Hey,
For steering my robot my Arduino nano expects a 1 for left or a 2 for right every 15 mS. This worked out fine with a RaspberryPI. Over the RX/TX pins.
if i try:
ser.write(‘11111’) on raspberry this works on jetson it errors - please encode to bytes
ser.write((char)‘11111’) is an invalid syntax
while True:
for i in range (1, 10):
ser.write(b’1’)
time.sleep(0.15)
does something but the read function shows other numbers (serial monitor) in between a line of 1’s. This yitter makes my robot lose balance and fall.
how can i have a clean line of outgoing data over the RXTX pins?
The ground line is there and i use a lvl converter 3.3 to 5 volt
Hope to solve this with your help, thanks
