2C slave not started
[0003.072] I2C write failed
[0003.074] i2c write failed
[0003.077] Slave: 0xee, Register 0x4 Instance 2, Buffer Size: 0
[0003.083] tca9539_device_init: failed to write polar reg
[0003.088] tca9539_init: failed to init device!
[0003.092] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0003.105] I2C Bus Init done
[0003.108] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0003.120] I2C Bus Init done
[0003.123] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0003.136] I2C Bus Init done
[0003.138] of_children_init: Ops found for compatible string maxim,max77620
[0003.151] max77620_init using irq 118
[0003.156] register 'maxim,max77620' pmic
[0003.161] gpio_driver_register: register 'max77620-gpio' driver
[0003.167] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0003.179] I2C Bus Init done
[0003.184] NCK carveout not present
[0003.200] Find /i2c@7000c000's alias i2c0
[0003.204] get eeprom at 1-a2, size 256, type 0
[0003.208] get eeprom at 1-ae, size 256, type 0
[0003.221] Find /i2c@7000c400's alias i2c1
[0003.225] get eeprom at 2-a0, size 256, type 0
[0003.238] Find /i2c@7000c500's alias i2c2
[0003.241] get eeprom at 3-a0, size 256, type 0
[0003.246] get eeprom at 3-ae, size 256, type 0
[0003.256] Find /host1x/i2c@546c0000's alias i2c6
[0003.260] get eeprom at 7-a8, size 256, type 0
[0003.265] pm_ids_update: Updating 1,a2, size 256, type 0
[0003.270] I2C slave not started
[0003.273] I2C write failed
[0003.276] Writing offset failed
[0003.279] eeprom_init: EEPROM read failed
[0003.283] pm_ids_update: eeprom init failed
[0003.287] pm_ids_update: Updating 1,ae, size 256, type 0
[0003.292] I2C slave not started
[0003.295] I2C write failed
[0003.298] Writing offset failed
[0003.301] eeprom_init: EEPROM read failed
[0003.305] pm_ids_update: eeprom init failed
[0003.309] pm_ids_update: Updating 2,a0, size 256, type 0
[0003.314] I2C slave not started
[0003.317] I2C write failed
[0003.320] Writing offset failed
[0003.323] eeprom_init: EEPROM read failed
[0003.327] pm_ids_update: eeprom init failed
[0003.331] pm_ids_update: Updating 3,a0, size 256, type 0
[0003.361] pm_ids_update: The pm board id is 2180-1000-100
[0003.369] Adding plugin-manager/ids/2180-1000-100=/i2c@7000c500:module@0x50
[0003.377] pm_ids_update: pm id update successful
[0003.381] pm_ids_update: Updating 3,ae, size 256, type 0
[0003.387] I2C slave not started
[0003.390] I2C write failed
[0003.392] Writing offset failed
[0003.395] eeprom_init: EEPROM read failed
[0003.399] pm_ids_update: eeprom init failed
[0003.403] pm_ids_update: Updating 7,a8, size 256, type 0
[0003.410] GPIO driver for phandle 0xf3 could not be found
[0003.415] I2C slave not started
[0003.418] I2C write failed
[0003.421] Writing offset failed
[0003.424] eeprom_init: EEPROM read failed
[0003.428] pm_ids_update: eeprom init failed
[0003.433] GPIO driver for phandle 0xf3 could not be found
[0003.466] updating /chosen/nvidia,wifi-mac node 00:04:4b:5a:e0:21
[0003.475] updating /chosen/nvidia,bluetooth-mac node 00:04:4b:5a:e0:22
[0003.484] updating /chosen/nvidia,ethernet-mac node 00:04:4b:5a:e0:23
[0003.490] Plugin Manager: Parse ODM data 0x000a4000
[0003.504] shim_cmdline_install: /chosen/bootargs:
[0003.521] Find /i2c@7000c000's alias i2c0
[0003.525] get eeprom at 1-a2, size 256, type 0
[0003.530] get eeprom at 1-ae, size 256, type 0
[0003.542] Find /i2c@7000c400's alias i2c1
[0003.546] get eeprom at 2-a0, size 256, type 0
[0003.559] Find /i2c@7000c500's alias i2c2
[0003.563] get eeprom at 3-a0, size 256, type 0
[0003.567] get eeprom at 3-ae, size 256, type 0
[0003.577] Find /host1x/i2c@546c0000's alias i2c6
[0003.582] get eeprom at 7-a8, size 256, type 0
[0003.586] pm_ids_update: Updating 1,a2, size 256, type 0
[0003.592] I2C slave not started
[0003.595] I2C write failed
[0003.597] Writing offset failed
[0003.600] eeprom_init: EEPROM read failed
[0003.604] pm_ids_update: eeprom init failed
[0003.608] pm_ids_update: Updating 1,ae, size 256, type 0
[0003.614] I2C slave not started
[0003.617] I2C write failed
[0003.619] Writing offset failed
[0003.622] eeprom_init: EEPROM read failed
[0003.626] pm_ids_update: eeprom init failed
[0003.630] pm_ids_update: Updating 2,a0, size 256, type 0
[0003.636] I2C slave not started
[0003.639] I2C write failed
[0003.641] Writing offset failed
[0003.644] eeprom_init: EEPROM read failed
[0003.648] pm_ids_update: eeprom init failed
[0003.652] pm_ids_update: Updating 3,a0, size 256, type 0
[0003.682] pm_ids_update: The pm board id is 2180-1000-100
[0003.690] Adding plugin-manager/ids/2180-1000-100=/i2c@7000c500:module@0x50
[0003.697] pm_ids_update: pm id update successful
[0003.701] pm_ids_update: Updating 3,ae, size 256, type 0
[0003.707] I2C slave not started
[0003.710] I2C write failed
[0003.712] Writing offset failed
[0003.715] eeprom_init: EEPROM read failed
[0003.719] pm_ids_update: eeprom init failed
[0003.723] pm_ids_update: Updating 7,a8, size 256, type 0
[0003.730] GPIO driver for phandle 0xf3 could not be found
[0003.736] I2C slave not started
[0003.739] I2C write failed
[0003.741] Writing offset failed
[0003.744] eeprom_init: EEPROM read failed
[0003.748] pm_ids_update: eeprom init failed
[0003.754] GPIO driver for phandle 0xf3 could not be found
[0003.786] Add serial number:0321516060175 as DT property
[0003.796] Applying platform configs
[0003.806] platform-init is not present. Skipping
[0003.810] calling apps_init()
[0003.829] Found 22 GPT partitions in "sdmmc3_user"
[0003.834] Proceeding to Cold Boot
[0003.837] starting app android_boot_app
[0003.841] Device state: unlocked
[0003.844] display console init
[0003.851] status of dsi node is not okay
[0003.859] enabling 'vdd-hdmi' regulator
[0003.863] GPIO driver for phandle 0xf4 could not be found
[0003.869] hdmi cable connected
[0003.888] DT entry for leds-pwm not found
[0003.892] edid read success
[0003.907] edid read success
[0003.910] width = 640, height = 480, frequency = 25174825
[0003.915] width = 1920, height = 1200, frequency = 154000000
[0003.921] width = 1920, height = 1080, frequency = 148500000
[0003.927] width = 1920, height = 1080, frequency = 148351648
[0003.932] width = 1920, height = 1080, frequency = 148351648
[0003.938] width = 1280, height = 720, frequency = 74175824
[0003.943] width = 1280, height = 720, frequency = 74175824
[0003.949] width = 720, height = 480, frequency = 26973026
[0003.954] width = 720, height = 480, frequency = 26973026
[0003.959] width = 720, height = 576, frequency = 26973026
[0003.965] width = 720, height = 576, frequency = 26973026
[0003.970] Best mode Width = 1920, Height = 1080, freq = 148351648
[0003.979] tmds-config node not found
[0003.984] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting 'vdd-hdmi-dp' regulator to 1050000 micro volts
[0003.998] setting 'vdd-1v8' regulator to 1800000 micro volts
[0004.006] enabling 'vdd-hdmi' regulator
[0004.009] GPIO driver for phandle 0xf4 could not be found
[0004.040] using default cmu settings
[0004.043] dc_hdmi_enable, starting HDMI initialisation
[0004.049] dc_hdmi_enable, HDMI initialisation complete
[0004.054] list and configure display window
[0004.063] display console init completed
[0004.077] Gpio keyboard init success
[0004.123] found decompressor handler: lz4-legacy
[0004.136] decompressing blob (type 1)...
[0004.173] load_bmp_blob: panelresolution=1080 type=3
[0004.178] -------> se_aes_verify_sbk_clear: 747
[0004.182] se_aes_verify_sbk_clear: Error
[0004.186] SE operation failed
[0004.189] bl_battery_charging: connected to external power supply
[0004.200] fastboot: usb cable is not connected
[0004.210] device_query_partition_size: failed to open partition sdmmc3_user:MSC !
[0004.217] MSC Partition not found
[0004.239] blob_init: USP partition does not have valid Blob
[0004.244] kfs_getpartname: name = LNX
[0004.248] Loading kernel from LNX
[0004.314] load kernel from storage
[0004.323] decompressor handler not found
[0004.358] Successfully loaded kernel and ramdisk images
[0004.363] board ID = 884, board SKU = 3E8
[0004.369] load_bmp_blob: panelresolution=1080 type=3
[0004.552] display bmp image done
[0004.555] NCK carveout not present
[0004.558] Skipping dts_overrides
[0004.562] NCK carveout not present
[0004.578] Find /i2c@7000c000's alias i2c0
[0004.581] get eeprom at 1-a2, size 256, type 0
[0004.586] get eeprom at 1-ae, size 256, type 0
[0004.599] Find /i2c@7000c400's alias i2c1
[0004.602] get eeprom at 2-a0, size 256, type 0
[0004.615] Find /i2c@7000c500's alias i2c2
[0004.619] get eeprom at 3-a0, size 256, type 0
[0004.624] get eeprom at 3-ae, size 256, type 0
[0004.634] Find /host1x/i2c@546c0000's alias i2c6
[0004.638] get eeprom at 7-a8, size 256, type 0
[0004.643] pm_ids_update: Updating 1,a2, size 256, type 0
[0004.648] I2C slave not started
[0004.651] I2C write failed
[0004.654] Writing offset failed
[0004.657] eeprom_init: EEPROM read failed
[0004.660] pm_ids_update: eeprom init failed
[0004.665] pm_ids_update: Updating 1,ae, size 256, type 0
[0004.670] I2C slave not started
[0004.673] I2C write failed
[0004.676] Writing offset failed
[0004.679] eeprom_init: EEPROM read failed
[0004.683] pm_ids_update: eeprom init failed
[0004.687] pm_ids_update: Updating 2,a0, size 256, type 0
[0004.692] I2C slave not started
[0004.695] I2C write failed
[0004.698] Writing offset failed
[0004.701] eeprom_init: EEPROM read failed
[0004.705] pm_ids_update: eeprom init failed
[0004.709] pm_ids_update: Updating 3,a0, size 256, type 0
[0004.739] pm_ids_update: The pm board id is 2180-1000-100
[0004.747] Adding plugin-manager/ids/2180-1000-100=/i2c@7000c500:module@0x50
[0004.755] pm_ids_update: pm id update successful
[0004.759] pm_ids_update: Updating 3,ae, size 256, type 0
[0004.765] I2C slave not started
[0004.768] I2C write failed
[0004.770] Writing offset failed
[0004.773] eeprom_init: EEPROM read failed
[0004.777] pm_ids_update: eeprom init failed
[0004.781] pm_ids_update: Updating 7,a8, size 256, type 0
[0004.788] GPIO driver for phandle 0xf3 could not be found
[0004.793] I2C slave not started
[0004.796] I2C write failed
[0004.799] Writing offset failed
[0004.802] eeprom_init: EEPROM read failed
[0004.806] pm_ids_update: eeprom init failed
[0004.812] GPIO driver for phandle 0xf3 could not be found
[0004.844] updating /chosen/nvidia,wifi-mac node 00:04:4b:5a:e0:21
[0004.853] updating /chosen/nvidia,bluetooth-mac node 00:04:4b:5a:e0:22
[0004.862] updating /chosen/nvidia,ethernet-mac node 00:04:4b:5a:e0:23
[0004.868] Plugin Manager: Parse ODM data 0x000a4000
[0004.882] shim_cmdline_install: /chosen/bootargs:
[0004.887] Add serial number:0321516060175 as DT property
[0004.900] "bpmp" doesn't exist, creating
[0004.907] Updated bpmp info to DTB
[0004.913] Updated initrd info to DTB
[0004.916] "proc-board" doesn't exist, creating
[0004.922] Updated board info to DTB
[0004.926] "pmu-board" doesn't exist, creating
[0004.932] Updated board info to DTB
[0004.935] "display-board" doesn't exist, creating
[0004.941] Updated board info to DTB
[0004.945] "reset" doesn't exist, creating
[0004.949] Updated reset info to DTB
[0004.953] Cmdline: tegraid=21.1.2.0.0 ddr_die=2048M@2048M ddr_die=2048M@4096M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 gpt tegra_fbmem2=0x800000@0x92cb5000 is_hdmi_initialised=1
[0004.994] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1 nv-auto-config
[0005.011] Updated bootarg info to DTB
[0005.015] Adding uuid 00000001640d06c82400000004ff01c0 to DT
[0005.021] Adding eks info 0 to DT
[0005.028] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0005.034] Updated memory info to DTB
[0005.047] set vdd_core voltage to 1075 mv
[0005.050] setting 'vdd-core' regulator to 1075000 micro volts
[0005.056] Found secure-pmc; disable BPMP
SoC: tegra210
DRAM:  4 GiB
In:    serial
Out:   serial
Err:   serial
Scanning mmc 1:1...
599 bytes read in 30 ms (18.6 KiB/s)
L4T boot options
1:      SD Card
2:      Internal EMMC
7159654 bytes read in 335 ms (20.4 MiB/s)
34707464 bytes read in 1519 ms (21.8 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=2048M@2048M ddr_die=2048M@4096M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 gpt tegra_fbmem2=0x800000@0x92cb5000 is_hdmi_initialised=1  root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1 nv-auto-config quiet root=/dev/mmcblk2p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1 nv-auto-config
Starting kernel ...
[    0.550199] pca953x 1-0074: failed reading register
[    0.550776] pca953x 1-0077: failed reading register
[    1.051484] tegradc tegradc.1: dc_hdmi_hotplug_init: couldn't get regulator vdd_hdmi_5v0, -517
[    1.277473] FAN: coudln't get the regulator
[    1.302172] ina3221x 1-0042: ina3221 reset failure status: 0xffffff87
[    1.302687] ina3221x 1-0043: ina3221 reset failure status: 0xffffff87
cp: not writing through dangling symlink 'etc/resolv.conf'
[    2.162221] cgroup: cgroup2: unknown option "nsdelegate"
[    3.657922] random: systemd: uninitialized urandom read (16 bytes read)
[    3.667541] random: systemd: uninitialized urandom read (16 bytes read)
[    3.679433] random: systemd: uninitialized urandom read (16 bytes read)
[    4.299226] random: crng init done
[    4.302652] random: 135 urandom warning(s) missed due to ratelimiting
[    5.714028] using random self ethernet address
[    5.718539] using random host ethernet address
[    7.055722] using random self ethernet address
[    7.060222] using random host ethernet address
but I cannot type and work with ubuntu terminal in serial monitor
I enter my password here in putty:
ubuntu login: [   17.701551] Bridge firewalling registered
the cannot do anything… everything I type didn’t work
I want to explore directories and work with linux command line with serial console
how can I do that ?
here is my extlinux.conf:
LABEL primary
      MENU LABEL Internal EMMC
      LINUX /boot/Image
      INITRD /boot/initrd
      APPEND ${cbootargs} quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1 nv-auto-config
Hello @Didehban.nv,
What happens if you hit the enter key?
Does it behaves the same?
regards,
Andrew
