I’m using Gstreamer pipeline to play rtsp stream : rtspsrc -> decodebin -> nvvidconv -> nvvideosink -> EGLStream
I used mailbox mode with the attribute “streamAttriMailboxMode = { EGLNONE };”, and the streams would blocking frequently.
And when I changed it with the attribute "streamAttriMailboxMode = { EGL_SUPPORT_REUSE, EGL_FALSE, EGLNONE };Video quality in beginning is good but after several minutes playback start to freezing - like slow motion video and never back to normal state. From that moment in console output I have many warnings:
WARNING: from element /GstPipeline:pipeline/GstNvVideoSink: A lot of buffers are being dropped.
Additional debug info:
gstbasesink.c(2854): gst_base_sink_is_too_late (): /GstPipeline:pipeline/NvVideoSink:
There may be a timestamping problem, or this computer is too slow.
And I refer to the web set nvvideosink property “sync” to false, it woundn’t be freezed, but it back to origin – blocking frequently.
I have seen the demo in NVIDIA_CUDA-8.0_Samples/3_Imaging/EGLStream_CUDA_Interop , but there is just testing one frame, and not test video stream.
