Set CSI Camera Metering Mode
Does nvarguscamerasrc has a parameter to set the metering mode of the camera?
Something similar to this:
(Taken from https://www.raspberrypi.org/documentation/raspbian/applications/camera.md)
It would be great, since I have a case using average metering (by default, I think) was not right and I need other metering mode. However, I didn’t find similar option in nvarguscamerasrc.
I was using Jetson Nano and IMX219 camera module with CSI connection.
I was using Python with cv2.VideoCapture using gstreamer backend.
Thank you.
I guess not, but you can find the argus API to check if any similar function.
https://docs.nvidia.com/jetson/l4t-multimedia/group__LibargusAPI.html
Is argus API available in Python?
I found no documentation on how to call the argus API from Python in Jetson Nano with JetPack 4.3.
No, you can build argus APP to use those API,
Have a check with multimedia API sample code download by sdkmanager.
Sure, will check.
Thank you.
