Hi Guys,
Can anyone please help me to set the GStreamer camera settings using open-cv after the camera is initialized?
Hi Guys,
hello niteshgaba,
may I know what’s your actual use-case.
what are the settings you’re going to configure after camera start streaming?
thanks
Hi JerryChang,
I would like to change the awmode and loca the exposure after few seconds once the camera is initialized.
The other alternative i could think of is, finding the right amount of exposure and setting it manually.
Thanks for helping in advance
hello niteshgaba ,
you cannot modify the settings if you’re having gstreamer pipeline to launch camera for streaming.
however, you may test with argus_camera application. it provide the UIs to toggle the camera settings and show the results to preview frames instantly.
hello niteshgaba ,
as you can see, it’s creating a gstreamer pipeline; it’s unavailable to change the awbmode and exposure after stream-on.
Hi @JerryChang ,
The other alternative i can think of is using gstreamer without open-cv. Do you think that will work ?
hello niteshgaba,
you may check nvgstcapture
, it’s able to set sensor configurations during preview rendering.
or, you could refer to Multimedia API sample applications, please have implementations to call the AutoControlSettings APIs for camera configuration settings,
thanks
