Q: A few of the parameters for running the solver need to be included in the url parameters, it throws a bad request otherwise. While others it seems can just be included within the json data object. Is this documented anywhere?
A: . You can observe the required and optional parameter here https://developer.nvidia.com/docs/cuopt/python/serv_api.html,
There is an optional argument used in default or run http://0.0.0.0:5000/redoc when server is run.
