"Serialization (Serialization assertion magicTagRead == magicTag failed.Magic tag does not match" Error While running converted TRT model
Hello.
I am trying to use the our TAO converted trt UNET model into deep stream pipeline
gst-launch-1.0 filesrc location=02****.mp4 ! qtdemux ! h264parse ! nvv4l2decoder ! m.sink_0 nvstreammux name=m batch-size=1 width=1920 height=1080 ! nvvideoconvert ! nvdspreprocess config-file= /opt/nvidia/deepstream/deepstream/sources/gst-plugins/gst-nvdspreprocess/config_preprocess.txt  ! nvinfer config-file-path=pgie_unet_tao_config.txt input-tensor-meta=1 batch-size=7  ! nvmultistreamtiler width=1920 height=1080 ! nvvideoconvert ! nvv4l2h264enc ! h264parse ! 'video/x-h264,stream-format=avc' ! matroskamux ! filesink location=gst_out.mkv
But while executing that within gstreamer pipeline i am getting error below
Setting pipeline to PAUSED ...
ERROR: [TRT]: 1: [stdArchiveReader.cpp::StdArchiveReader::29] Error Code 1: Serialization (Serialization assertion magicTagRead == magicTag failed.Magic tag does not match)
ERROR: [TRT]: 4: [runtime.cpp::deserializeCudaEngine::76] Error Code 4: Internal Error (Engine deserialization failed.)
ERROR: ../nvdsinfer/nvdsinfer_model_builder.cpp:1528 Deserialize engine failed from file: /home/elio_admin/deep/unet/CA_CD_ICG_100_2switched.trt_ew
0:00:01.483888692 14958 0x564bfea49a60 WARN                 nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<nvinfer0> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1889> [UID = 1]: deserialize engine from file :/home/elio_admin/deep/unet/CA_CD_ICG_100_2switched.trt_ew failed
0:00:01.483940342 14958 0x564bfea49a60 WARN                 nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<nvinfer0> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1996> [UID = 1]: deserialize backend context from engine from file :/home/elio_admin/deep/unet/CA_CD_ICG_100_2switched.trt_ew failed, try rebuild
0:00:01.483953638 14958 0x564bfea49a60 INFO                 nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<nvinfer0> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1914> [UID = 1]: Trying to create engine from model files
WARNING: [TRT]: onnx2trt_utils.cpp:364: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
WARNING: [TRT]: TensorRT was linked against cuBLAS/cuBLAS LT 11.5.1 but loaded cuBLAS/cuBLAS LT 111.0.1
WARNING: [TRT]: Detected invalid timing cache, setup a local cache instead
0:00:16.907711285 14958 0x564bfea49a60 INFO                 nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<nvinfer0> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1947> [UID = 1]: serialize cuda engine to file: /home/elio_admin/deep/CA_CD.etlt_b1_gpu0_fp32.engine successfully
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 2
0   INPUT  kFLOAT input_1         3x512x512
1   OUTPUT kFLOAT softmax_1       512x512x3
0:00:16.921437595 14958 0x564bfea49a60 INFO                 nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<nvinfer0> [UID 1]: Load new model:pgie_unet_tao_config.txt sucessfully
Pipeline is PREROLLING ...
Warning: Color primaries 5 not present and will be treated BT.601
Redistribute latency...
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Got EOS from element "pipeline0".
Execution ended after 0:00:20.576415680
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
Any help and suggestion would be appreciated
• Hardware Platform (DGPU)
Tesla T4
• DeepStream Version
deepstream-app version 6.0.1
DeepStreamSDK 6.0.1
CUDA Driver Version: 11.4
CUDA Runtime Version: 11.4
TensorRT Version: 8.0
cuDNN Version: 8.4
libNVWarp360 Version: 2.0.1d3
Could you attach your models and config files?
[property]
labelfile-path=unet_labels.txt
#model-engine-file=Model.trt
engine-create-func-name=NvDsInferYoloCudaEngineGet
#tlt-encoded-model=Model.etlt
net-scale-factor=0.00784313725490196
offsets=127.5;127.5;127.5
infer-dims=3;512;512
#tlt-model-key=Model_Key
network-type=1
num-detected-classes=3
model-color-format=1
segmentation-threshold=0.0
output-blob-names=softmax_1
segmentation-output-order=1
gie-unique-id=1
pgie_unet_tao_config.txt (1.7 KB)
classification_0.trt (88.4 MB)
You can refer the topic below:
https://forums.developer.nvidia.com/t/error-trt-stdarchivereader-serialization-assertion/226692?u=morganh
Referred source seems not to be helping much could you pl. look into issue again
We are trying to use the application on the host machine which is an Ubuntu 18.04 dPGU A6000, T4 instead of an Docker. We have also matched the Version of TensorRT on both machine having similar version, Machine on the Tlt-export to convert model into Etlt and TensorRT was done was same as our Execution server having similar TensorRT version. We are Trying to use an TAO-Unet model with our custom training over data having 3 class detection. But we are still facing issues as mentioned above if any reference link to the similar kind of problem or anything around Unit could be share we can also have look at that also.
Hi @nitinp14920914
Please try to let deepstream generate the tensorrt engine directly based on the .etlt model.
Please follow
https://github.com/NVIDIA-AI-IOT/deepstream_tao_apps/blob/master/configs/unet_tao/pgie_unet_tao_config.txt
And please ignore line 31 and 32. Actually it can parse the etlt model.
