Recently we tried to test the TX2 on Auvidea J120 carrier board. After we put the TX2 module back on the development board it failed to boot or enter recovery board.
By using the serial console we get the following messages:
[0000.313] !!! Exception !!! [lr:0x40021cea, dfar:0x2431018, dfsr:0x1808]
[0000.320] MB1-BIT() boot status dump :
0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
[0000.348] Last seen error : 0x00000000
And occasionally when the above message doesn’t show up:
[ 2.663832] ata2: DUMMY
[ 2.664834] spi-tegra114 3210000.spi: Static pin configuration used
[ 2.665296] spi-tegra114 c260000.spi: Static pin configuration used
[ 2.665773] spi-tegra114 3240000.spi: Static pin configuration used
[ 2.666622] tun: Universal TUN/TAP device driver, 1.6
[ 2.666625] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 2.666820] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 2.666821] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.666855] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.3.0-k
[ 2.666857] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.667827] CPU5: SError detected, daif=140, spsr=0x80000045, mpidr=80000103, esr=bf000002
[ 2.667830] CPU3: SError detected, daif=1c0, spsr=0xc5, mpidr=80000101, esr=b f40c000
[ 2.667834] CPU0: SError detected, daif=1c0, spsr=0x600000c5, mpidr=80000100, esr=bf40c000
[ 2.667837] CPU4: SError detected, daif=1c0, spsr=0x600000c5, mpidr=80000102, esr=bf40c000
[ 2.667839] CPU5: SError detected, daif=140, spsr=0x80000045, mpidr=80000103, esr=bf40c000
[ 2.667844] CPU5: SError detected, daif=140, spsr=0x20000045, mpidr=80000103, esr=bf000002
[ 2.667848] CPU5: SError detected, daif=140, spsr=0x60000045, mpidr=80000103, esr=bf000002
[ 2.667900] CPU5: SError detected, daif=140, spsr=0x80000045, mpidr=80000103, esr=bf000002
[ 2.667905] CPU5: SError detected, daif=140, spsr=0x20000045, mpidr=80000103, esr=bf000002
[ 2.667908] CPU5: SError detected, daif=140, spsr=0x60000045, mpidr=80000103, esr=bf000002
[ 2.670841] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b a7 e5 f0
[ 2.982370] ata1: SATA link down (SStatus 0 SControl 300)
[ 3.091608] tegradc 15210000.nvdisplay: fb registered
[ 13.442362] random: nonblocking pool is initialized
[ 23.678334] INFO: rcu_preempt detected stalls on CPUs/tasks:
[ 23.685527] 2-...: (1 GPs behind) idle=331/140000000000000/0 softirq=44/47 fqs=5203
Could this cause by hardware failure? Is there any way to solve this issue?
Regards
Full log:
log.txt (78.6 KB)
