I have several cameras, and I want to run different sets of analytics on them.
Right now, I connect all streams to a single pipeline. Therefore, all streams are processed in the same way. I want to manage them more flexibly. For example, I would like to enable vehicle detection only on one subset of cameras, face detection on a second subset, and LPR on a third subset. It would be even better to change settings like thresholds per stream.
• Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
