• Hardware Platform (Jetson / GPU) Xavier
• DeepStream Version 5.1.0
• JetPack Version (valid for Jetson only) 4.5.1
• TensorRT Version
I find that the tolerance in nvdsanalitycs is quite big. For example the following configuration:
[direction-detection-stream-1]
enable=1
direction-M1=277;148;329;126;
direction-M2=309;29;186;67;
direction-M3=479;164;382;146;
class-id=2;3;4;5;6;7;8;9;10;11;
Will always provide:
object 360121093530320910 is moving in M3 id : 14
even if the object is following direction in M2
How can I set some tolerance in direction in order to distinguish between both movements?
If direction-M3 is missing then object direction is correctly defined, but I need to detect object in both directions.
