Service Maker OSD Labels display, textParams() access
• Hardware Platform (Jetson / GPU) Jetson
• DeepStream Version Deepstream 7.0 SDK
• JetPack Version (valid for Jetson only) Jetpack 6.0
• TensorRT Version TensorRT: 8.6.2.3
• Issue Type( questions, new requirements, bugs) Question
• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) Deepstream service maker test 2 and test 5.
Good afternoon, everyone. I recently switched to developing DeepStream applications using Service Maker. While testing the DeepStream Service Maker Test 2 application with a custom input model, I can see both the bounding boxes and labels for detected objects. However, when I move the same pipeline to the Test 5 application, I only see the bounding boxes without the labels.
For example, if I add this code inside the handleData() function in the DeepStream Service Maker Test 5 application and try to build it, I get an “undefined reference” error:
    const auto& rect = object.rectParams();
    const auto& text_params = object.textParams();
    std::cout << "Bounding Box for Object:"
              << " Left: " << rect.left
              << " Top: " << rect.top
              << " Width: " << rect.width
              << " Height: " << rect.height
              << " Confidence: " << object.confidence()
              << " Class ID: " << object.classId()
              << " Label: " << object.label()
              << " Label: " << text_params.display_text
              << std::endl;
After checking the metadata.hpp file and specifically the ObjectMetadata class, I noticed these two declarations. I can easily access rectParams() and retrieve information from it. Why can’t I access textParams, and what is the reason the labels are not being displayed?
NvOSD_RectParams rectParams() const;
NvOSD_TextParams textParams() const
Thanks for your help!
Hi @6220412 , if you add the code snippet in the test2, will it report the same error? And what’s the object in your code snippet?
