Hello!
I did the object detection tutorial (others also) based on this site: https://awesomeopensource.com/project/dusty-nv/jetson-inference#code-examples
It worked perfectly, but now, they don’t work at all. I didn’t change any code, the only difference is I did some recommended system update.
Please help me, how solve the problem, how to get the codes work again. Thank you!
detectNet – loading detection network model from:
– model networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff
– input_blob ‘Input’
– output_blob ‘NMS’
– output_count ‘NMS_1’
– class_labels networks/SSD-Mobilenet-v2/ssd_coco_labels.txt
– threshold 0.500000
– batch_size 1
[TRT] TensorRT version 7.1.0
[TRT] loading NVIDIA plugins…
[TRT] Registered plugin creator - ::GridAnchor_TRT version 1
[TRT] Registered plugin creator - ::NMS_TRT version 1
[TRT] Registered plugin creator - ::Reorg_TRT version 1
[TRT] Registered plugin creator - ::Region_TRT version 1
[TRT] Registered plugin creator - ::Clip_TRT version 1
[TRT] Registered plugin creator - ::LReLU_TRT version 1
[TRT] Registered plugin creator - ::PriorBox_TRT version 1
[TRT] Registered plugin creator - ::Normalize_TRT version 1
[TRT] Registered plugin creator - ::RPROI_TRT version 1
[TRT] Registered plugin creator - ::BatchedNMS_TRT version 1
[TRT] Could not register plugin creator - ::FlattenConcat_TRT version 1
[TRT] Registered plugin creator - ::CropAndResize version 1
[TRT] Registered plugin creator - ::DetectionLayer_TRT version 1
[TRT] Registered plugin creator - ::Proposal version 1
[TRT] Registered plugin creator - ::ProposalLayer_TRT version 1
[TRT] Registered plugin creator - ::PyramidROIAlign_TRT version 1
[TRT] Registered plugin creator - ::ResizeNearest_TRT version 1
[TRT] Registered plugin creator - ::Split version 1
[TRT] Registered plugin creator - ::SpecialSlice_TRT version 1
[TRT] Registered plugin creator - ::InstanceNormalization_TRT version 1
[TRT] detected model format - UFF (extension ‘.uff’)
[TRT] desired precision specified for GPU: FASTEST
[TRT] requested fasted precision for device GPU without providing valid calibrator, disabling INT8
[TRT] native precisions detected for GPU: FP32, FP16
[TRT] selecting fastest native precision for GPU: FP16
[TRT] attempting to open engine cache file /usr/local/bin/networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff.1.1.7100.GPU.FP16.engine
[TRT] loading network plan from engine cache… /usr/local/bin/networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff.1.1.7100.GPU.FP16.engine
[TRT] device GPU, loaded /usr/local/bin/networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff
[TRT] coreReadArchive.cpp (38) - Serialization Error in verifyHeader: 0 (Version tag does not match)
[TRT] INVALID_STATE: std::exception
[TRT] INVALID_CONFIG: Deserialize the cuda engine failed.
[TRT] device GPU, failed to create CUDA engine
[TRT] failed to create TensorRT engine for /usr/local/bin/networks/SSD-Mobilenet-v2/ssd_mobilenet_v2_coco.uff, device GPU
[TRT] detectNet – failed to initialize.
detectnet-console: failed to initialize detectNet
Press ENTER to continue…
