HI team, i was working in the nvidia AGX orin in Jetpack 6.1.0 L4T 36.4.0 in that i have my camera driver support the both 30 and 60 i was able to stream both fps in g streamerbut if i tried to set the frame rate through v4l2-ctl --set-parm=60 it was not setting the vale to 60. is this was a actual behavior do i need to changes in my driver
Use below command to try.
v4l2-ctl -c frame_rate=6000000
v4l2-ctl -C frame_rate
