We have multiple sensor configrations with same resolution(eg different window position) and want to switch it in runtime.
Is there a way to specify sensor mode directly by argus library?
Thanks !
Thanks !
Should be able do it by SetSensorMode() API.
Also you can reference to argus_camera to implement it.
Thank you!
We can fetch sensor mode list from camera properties interface.
Then how can I determine which sensor mode is my desired?
There is no mode ID provided in ISensorMode and other settings maybe same.
Please check the argus_camera GUI for the sensor mode selected and check the source for your desired.
Thanks for your help!
