Server connection error for Assesment of Rapid Application Development with Large Language Models
Keep getting the below error whenever i try to run the task3 in the assesment. this is 4th time it has happened. lit takes a hour to run then disconnects. can you please provide a better server or a simpler assesment? because this is such a waste of time sorry to say. appreciate your help on this. Thanks!!! Server Connection Error
A connection to the Jupyter server could not be established. JupyterLab will continue trying to reconnect. Check your network connection or Jupyter server configuration.
Hello @samrat_kar_77
I suggest that you open a case with the DLI team for this issue.
