It’s an environment variable. To set it “permanently” you could:
Just do
export GLPATH=/usr/lib
and then it will be set for as long as you are logged in, but only in the shell/command prompt where you issue it. For instance, after doing that, in the same shell/command prompt, if you just typed make, it should behave the same way as if you typed GLPATH=/usr/lib make
edit some file like .bashrc to add that export command “permanently”, i.e. to make it effective for any login under that user name.
Note that discussion of environment variables is really just about linux, not about CUDA specifically, so google is your friend.
Having said all that, this specific environment variable should really only be needed when using a particular Makefile. It is not needed generally to make OpenGL “work”.
