Hi WayneWWW:
Thanks for you reply;
My modifiction as follows;
In egra234-p3768-0000-a0.dtsi file :
ports {
usb2-0 {/* Goes to recovery port */
mode = "host";
status = "okay";
vbus-supply = <&p3768_vdd_5v_sys>;
usb2-1 {/* Goes to hub */
mode = "host";
vbus-supply = <&p3768_vdd_av10_hub>;
status = "okay";
usb2-2 {/* Goes to M2.E */
mode = "host";
status = "okay";
usb3-0 {/* Goes to hub */
nvidia,usb2-companion = <1>;
status = "okay";
usb3-1 {/* Goes to J5 */
nvidia,usb2-companion = <0>;
status = "okay";
//disable xudc
tegra_xudc: xudc@3550000 {
status = "disabled";
phys = <&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-0}>,
<&{/xusb_padctl@3520000/pads/usb3/lanes/usb3-1}>;
phy-names = "usb2-0", "usb3-1";
nvidia,xusb-padctl = <&xusb_padctl>;
In tegra234-soc-base.dtsi file:
tegra_usb_cd: usb_cd {
compatible = "nvidia,tegra234-usb-cd";
phys = <&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-0}>;
phy-names = "otg-phy";
I am currently using JetPack 5.1.5 and debugging it on Orin NX 16G own custom board.
After modifying the device tree, I recompiled the kernel and found that the burning process timed out.
flash failed log:
/home/yan/nvidia/nvidia_sdk/JetPack_5.1.5_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra
* Step 3: Start the flashing process *
Waiting for target to boot-up...
Timeout
Cleaning up...
orin nx uart log:
[11:09:39:513] <0xff><0xe4>E/TC:?? 00 get_rpc_alloc_res:645 RPC allocation failed. Non-secure world result: ret=0xffff0000 ret_origin=0␍␊
[11:09:39:543] E/LD: init_elf:486 sys_open_ta_bin(bc50d971-d4c9-42c4-82cb-343fb7f37896)␍␊
[11:09:39:563] E/TC:?? 00 ldelf_init_with_ldelf:131 ldelf failed with res: 0xffff000c␍␊
[11:09:39:593] <0xff><0xe1>␊
[11:09:39:599] ␊
[11:09:39:605] ␊
[11:09:39:611] ␊
[11:09:39:617] ␊
[11:09:39:623] ␊
[11:09:39:629] ␊
[11:09:39:635] ␊
[11:09:39:641] ␊
[11:09:39:648] ␊
[11:09:39:653] ␊
[11:09:39:660] ␊
[11:09:39:666] ␊
[11:09:39:672] ␊
[11:09:39:678] ␊
[11:09:39:684] ␊
[11:09:39:690] ␊
[11:09:39:696] ␊
[11:09:39:702] ␊
[11:09:39:708] ␊
[11:09:39:714] ␊
[11:09:39:720] ␊
[11:09:39:727] ␊
[11:09:39:733] ␊
[11:09:39:739] ␊
[11:09:39:745] ␊
[11:09:39:751] ␊
[11:09:39:757] ␊
[11:09:39:763] ␊
[11:09:39:769] ␊
[11:09:39:809] ␊
[11:09:39:815] ␊
[11:09:39:822] ␊
[11:09:39:833] ␊
[11:09:39:839] ␊
[11:09:39:845] ␊
[11:09:39:851] ␊
[11:09:39:858] ␊
[11:09:39:866] ␊
[11:09:39:873] ␊
[11:09:39:879] ␊
[11:09:39:885] ␊
[11:09:39:892] ␊
[11:09:39:899] ␊
[11:09:39:906] ␊
[11:09:39:913] ␊
[11:09:39:921] ␊
[11:09:39:928] ␊
[11:09:39:936] ␊
[11:09:39:942] ␊
[11:09:39:958] ␊
[11:09:39:958] <0x1b>[2J<0x1b>[04D<0x1b>[=3h<0x1b>[2J<0x1b>[09D␊
[11:09:39:978] ␊
[11:09:40:000] ␊
[11:09:40:015] ␊
[11:09:40:024] ␊
[11:09:40:034] ␊
[11:09:40:043] ␊
[11:09:40:053] ␊
[11:09:40:072] ␊
[11:09:40:079] ␊
[11:09:40:085] ␊
[11:09:40:113] ␊
[11:09:40:133] ␊
[11:09:40:144] ␊
[11:09:40:150] ␊
[11:09:40:179] ␊
[11:09:40:189] ␊
[11:09:40:349] ␊
[11:09:40:423] ␊
[11:09:40:440] ␊
[11:09:40:452] ␊
[11:09:40:469] ␊
[11:09:40:484] ␊
[11:09:40:490] ␊
[11:09:40:497] ␊
[11:09:40:521] ␊
[11:09:40:578] ␊
[11:09:40:584] ␊
[11:09:40:592] ␊
[11:09:40:599] ␊
[11:09:40:608] ␊
[11:09:41:180] ␊
[11:09:41:180] L4TLauncher: Attempting RCM Boot␍␊
[11:09:41:243] EFI stub: Booting Linux Kernel...␍␊
[11:09:41:253] EFI stub: Using DTB from configuration table␍␊
[11:09:41:261] EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path␍␊
[11:09:41:267] EFI stub: Exiting boot services and installing virtual address map...␍␊
[11:09:41:457] <0xff><0xe4>I/TC: Secondary CPU 1 initializing␍␊
[11:09:41:467] I/TC: Secondary CPU 1 switching to normal world boot␍␊
[11:09:41:478] I/TC: Secondary CPU 2 initializing␍␊
[11:09:41:498] I/TC: Secondary CPU 2 switching to normal world boot␍␊
[11:09:41:508] I/TC: Secondary CPU 3 initializing␍␊
[11:09:41:518] I/TC: Secondary CPU 3 switching to normal world boot␍␊
[11:09:41:545] I/TC: Secondary CPU 4 initializing␍␊
[11:09:41:556] I/TC: Secondary CPU 4 switching to normal world boot␍␊
[11:09:41:566] I/TC: Secondary CPU 5 initializing␍␊
[11:09:41:577] I/TC: Secondary CPU 5 switching to normal world boot␍␊
[11:09:41:597] I/TC: Secondary CPU 6 initializing␍␊
[11:09:41:607] I/TC: Secondary CPU 6 switching to normal world boot␍␊
[11:09:41:627] I/TC: Secondary CPU 7 initializing␍␊
[11:09:41:637] I/TC: Secondary CPU 7 switching to normal world boot␍␊
[11:09:42:149] <0xff><0xe1>[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]␍␊
[11:09:42:155] [ 0.000000] Linux version 5.10.216-tegra (yan@yan-Legion-Y9000P-IRX9) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #3 SMP PREEMPT Fri Oct 31 11:01:34 CST 2025␍␊
[11:09:42:174] [ 0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,␍␊
[11:09:42:182] [ 0.000000] OF: fdt: - 80000000 , c0000000␍␊
[11:09:42:187] [ 0.000000] Machine model: NVIDIA Orin NX Developer Kit␍␊
[11:09:42:192] [ 0.000000] efi: EFI v2.70 by EDK II␍␊
[11:09:42:197] [ 0.000000] efi: SMBIOS=0xffff0000 SMBIOS 3.0=0x43bbb0000 MEMATTR=0x4363ac018 RNG=0x429470018 MEMRESERVE=0x42a9d4f18 ␍␊
[11:09:42:202] [ 0.000000] random: crng init done␍␊
[11:09:42:208] [ 0.000000] Reserved memory: created CMA memory pool at 0x000000045e800000, size 256 MiB␍␊
[11:09:42:217] [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool␍␊
[11:09:42:223] [ 0.000000] Zone ranges:␍␊
[11:09:42:232] [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]␍␊
[11:09:42:232] [ 0.000000] DMA32 empty␍␊
[11:09:42:239] [ 0.000000] Normal [mem 0x0000000100000000-0x0000000473ffffff]␍␊
[11:09:42:244] [ 0.000000] Movable zone start for each node␍␊
[11:09:42:249] [ 0.000000] Early memory node ranges␍␊
[11:09:42:252] [ 0.000000] node 0: [mem 0x0000000080000000-0x00000000fffdffff]␍␊
[11:09:42:256] [ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]␍␊
[11:09:42:261] [ 0.000000] node 0: [mem 0x0000000100000000-0x000000042cbb4fff]␍␊
[11:09:42:267] [ 0.000000] node 0: [mem 0x000000042cbb5000-0x000000042cd0bfff]␍␊
[11:09:42:279] [ 0.000000] node 0: [mem 0x000000042cd0c000-0x000000043a1effff]␍␊
[11:09:42:281] [ 0.000000] node 0: [mem 0x000000043a1f0000-0x000000043c12ffff]␍␊
[11:09:42:290] [ 0.000000] node 0: [mem 0x000000043c130000-0x000000046eb0ffff]␍␊
[11:09:42:296] [ 0.000000] node 0: [mem 0x000000046eb10000-0x000000046eb1ffff]␍␊
[11:09:42:304] [ 0.000000] node 0: [mem 0x0000000472000000-0x0000000473ffffff]␍␊
[11:09:42:306] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000473ffffff]␍␊
[11:09:42:312] [ 0.000000] On node 0, zone Normal: 224 pages in unavailable ranges␍␊
[11:09:42:320] [ 0.000000] psci: probing for conduit method from DT.␍␊
[11:09:42:325] [ 0.000000] psci: PSCIv1.1 detected in firmware.␍␊
[11:09:42:330] [ 0.000000] psci: Using standard PSCI v0.2 function IDs␍␊
[11:09:42:336] [ 0.000000] psci: Trusted OS migration not required␍␊
[11:09:42:341] [ 0.000000] psci: SMC Calling Convention v1.2␍␊
[11:09:42:344] [ 0.000000] percpu: Embedded 32 pages/cpu s90392 r8192 d32488 u131072␍␊
[11:09:42:351] [ 0.000000] Detected PIPT I-cache on CPU0␍␊
[11:09:42:354] [ 0.000000] CPU features: detected: GIC system register CPU interface␍␊
[11:09:42:359] [ 0.000000] CPU features: detected: Virtualization Host Extensions␍␊
[11:09:42:368] [ 0.000000] CPU features: kernel page table isolation forced ON by KASLR␍␊
[11:09:42:375] [ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)␍␊
[11:09:42:381] [ 0.000000] CPU features: detected: Spectre-v4␍␊
[11:09:42:387] [ 0.000000] CPU features: detected: Spectre-BHB␍␊
[11:09:42:391] [ 0.000000] alternatives: patching kernel code␍␊
[11:09:42:394] [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 4066848␍␊
[11:09:42:401] [ 0.000000] Kernel command line: root=/dev/initrd rw rootwait mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 kernel.hung_task_panic=0 ␍␊
[11:09:42:418] [ 0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)␍␊
[11:09:42:424] [ 0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)␍␊
[11:09:42:432] [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off␍␊
[11:09:42:440] [ 0.000000] software IO TLB: mapped [mem 0x00000000effe0000-0x00000000fffe0000] (256MB)␍␊
[11:09:42:446] [ 0.000000] Memory: 15588200K/16526464K available (18560K kernel code, 3172K rwdata, 7224K rodata, 4032K init, 1417K bss, 676120K reserved, 262144K cma-reserved)␍␊
[11:09:42:463] [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1␍␊
[11:09:42:469] [ 0.000000] rcu: Preemptible hierarchical RCU implementation.␍␊
[11:09:42:474] [ 0.000000] rcu: ⇥ RCU event tracing is enabled.␍␊
[11:09:42:480] [ 0.000000] rcu: ⇥ RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.␍␊
[11:09:42:485] [ 0.000000] ⇥ Trampoline variant of Tasks RCU enabled.␍␊
[11:09:42:491] [ 0.000000] ⇥ Rude variant of Tasks RCU enabled.␍␊
[11:09:42:494] [ 0.000000] ⇥ Tracing variant of Tasks RCU enabled.␍␊
[11:09:42:499] [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.␍␊
[11:09:42:508] [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8␍␊
[11:09:42:513] [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0␍␊
[11:09:42:519] [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode␍␊
[11:09:42:524] [ 0.000000] GICv3: 960 SPIs implemented␍␊
[11:09:42:530] [ 0.000000] GICv3: 0 Extended SPIs implemented␍␊
[11:09:42:533] [ 0.000000] GICv3: Distributor has no Range Selector support␍␊
[11:09:42:539] [ 0.000000] GICv3: 16 PPIs implemented␍␊
[11:09:42:544] [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000␍␊
[11:09:42:550] [ 0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)␍␊
[11:09:42:555] [ 0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]␍␊
[11:09:42:561] [ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).␍␊
[11:09:42:569] [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns␍␊
[11:09:42:578] [ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns␍␊
[11:09:42:586] [ 0.000623] Console: colour dummy device 80x25␍␊
[11:09:42:592] [ 0.000661] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)␍␊
[11:09:42:603] [ 0.000670] pid_max: default: 32768 minimum: 301␍␊
[11:09:42:607] [ 0.000722] LSM: Security Framework initializing␍␊
[11:09:42:612] [ 0.000742] Yama: becoming mindful.␍␊
[11:09:42:615] [ 0.000760] SELinux: Initializing.␍␊
[11:09:42:617] [ 0.000822] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)␍␊
[11:09:42:625] [ 0.000847] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)␍␊
[11:09:42:634] [ 0.001884] rcu: Hierarchical SRCU implementation.␍␊
[11:09:42:639] [ 0.001960] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build␍␊
[11:09:42:648] [ 0.002327] DTS File Name: /home/yan/nvidia/nvidia_sdk/JetPack_5.1.5_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/source/public/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t23x/p3768/kernel-dts/tegra234-p3767-0000-p3768-0000-a0.dts␍␊
[11:09:42:671] [ 0.002332] DTB Build time: Oct 31 2025 11:01:46␍␊
[11:09:42:676] [ 0.003501] Tegra Revision: A01 SKU: 0xd3 CPU Process: 0 SoC Process: 0␍␊
[11:09:42:681] [ 0.003660] Remapping and enabling EFI services.␍␊
[11:09:42:687] [ 0.004524] smp: Bringing up secondary CPUs ...␍␊
[11:09:42:690] [ 0.033209] Detected PIPT I-cache on CPU1␍␊
[11:09:42:695] [ 0.033243] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000␍␊
[11:09:42:701] [ 0.033268] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]␍␊
[11:09:42:709] [ 0.061897] Detected PIPT I-cache on CPU2␍␊
[11:09:42:715] [ 0.061906] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000␍␊
[11:09:42:721] [ 0.061921] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]␍␊
[11:09:42:726] [ 0.090519] Detected PIPT I-cache on CPU3␍␊
[11:09:42:730] [ 0.090527] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000␍␊
[11:09:42:737] [ 0.090540] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]␍␊
[11:09:42:743] [ 0.121195] Detected PIPT I-cache on CPU4␍␊
[11:09:42:748] [ 0.121214] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000␍␊
[11:09:42:754] [ 0.121240] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]␍␊
[11:09:42:763] [ 0.149893] Detected PIPT I-cache on CPU5␍␊
[11:09:42:766] [ 0.149903] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000␍␊
[11:09:42:774] [ 0.149917] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]␍␊
[11:09:42:780] [ 0.178534] Detected PIPT I-cache on CPU6␍␊
[11:09:42:785] [ 0.178544] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000␍␊
[11:09:42:791] [ 0.178558] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]␍␊
[11:09:42:801] [ 0.207179] Detected PIPT I-cache on CPU7␍␊
[11:09:42:809] [ 0.207189] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000␍␊
[11:09:42:813] [ 0.207203] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]␍␊
[11:09:42:816] [ 0.207259] smp: Brought up 1 node, 8 CPUs␍␊
[11:09:42:822] [ 0.207273] SMP: Total of 8 processors activated.␍␊
[11:09:42:825] [ 0.207277] CPU features: detected: Privileged Access Never␍␊
[11:09:42:830] [ 0.207278] CPU features: detected: LSE atomic instructions␍␊
[11:09:42:835] [ 0.207280] CPU features: detected: User Access Override␍␊
[11:09:42:841] [ 0.207282] CPU features: detected: 32-bit EL0 Support␍␊
[11:09:42:847] [ 0.207284] CPU features: detected: Common not Private translations␍␊
[11:09:42:852] [ 0.207285] CPU features: detected: RAS Extension Support␍␊
[11:09:42:858] [ 0.207287] CPU features: detected: Data cache clean to the PoU not required for I/D coherence␍␊
[11:09:42:866] [ 0.207289] CPU features: detected: CRC32 instructions␍␊
[11:09:42:872] [ 0.207290] CPU features: detected: Speculative Store Bypassing Safe (SSBS)␍␊
[11:09:42:877] [ 0.239842] CPU: All CPU(s) started at EL2␍␊
[11:09:42:883] [ 0.241773] devtmpfs: initialized␍␊
[11:09:42:886] [ 0.255679] KASLR enabled␍␊
[11:09:42:888] [ 0.255797] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns␍␊
[11:09:42:897] [ 0.255808] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)␍␊
[11:09:42:905] [ 0.257328] pinctrl core: initialized pinctrl subsystem␍␊
[11:09:42:911] [ 0.257778] SMBIOS 3.0.0 present.␍␊
[11:09:42:914] [ 0.257785] DMI: NVIDIA NVIDIA Orin NX Developer Kit/Jetson, BIOS 6.1-39721438 03/04/2025␍␊
[11:09:42:922] [ 0.258046] NET: Registered protocol family 16␍␊
[11:09:42:928] [ 0.258665] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations␍␊
[11:09:42:933] [ 0.258771] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations␍␊
[11:09:42:942] [ 0.258871] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations␍␊
[11:09:42:950] [ 0.258898] audit: initializing netlink subsys (disabled)␍␊
[11:09:42:956] [ 0.258975] audit: type=2000 audit(0.256:1): state=initialized audit_enabled=0 res=1␍␊
[11:09:42:964] [ 0.259158] thermal_sys: Registered thermal governor 'step_wise'␍␊
[11:09:42:970] [ 0.259160] thermal_sys: Registered thermal governor 'power_allocator'␍␊
[11:09:42:975] [ 0.259162] thermal_sys: Registered thermal governor 'pid_thermal_gov'␍␊
[11:09:42:981] [ 0.259921] cpuidle: using governor menu␍␊
[11:09:42:987] [ 0.260015] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.␍␊
[11:09:42:992] [ 0.260099] ASID allocator initialised with 32768 entries␍␊
[11:09:42:998] [ 0.260177] Serial: AMBA PL011 UART driver␍␊
[11:09:43:003] [ 0.261976] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful␍␊
[11:09:43:009] [ 0.261997] Tegra reboot handler registered.␍␊
[11:09:43:012] [ 0.279659] mc: mapped MMIO address: 0xffff800010b10000 -> 0x2c10000␍␊
[11:09:43:020] [ 0.279667] mc: mapped MMIO address: 0xffff800010b30000 -> 0x2c20000␍␊
[11:09:43:026] [ 0.279675] mc: mapped MMIO address: 0xffff800010b50000 -> 0x2c30000␍␊
[11:09:43:031] [ 0.279681] mc: mapped MMIO address: 0xffff800010b70000 -> 0x2c40000␍␊
[11:09:43:040] [ 0.279688] mc: mapped MMIO address: 0xffff800010b90000 -> 0x2c50000␍␊
[11:09:43:045] [ 0.279694] mc: mapped MMIO address: 0xffff800010bb0000 -> 0x2b80000␍␊
[11:09:43:051] [ 0.279700] mc: mapped MMIO address: 0xffff800010bd0000 -> 0x2b90000␍␊
[11:09:43:056] [ 0.279706] mc: mapped MMIO address: 0xffff800010bf0000 -> 0x2ba0000␍␊
[11:09:43:065] [ 0.279715] mc: mapped MMIO address: 0xffff800010c10000 -> 0x2bb0000␍␊
[11:09:43:070] [ 0.279721] mc: mapped MMIO address: 0xffff800010c30000 -> 0x1700000␍␊
[11:09:43:076] [ 0.279728] mc: mapped MMIO address: 0xffff800010c50000 -> 0x1710000␍␊
[11:09:43:085] [ 0.279734] mc: mapped MMIO address: 0xffff800010c70000 -> 0x1720000␍␊
[11:09:43:090] [ 0.279740] mc: mapped MMIO address: 0xffff800010c90000 -> 0x1730000␍␊
[11:09:43:096] [ 0.279748] mc: mapped MMIO address: 0xffff800010cb0000 -> 0x1740000␍␊
[11:09:43:101] [ 0.279754] mc: mapped MMIO address: 0xffff800010cd0000 -> 0x1750000␍␊
[11:09:43:110] [ 0.279759] mc: mapped MMIO address: 0xffff800010cf0000 -> 0x1760000␍␊
[11:09:43:115] [ 0.279764] mc: mapped MMIO address: 0xffff800010d10000 -> 0x1770000␍␊
[11:09:43:121] [ 0.279773] nv-tegra-mc 2c10000.mc: No mssnvlink node␍␊
[11:09:43:127] [ 0.279803] mc-err: mcerr ops are set to t23x␍␊
[11:09:43:132] [ 0.280450] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 68, base_baud = 0) is a SBSA␍␊
[11:09:43:141] [ 0.284217] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages␍␊
[11:09:43:146] [ 0.284221] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages␍␊
[11:09:43:152] [ 0.284222] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages␍␊
[11:09:43:160] [ 0.284224] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages␍␊
[11:09:43:166] [ 0.285954] ACPI: Interpreter disabled.␍␊
[11:09:43:171] [ 0.286423] ddr-vddq: supplied by vdd-5v␍␊
[11:09:43:174] [ 0.286594] ddr-vdd2: supplied by vdd-5v␍␊
[11:09:43:177] [ 0.286694] vdd-AO-1v2: supplied by vdd-5v␍␊
[11:09:43:183] [ 0.286791] vdd-3v3: supplied by vdd-5v␍␊
[11:09:43:185] [ 0.286890] vdd-rtc: supplied by vdd-AO-1v2␍␊
[11:09:43:191] [ 0.286985] vdd-0v95-uphy: supplied by vdd-AO-1v2␍␊
[11:09:43:194] [ 0.287068] vdd-0v95-hdmi: supplied by vdd-AO-1v2␍␊
[11:09:43:199] [ 0.287280] vdd-1v8: supplied by vdd-3v3-sys␍␊
[11:09:43:205] [ 0.287360] vdd-3v3-AO: supplied by vdd-5v-sys␍␊
[11:09:43:208] [ 0.287439] vdd-av10-hub: supplied by vdd-5v-sys␍␊
[11:09:43:213] [ 0.287537] vdd-vbus-a: supplied by vdd-5v-sys␍␊
[11:09:43:217] [ 0.287614] vdd-vbus-b: supplied by vdd-5v-sys␍␊
[11:09:43:222] [ 0.287688] vdd-3v3-dp: supplied by vdd-3v3-sys␍␊
[11:09:43:227] [ 0.287990] iommu: Default domain type: Translated ␍␊
[11:09:43:232] [ 0.288062] eventlib_kernel: keventlib is initialized, test id: 0␍␊
[11:09:43:239] [ 0.288223] SCSI subsystem initialized␍␊
[11:09:43:243] [ 0.288298] usbcore: registered new interface driver usbfs␍␊
[11:09:43:247] [ 0.288315] usbcore: registered new interface driver hub␍␊
[11:09:43:253] [ 0.288328] usbcore: registered new device driver usb␍␊
[11:09:43:258] [ 0.288501] mc: Linux media interface: v0.10␍␊
[11:09:43:261] [ 0.288513] videodev: Linux video capture interface: v2.00␍␊
[11:09:43:267] [ 0.288646] pps_core: LinuxPPS API ver. 1 registered␍␊
[11:09:43:274] [ 0.288649] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>␍␊
[11:09:43:280] [ 0.288656] PTP clock support registered␍␊
[11:09:43:286] [ 0.288878] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec␍␊
[11:09:43:292] [ 0.288915] tegra_wdt_t18x 2190000.watchdog: Registered successfully␍␊
[11:09:43:297] [ 0.290252] Registered efivars operations␍␊
[11:09:43:303] [ 0.290772] FPGA manager framework␍␊
[11:09:43:306] [ 0.290810] Advanced Linux Sound Architecture Driver Initialized.␍␊
[11:09:43:311] [ 0.291083] Bluetooth: Core ver 2.22␍␊
[11:09:43:317] [ 0.291097] NET: Registered protocol family 31␍␊
[11:09:43:320] [ 0.291098] Bluetooth: HCI device and connection manager initialized␍␊
[11:09:43:325] [ 0.291104] Bluetooth: HCI socket layer initialized␍␊
[11:09:43:331] [ 0.291108] Bluetooth: L2CAP socket layer initialized␍␊
[11:09:43:336] [ 0.291114] Bluetooth: SCO socket layer initialized␍␊
[11:09:43:342] [ 0.291847] camchar: rtcpu character device driver loaded␍␊
[11:09:43:348] [ 0.292070] clocksource: Switched to clocksource arch_sys_counter␍␊
[11:09:43:353] [ 0.441219] VFS: Disk quotas dquot_6.6.0␍␊
[11:09:43:356] [ 0.441254] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)␍␊
[11:09:43:364] [ 0.441772] pnp: PnP ACPI: disabled␍␊
[11:09:43:368] [ 0.443560] la/ptsa driver initialized.␍␊
[11:09:43:371] [ 0.443621] NET: Registered protocol family 2␍␊
[11:09:43:376] [ 0.443830] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)␍␊
[11:09:43:384] [ 0.446057] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)␍␊
[11:09:43:392] [ 0.446084] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)␍␊
[11:09:43:401] [ 0.446195] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)␍␊
[11:09:43:406] [ 0.446697] TCP: Hash tables configured (established 131072 bind 65536)␍␊
[11:09:43:415] [ 0.446772] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)␍␊
[11:09:43:420] [ 0.446803] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)␍␊
[11:09:43:429] [ 0.446908] NET: Registered protocol family 1␍␊
[11:09:43:435] [ 0.447174] RPC: Registered named UNIX socket transport module.␍␊
[11:09:43:439] [ 0.447177] RPC: Registered udp transport module.␍␊
[11:09:43:443] [ 0.447179] RPC: Registered tcp transport module.␍␊
[11:09:43:449] [ 0.447180] RPC: Registered tcp NFSv4.1 backchannel transport module.␍␊
[11:09:43:454] [ 0.447188] PCI: CLS 0 bytes, default 64␍␊
[11:09:43:460] [ 0.447310] Trying to unpack rootfs image as initramfs...␍␊
[11:09:43:463] [ 0.670988] Freeing initrd memory: 21816K␍␊
[11:09:43:468] [ 0.672763] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available␍␊
[11:09:43:476] [ 0.672893] kvm [1]: IPA Size Limit: 48 bits␍␊
[11:09:43:480] [ 0.672916] kvm [1]: GICv3: no GICV resource entry␍␊
[11:09:43:485] [ 0.672920] kvm [1]: disabling GICv2 emulation␍␊
[11:09:43:491] [ 0.672937] kvm [1]: GIC system register CPU interface enabled␍␊
[11:09:43:496] [ 0.673006] kvm [1]: vgic interrupt IRQ9␍␊
[11:09:43:499] [ 0.673119] kvm [1]: VHE mode initialized successfully␍␊
[11:09:43:504] [ 0.673780] Initialise system trusted keyrings␍␊
[11:09:43:507] [ 0.673863] workingset: timestamp_bits=46 max_order=22 bucket_order=0␍␊
[11:09:43:516] [ 0.676034] squashfs: version 4.0 (2009/01/31) Phillip Lougher␍␊
[11:09:43:521] [ 0.676351] NFS: Registering the id_resolver key type␍␊
[11:09:43:527] [ 0.676364] Key type id_resolver registered␍␊
[11:09:43:530] [ 0.676366] Key type id_legacy registered␍␊
[11:09:43:535] [ 0.676396] nfs4filelayout_init: NFSv4 File Layout Driver Registering...␍␊
[11:09:43:541] [ 0.676403] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...␍␊
[11:09:43:549] [ 0.676416] ntfs: driver 2.1.32 [Flags: R/W].␍␊
[11:09:43:554] [ 0.687984] NET: Registered protocol family 38␍␊
[11:09:43:559] [ 0.687989] Key type asymmetric registered␍␊
[11:09:43:563] [ 0.687993] Asymmetric key parser 'x509' registered␍␊
[11:09:43:566] [ 0.688015] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 239)␍␊
[11:09:43:574] [ 0.688083] io scheduler mq-deadline registered␍␊
[11:09:43:578] [ 0.688087] io scheduler kyber registered␍␊
[11:09:43:583] [ 0.691636] tegra-pwm 3280000.pwm: PWM clk can sleep in ops␍␊
[11:09:43:589] [ 0.691662] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops␍␊
[11:09:43:594] [ 0.691679] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops␍␊
[11:09:43:600] [ 0.691691] tegra-pwm 32e0000.pwm: PWM clk can sleep in ops␍␊
[11:09:43:605] [ 0.692444] efifb: probing for efifb␍␊
[11:09:43:608] [ 0.692473] efifb: framebuffer at 0x479e00000, using 8640k, total 8640k␍␊
[11:09:43:614] [ 0.692475] efifb: mode is 1920x1080x32, linelength=8192, pages=1␍␊
[11:09:43:622] [ 0.692477] efifb: scrolling: redraw␍␊
[11:09:43:625] [ 0.692479] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0␍␊
[11:09:43:631] [ 0.695496] Console: switching to colour frame buffer device 240x67␍␊
[11:09:43:636] [ 0.698234] fb0: EFI VGA frame buffer device␍␊
[11:09:43:642] [ 0.699759] tegra_dc_assign_hw_data: no matching compatible node␍␊
[11:09:43:647] [ 0.699762] tegradccommon module_init failed␍␊
[11:09:43:650] [ 0.699764] tegradc module_init failed␍␊
[11:09:43:656] [ 0.700001] EINJ: ACPI disabled.␍␊
[11:09:43:658] [ 0.701455] tegra-pmc c360000.pmc: scratch reg offset dts data not present␍␊
[11:09:43:664] [ 0.701462] tegra-pmc: ### PMC reset source: MAINSWRST␍␊
[11:09:43:670] [ 0.701465] tegra-pmc: ### PMC reset level: L1␍␊
[11:09:43:675] [ 0.701468] tegra-pmc: ### PMC reset status reg: 0x2d␍␊
[11:09:43:681] [ 0.702610] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled␍␊
[11:09:43:687] [ 2.150982] printk: console [ttyTCU0] enabled␍␊
[11:09:43:690] [ 2.155671] arm-smmu 12000000.iommu: probing hardware configuration...␍␊
[11:09:43:698] [ 2.161558] arm-smmu 12000000.iommu: SMMUv2 with:␍␊
[11:09:43:701] [ 2.166281] arm-smmu 12000000.iommu: ⇥ stage 1 translation␍␊
[11:09:43:706] [ 2.171629] arm-smmu 12000000.iommu: ⇥ stage 2 translation␍␊
[11:09:43:712] [ 2.177129] arm-smmu 12000000.iommu: ⇥ nested translation␍␊
[11:09:43:718] [ 2.182474] arm-smmu 12000000.iommu: ⇥ stream matching with 128 register groups␍␊
[11:09:43:726] [ 2.189471] arm-smmu 12000000.iommu: ⇥ 128 context banks (0 stage-2 only)␍␊
[11:09:43:731] [ 2.198178] arm-smmu 12000000.iommu: ⇥ Supported page sizes: 0x00001000␍␊
[11:09:43:740] [ 2.202592] arm-smmu 12000000.iommu: ⇥ Stage-1: 48-bit VA -> 48-bit IPA␍␊
[11:09:43:746] [ 2.209155] arm-smmu 12000000.iommu: ⇥ Stage-2: 48-bit IPA -> 48-bit PA␍␊
[11:09:43:751] [ 2.216354] arm-smmu 10000000.iommu: probing hardware configuration...␍␊
[11:09:43:759] [ 2.222018] arm-smmu 10000000.iommu: SMMUv2 with:␍␊
[11:09:43:763] [ 2.226740] arm-smmu 10000000.iommu: ⇥ stage 1 translation␍␊
[11:09:43:768] [ 2.232255] arm-smmu 10000000.iommu: ⇥ stage 2 translation␍␊
[11:09:43:774] [ 2.237679] arm-smmu 10000000.iommu: ⇥ nested translation␍␊
[11:09:43:780] [ 2.243104] arm-smmu 10000000.iommu: ⇥ stream matching with 128 register groups␍␊
[11:09:43:787] [ 2.250280] arm-smmu 10000000.iommu: ⇥ 128 context banks (0 stage-2 only)␍␊
[11:09:43:793] [ 2.259020] arm-smmu 10000000.iommu: ⇥ Supported page sizes: 0x00001000␍␊
[11:09:43:798] [ 2.263493] arm-smmu 10000000.iommu: ⇥ Stage-1: 48-bit VA -> 48-bit IPA␍␊
[11:09:43:807] [ 2.270053] arm-smmu 10000000.iommu: ⇥ Stage-2: 48-bit IPA -> 48-bit PA␍␊
[11:09:43:813] [ 2.277042] arm-smmu 8000000.iommu: probing hardware configuration...␍␊
[11:09:43:819] [ 2.283181] arm-smmu 8000000.iommu: SMMUv2 with:␍␊
[11:09:43:824] [ 2.287905] arm-smmu 8000000.iommu: ⇥ stage 1 translation␍␊
[11:09:43:830] [ 2.293416] arm-smmu 8000000.iommu: ⇥ stage 2 translation␍␊
[11:09:43:835] [ 2.298841] arm-smmu 8000000.iommu: ⇥ nested translation␍␊
[11:09:43:841] [ 2.304005] arm-smmu 8000000.iommu: ⇥ stream matching with 128 register groups␍␊
[11:09:43:846] [ 2.311179] arm-smmu 8000000.iommu: ⇥ 128 context banks (0 stage-2 only)␍␊
[11:09:43:856] [ 2.319888] arm-smmu 8000000.iommu: ⇥ Supported page sizes: 0x00001000␍␊
[11:09:43:860] [ 2.324393] arm-smmu 8000000.iommu: ⇥ Stage-1: 48-bit VA -> 48-bit IPA␍␊
[11:09:43:866] [ 2.330955] arm-smmu 8000000.iommu: ⇥ Stage-2: 48-bit IPA -> 48-bit PA␍␊
[11:09:43:874] [ 2.338224] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful␍␊
[11:09:43:880] [ 2.346940] tegra_profiler: version: 1.151, samples/io: 51/30␍␊
[11:09:43:889] [ 2.351194] tegra_profiler: auth: init␍␊
[11:09:43:891] [ 2.355225] nvsciipc: loaded module␍␊
[11:09:43:894] [ 2.359522] tegra23x-qspi 3270000.spi: Adding to iommu group 0␍␊
[11:09:43:900] [ 2.364625] tegra23x-qspi 3270000.spi: Node prod_c_nonsecure has invalid entries␍␊
[11:09:43:908] [ 2.371907] tegra23x-qspi 3270000.spi: Node prod_c_nonsecure: Child has not proper setting␍␊
[11:09:43:916] [ 2.380129] tegra23x-qspi 3270000.spi: Node spi: Faild to read the Prod Setting.␍␊
[11:09:43:922] [ 2.387567] tegra23x-qspi 3270000.spi: Prod settings list not found␍␊
[11:09:43:930] [ 2.394382] tun: Universal TUN/TAP device driver, 1.6␍␊
[11:09:43:936] [ 2.399360] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version␍␊
[11:09:43:941] [ 2.406208] hns3: Copyright (c) 2017 Huawei Corporation.␍␊
[11:09:43:947] [ 2.411739] e1000e: Intel(R) PRO/1000 Network Driver␍␊
[11:09:43:952] [ 2.416707] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.␍␊
[11:09:43:958] [ 2.422584] igb: Intel(R) Gigabit Ethernet Network Driver␍␊
[11:09:43:964] [ 2.427905] igb: Copyright (c) 2007-2014 Intel Corporation.␍␊
[11:09:43:970] [ 2.433646] PPP generic driver version 2.4.2␍␊
[11:09:43:972] [ 2.437837] PPP BSD Compression module registered␍␊
[11:09:43:978] [ 2.442521] PPP Deflate Compression module registered␍␊
[11:09:43:983] [ 2.447686] PPP MPPE Compression module registered␍␊
[11:09:43:989] [ 2.452689] usbcore: registered new interface driver r8152␍␊
[11:09:43:995] [ 2.458015] usbcore: registered new interface driver asix␍␊
[11:09:44:000] [ 2.463526] usbcore: registered new interface driver ax88179_178a␍␊
[11:09:44:006] [ 2.469650] usbcore: registered new interface driver cdc_ether␍␊
[11:09:44:011] [ 2.475599] usbcore: registered new interface driver net1080␍␊
[11:09:44:017] [ 2.481199] usbcore: registered new interface driver cdc_subset␍␊
[11:09:44:023] [ 2.487236] usbcore: registered new interface driver zaurus␍␊
[11:09:44:028] [ 2.492928] usbcore: registered new interface driver cdc_ncm␍␊
[11:09:44:034] [ 2.498612] usbcore: registered new interface driver aqc111␍␊
[11:09:44:039] [ 2.504148] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver␍␊
[11:09:44:045] [ 2.510337] ohci-pci: OHCI PCI platform driver␍␊
[11:09:44:051] [ 2.514633] ohci-platform: OHCI generic platform driver␍␊
[11:09:44:056] [ 2.519971] tegra-xusb 3610000.xhci: Adding to iommu group 1␍␊
[11:09:44:062] [ 2.525960] usbcore: registered new interface driver uas␍␊
[11:09:44:067] [ 2.530912] usbcore: registered new interface driver usb-storage␍␊
[11:09:44:073] [ 2.536957] mousedev: PS/2 mouse device common for all mice␍␊
[11:09:44:079] [ 2.542375] usbcore: registered new interface driver xpad␍␊
[11:09:44:084] [ 2.549620] tegra_rtc c2a0000.rtc: registered as rtc1␍␊
[11:09:44:090] [ 2.553214] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:32 UTC (32)␍␊
[11:09:44:096] [ 2.560917] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock␍␊
[11:09:44:104] [ 2.567262] i2c /dev entries driver␍␊
[11:09:44:107] [ 2.570731] tegra-i2c 3160000.i2c: Adding to iommu group 2␍␊
[11:09:44:112] [ 2.576276] tegra-i2c c240000.i2c: Adding to iommu group 2␍␊
[11:09:44:118] [ 2.581637] tegra-i2c 3180000.i2c: Adding to iommu group 2␍␊
[11:09:44:123] [ 2.587127] tegra-i2c 3190000.i2c: Adding to iommu group 2␍␊
[11:09:44:129] [ 2.592541] tegra-i2c 31b0000.i2c: Adding to iommu group 2␍␊
[11:09:44:135] [ 2.597896] tegra-i2c 31c0000.i2c: Adding to iommu group 2␍␊
[11:09:44:140] [ 2.603389] tegra-i2c c250000.i2c: Adding to iommu group 2␍␊
[11:09:44:146] [ 2.608736] tegra-i2c 31e0000.i2c: Adding to iommu group 2␍␊
[11:09:44:152] [ 2.616371] pps pps0: new PPS source ktimer␍␊
[11:09:44:154] [ 2.618304] pps pps0: ktimer PPS source registered␍␊
[11:09:44:160] [ 2.623124] pps_ldisc: PPS line discipline registered␍␊
[11:09:44:165] [ 2.628283] pps_parport: parallel port PPS client␍␊
[11:09:44:168] [ 2.636555] device-mapper: uevent: version 1.0.3␍␊
[11:09:44:174] [ 2.637468] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com␍␊
[11:09:44:182] [ 2.647097] sdhci: Secure Digital Host Controller Interface driver␍␊
[11:09:44:188] [ 2.652353] sdhci: Copyright(c) Pierre Ossman␍␊
[11:09:44:193] [ 2.656829] Synopsys Designware Multimedia Card Interface Driver␍␊
[11:09:44:199] [ 2.662918] sdhci-pltfm: SDHCI platform and OF driver helper␍␊
[11:09:44:205] [ 2.668998] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401␍␊
[11:09:44:210] [ 2.676316] tegra-bpmp bpmp: firmware: dc3fd3cac60f9b918e11-da583751bbf␍␊
[11:09:44:219] [ 2.683163] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9 ␍␊
[11:09:44:223] [ 2.687753] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x82␍␊
[11:09:44:227] [ 2.698997] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0␍␊
[11:09:44:233] [ 2.699182] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful␍␊
[11:09:44:454] <0xff><0xe2>debugfs initialized␍␊
[11:09:45:343] <0xff><0xe1>[ 3.896416] hid: raw HID events driver (C) Jiri Kosina␍␊
[11:09:45:345] [ 3.897030] usbcore: registered new interface driver usbhid␍␊
[11:09:45:355] [ 3.897215] usbhid: USB HID core driver␍␊
[11:09:45:362] [ 3.897714] tegra-dce d800000.dce: Adding to iommu group 3␍␊
[11:09:45:362] [ 3.898834] dce: dce_ipc_channel_init:319 Invalid Channel State [0x0] for ch_type [2]␍␊
[11:09:45:370] [ 3.899440] tegra234-aon c000000.aon: Adding to iommu group 4␍␊
[11:09:45:378] [ 3.900464] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x5]␍␊
[11:09:45:384] [ 3.900749] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [0]. Ignored...␍␊
[11:09:45:393] [ 3.901006] dce: dce_admin_send_cmd_ver:424 version : [0x2] err : [0x0]␍␊
[11:09:45:399] [ 3.901312] c000000.aon:hsp: probed␍␊
[11:09:45:404] [ 3.901426] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x1]␍␊
[11:09:45:412] [ 3.901690] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [1] ...␍␊
[11:09:45:421] [ 3.901693] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [1]. Ignored...␍␊
[11:09:45:429] [ 3.901709] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [1]. Ignored...␍␊
[11:09:45:438] [ 3.901904] dce: dce_admin_setup_clients_ipc:529 Get queue info failed for [2]␍␊
[11:09:45:443] [ 3.902142] tegra234-aon c000000.aon: init done␍␊
[11:09:45:449] [ 3.902392] tegra23x-psc e860000.psc: Adding to iommu group 5␍␊
[11:09:45:454] [ 3.918576] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x2]␍␊
[11:09:45:463] [ 3.924391] tegra23x-psc e860000.psc: ext_cfg base:0000000076fc6daa␍␊
[11:09:45:468] [ 3.927413] dce: dce_admin_setup_clients_ipc:553 Channel Reset Complete for Type [3] ...␍␊
[11:09:45:477] [ 3.927419] dce: dce_admin_ipc_handle_signal:90 Spurious signal on channel: [3]. Ignored...␍␊
[11:09:45:485] [ 3.933533] tegra23x-psc e860000.psc: init done␍␊
[11:09:45:492] [ 3.941987] dce: dce_start_boot_flow:173 DCE_BOOT_DONE␍␊
[11:09:45:498] [ 3.950438] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 6␍␊
[11:09:45:503] [ 3.967461] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000␍␊
[11:09:45:510] [ 3.978418] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584␍␊
[11:09:45:519] [ 3.983542] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900␍␊
[11:09:45:530] [ 3.994474] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80␍␊
[11:09:45:541] [ 4.005424] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80␍␊
[11:09:45:553] [ 4.016613] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80␍␊
[11:09:45:564] [ 4.028338] tegra-ivc-bu<0xff><0xe4>I<0xff><0xe1>s b<0xff><0xe4>/T<0xff><0xe1>c00<0xff><0xe4>C: <0xff><0xe1>000<0xff><0xe4>Res<0xff><0xe1>.rt<0xff><0xe4>erv<0xff><0xe1>cpu<0xff><0xe4>ed <0xff><0xe1>:iv<0xff><0xe4>sha<0xff><0xe1>c-b<0xff><0xe4>re<0xff><0xe1>us:<0xff><0xe4>d m<0xff><0xe1>ivc<0xff><0xe4>emo<0xff><0xe1>cap<0xff><0xe4>ry <0xff><0xe1>tur<0xff><0xe4>is <0xff><0xe1>e@4<0xff><0xe4>dis<0xff><0xe1>: i<0xff><0xe4>ab<0xff><0xe1>vcc<0xff><0xe4>led<0xff><0xe1>apt<0xff><0xe4>␍␊
[11:09:45:583] <0xff><0xe1>ure<0xff><0xe4><0xff><0xe1>: v<0xff><0xe4>I/T<0xff><0xe1>er=<0xff><0xe4>C:<0xff><0xe1>0 g<0xff><0xe4> Dy<0xff><0xe1>rp=<0xff><0xe4>nam<0xff><0xe1>1 R<0xff><0xe4>ic <0xff><0xe1>X[5<0xff><0xe4>sha<0xff><0xe1>12x<0xff><0xe4>red<0xff><0xe1>64]<0xff><0xe4> m<0xff><0xe1>=0x<0xff><0xe4>emo<0xff><0xe1>ff8<0xff><0xe4>ry <0xff><0xe1>0-0<0xff><0xe4>is <0xff><0xe1>x18<0xff><0xe4>ena<0xff><0xe1>000<0xff><0xe4>ble<0xff><0xe1> TX<0xff><0xe4>d␍<0xff><0xe1>[51<0xff><0xe4>␊
[11:09:45:594] <0xff><0xe1>2x6<0xff><0xe4><0xff><0xe1>4]=<0xff><0xe4>I/<0xff><0xe1>0x1<0xff><0xe4>TC:<0xff><0xe1>800<0xff><0xe4> No<0xff><0xe1>0-0<0xff><0xe4>rma<0xff><0xe1>x20<0xff><0xe4>l W<0xff><0xe1>080<0xff><0xe4>or<0xff><0xe1>␍␊
[11:09:45:600] <0xff><0xe4>ld <0xff><0xe1>[ <0xff><0xe4>vir<0xff><0xe1> 4<0xff><0xe4>tua<0xff><0xe1>.04<0xff><0xe4>li<0xff><0xe1>082<0xff><0xe4>zat<0xff><0xe1>8] <0xff><0xe4>ion<0xff><0xe1>teg<0xff><0xe4> su<0xff><0xe1>ra-<0xff><0xe4>ppo<0xff><0xe1>ivc<0xff><0xe4>rt <0xff><0xe1>-bu<0xff><0xe4>is<0xff><0xe1>s b<0xff><0xe4> di<0xff><0xe1>c00<0xff><0xe4>sab<0xff><0xe1>000<0xff><0xe4>led<0xff><0xe1>.rt<0xff><0xe4>␍␊
[11:09:45:611] <0xff><0xe1>cpu<0xff><0xe4><0xff><0xe1>:iv<0xff><0xe4>I/<0xff><0xe1>c-b<0xff><0xe4>TC:<0xff><0xe1>us:<0xff><0xe4> As<0xff><0xe1>dia<0xff><0xe4>ync<0xff><0xe1>g@5<0xff><0xe4>hro<0xff><0xe1>: d<0xff><0xe4>no<0xff><0xe1>iag<0xff><0xe4>us <0xff><0xe1>: v<0xff><0xe4>not<0xff><0xe1>er=<0xff><0xe4>ifi<0xff><0xe1>0 g<0xff><0xe4>cat<0xff><0xe1>rp=<0xff><0xe4>ion<0xff><0xe1>1 R<0xff><0xe4>s <0xff><0xe1>X[1<0xff><0xe4>are<0xff><0xe1>x64<0xff><0xe4> di<0xff><0xe1>]=0<0xff><0xe4>sab<0xff><0xe1>x20<0xff><0xe4>led<0xff><0xe1>080<0xff><0xe4>␍␊
[11:09:45:625] <0xff><0xe1>-0x20140 TX[1x64]=0x20140-0x20200␍␊
[11:09:45:631] [ 4.052451] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (116)␍␊
[11:09:45:636] [ 4.058914] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful␍␊
[11:09:45:645] [ 4.067242] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=07158d6a2d3d02920f5ae2c585e6b8912c204c81␍␊
[11:09:45:656] [ 4.079856] t19x_cache tegra-cache: probed␍␊
[11:09:45:660] [ 4.082298] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU␍␊
[11:09:45:664] [ 4.096946] optee: probing for conduit method.␍␊
[11:09:45:670] [ 4.097085] optee: revision 3.22 (eb8130c7)␍␊
[11:09:45:673] [ 4.156858] optee: dynamic shared memory is enabled␍␊
[11:09:45:679] [ 4.157201] optee: initialized driver␍␊
[11:09:45:681] [ 4.171484] nvpmodel: initialized successfully␍␊
[11:09:45:687] [ 4.171717] tegra_hv: get_hvd: not initialized yet␍␊
[11:09:45:693] [ 4.171844] user_ivc_mempool: hypervisor not present␍␊
[11:09:45:695] [ 4.172598] usbcore: registered new interface driver snd-usb-audio␍␊
[11:09:45:704] [ 4.173795] u32 classifier␍␊
[11:09:45:707] [ 4.173888] input device check on␍␊
[11:09:45:709] [ 4.173998] Actions configured␍␊
[11:09:45:712] [ 4.176660] Initializing XFRM netlink socket␍␊
[11:09:45:718] [ 4.181368] NET: Registered protocol family 10␍␊
[11:09:45:720] [ 4.186496] Segment Routing with IPv6␍␊
[11:09:45:726] [ 4.188990] NET: Registered protocol family 17␍␊
[11:09:45:729] [ 4.193331] NET: Registered protocol family 15␍␊
[11:09:45:735] [ 4.197742] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.␍␊
[11:09:45:746] [ 4.211441] Bluetooth: RFCOMM socket layer initialized␍␊
[11:09:45:752] [ 4.216009] Bluetooth: RFCOMM ver 1.11␍␊
[11:09:45:757] [ 4.219923] Bluetooth: HIDP (Human Interface Emulation) ver 1.2␍␊
[11:09:45:763] [ 4.225780] Bluetooth: HIDP socket layer initialized␍␊
[11:09:45:768] [ 4.231751] 9pnet: Installing 9P2000 support␍␊
[11:09:45:772] [ 4.235201] Key type dns_resolver registered␍␊
[11:09:45:777] [ 4.240533] registered taskstats version 1␍␊
[11:09:45:782] [ 4.243643] Loading compiled-in X.509 certificates␍␊
[11:09:45:786] [ 4.258605] Loaded X.509 cert 'Build time autogenerated kernel key: 0a3815b51bd47bcec671076498506de098bec793'␍␊
[11:09:45:793] [ 4.259611] tegra194-pcie 14100000.pcie: Adding to iommu group 7␍␊
[11:09:45:802] [ 4.271085] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator␍␊
[11:09:45:807] [ 4.272280] tegra194-pcie 14160000.pcie: Adding to iommu group 8␍␊
[11:09:45:813] [ 4.282967] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator␍␊
[11:09:45:819] [ 4.283549] tegra194-pcie 141e0000.pcie: Adding to iommu group 9␍␊
[11:09:45:824] [ 4.294568] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator␍␊
[11:09:45:833] [ 4.295308] tegra194-pcie 140a0000.pcie: Adding to iommu group 10␍␊
[11:09:45:838] [ 4.307031] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator␍␊
[11:09:45:844] [ 4.308360] tegra194-pcie 140c0000.pcie: Adding to iommu group 11␍␊
[11:09:45:849] [ 4.319581] tegra194-pcie 140c0000.pcie: Using GICv2m MSI allocator␍␊
[11:09:45:855] [ 4.346211] tegra-soc-hwpm f100000.tegra_soc_hwpm: Adding to iommu group 12␍␊
[11:09:45:863] [ 4.351269] simple-framebuffer chosen:framebuffer: framebuffer at 0x479e00000, 0x870000 bytes, mapped to 0x0000000078a9a38b␍␊
[11:09:45:875] [ 4.351555] simple-framebuffer chosen:framebuffer: format=x8r8g8b8, mode=1920x1080x32, linelength=8192␍␊
[11:09:45:883] [ 4.351809] fb0: switching to simple from EFI VGA␍␊
[11:09:45:889] [ 4.352343] Console: switching to colour dummy device 80x25␍␊
[11:09:45:894] [ 4.361039] Console: switching to colour frame buffer device 240x67␍␊
[11:09:45:900] [ 4.364201] simple-framebuffer chosen:framebuffer: fb0: simplefb registered!␍␊
[11:09:45:908] [ 4.371397] host1x 13e40000.host1x: Adding to iommu group 13␍␊
[11:09:45:914] [ 4.396105] host1x 13e40000.host1x: initialized␍␊
[11:09:45:918] [ 4.396627] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 14␍␊
[11:09:45:925] [ 4.397093] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)␍␊
[11:09:45:936] [ 4.399779] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 15␍␊
[11:09:45:944] [ 4.407205] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)␍␊
[11:09:45:953] [ 4.417666] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 16␍␊
[11:09:45:961] [ 4.425071] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)␍␊
[11:09:45:972] [ 4.435631] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 17␍␊
[11:09:45:982] [ 4.443152] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)␍␊
[11:09:45:989] [ 4.453466] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 18␍␊
[11:09:45:998] [ 4.461008] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)␍␊
[11:09:46:009] [ 4.471485] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 19␍␊
[11:09:46:015] [ 4.479029] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)␍␊
[11:09:46:026] [ 4.489547] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 20␍␊
[11:09:46:034] [ 4.497099] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)␍␊
[11:09:46:047] [ 4.507558] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 21␍␊
[11:09:46:051] [ 4.515082] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)␍␊
[11:09:46:062] [ 4.525631] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 22␍␊
[11:09:46:070] [ 4.533117] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)␍␊
[11:09:46:079] [ 4.543599] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 23␍␊
[11:09:46:087] [ 4.551123] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)␍␊
[11:09:46:099] [ 4.561660] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 24␍␊
[11:09:46:107] [ 4.569162] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)␍␊
[11:09:46:115] [ 4.579669] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 25␍␊
[11:09:46:124] [ 4.587168] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)␍␊
[11:09:46:135] [ 4.597682] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 26␍␊
[11:09:46:141] [ 4.605242] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)␍␊
[11:09:46:152] [ 4.615718] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 27␍␊
[11:09:46:160] [ 4.623240] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)␍␊
[11:09:46:171] [ 4.633715] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 28␍␊
[11:09:46:177] [ 4.641274] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)␍␊
[11:09:46:188] [ 4.651774] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 29␍␊
[11:09:46:197] [ 4.659271] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)␍␊
[11:09:46:205] [ 4.669804] falcon 15340000.vic: Adding to iommu group 30␍␊
[11:09:46:211] [ 4.683489] falcon 15340000.vic: initialized␍␊
[11:09:46:216] [ 4.683969] falcon 15380000.nvjpg: Adding to iommu group 31␍␊
[11:09:46:222] [ 4.690333] falcon 15380000.nvjpg: initialized␍␊
[11:09:46:227] [ 4.690588] falcon 15540000.nvjpg1: Adding to iommu group 32␍␊
[11:09:46:233] [ 4.700213] falcon 15540000.nvjpg1: initialized␍␊
[11:09:46:236] [ 4.700477] falcon 154c0000.nvenc: Adding to iommu group 33␍␊
[11:09:46:241] [ 4.713696] falcon 154c0000.nvenc: initialized␍␊
[11:09:46:247] [ 4.713955] falcon 15a50000.ofa: Adding to iommu group 34␍␊
[11:09:46:253] [ 4.721754] falcon 15a50000.ofa: initialized␍␊
[11:09:46:256] [ 4.722008] nvdec 15480000.nvdec: Adding to iommu group 35␍␊
[11:09:46:261] [ 4.738168] nvdec 15480000.nvdec: initialized␍␊
[11:09:46:267] [ 4.738427] tsec 15500000.tsec: Adding to iommu group 36␍␊
[11:09:46:272] [ 4.747321] tsec 15500000.tsec: initialized␍␊
[11:09:46:276] [ 4.750234] gic 2a41000.agic-controller: GIC IRQ controller registered␍␊
[11:09:46:283] [ 4.758971] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered␍␊
[11:09:46:289] [ 4.768805] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio␍␊
[11:09:46:295] [ 4.769729] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon␍␊
[11:09:46:303] [ 4.770083] tegra-pwm 3280000.pwm: PWM clk can sleep in ops␍␊
[11:09:46:308] [ 4.772368] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops␍␊
[11:09:46:314] [ 4.777974] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops␍␊
[11:09:46:320] [ 4.783403] tegra-pwm 32e0000.pwm: PWM clk can sleep in ops␍␊
[11:09:46:325] [ 4.790591] tegra194-isp5 14800000.isp: Adding to iommu group 37␍␊
[11:09:46:331] [ 4.797647] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU␍␊
[11:09:46:339] [ 4.803652] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized␍␊
[11:09:46:345] [ 4.809504] driver not enabled, cannot register any devices␍␊
[11:09:46:350] [ 4.815426] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 38␍␊
[11:09:46:359] [ 4.823010] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 39␍␊
[11:09:46:365] [ 4.830299] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: Adding to iommu group 38␍␊
[11:09:46:373] [ 4.837796] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized␍␊
[11:09:46:382] [ 4.844061] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: Adding to iommu group 39␍␊
[11:09:46:387] [ 4.851849] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized␍␊
[11:09:46:395] [ 4.858113] scare-pigeon 13e40000.host1x:isp-thi@14b00000: Adding to iommu group 37␍␊
[11:09:46:401] [ 4.866103] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized␍␊
[11:09:46:410] [ 4.872563] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: Adding to iommu group 40␍␊
[11:09:46:418] [ 4.880768] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: initialized (streamid=18, iommu=smmu.0x0000000008000000)␍␊
[11:09:46:429] [ 4.891483] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: Adding to iommu group 41␍␊
[11:09:46:442] [ 4.900009] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: initialized (streamid=19, iommu=smmu.0x0000000008000000)␍␊
[11:09:46:446] [ 4.910737] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: Adding to iommu group 42␍␊
[11:09:46:454] [ 4.919090] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: initialized (streamid=20, iommu=smmu.0x0000000008000000)␍␊
[11:09:46:465] [ 4.929979] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: Adding to iommu group 43␍␊
[11:09:46:474] [ 4.938338] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: initialized (streamid=21, iommu=smmu.0x0000000008000000)␍␊
[11:09:46:485] [ 4.949063] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: Adding to iommu group 44␍␊
[11:09:46:494] [ 4.957555] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: initialized (streamid=22, iommu=smmu.0x0000000008000000)␍␊
[11:09:46:505] [ 4.968303] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: Adding to iommu group 45␍␊
[11:09:46:513] [ 4.976816] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: initialized (streamid=23, iommu=smmu.0x0000000008000000)␍␊
[11:09:46:524] [ 4.987560] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: Adding to iommu group 46␍␊
[11:09:46:532] [ 4.996055] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: initialized (streamid=24, iommu=smmu.0x0000000008000000)␍␊
[11:09:46:544] [ 5.006813] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: Adding to iommu group 47␍␊
[11:09:46:552] [ 5.015314] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: initialized (streamid=25, iommu=smmu.0x0000000008000000)␍␊
[11:09:46:563] [ 5.026052] pva 16000000.pva0: Adding to iommu group 48␍␊
[11:09:46:569] [ 5.036219] pva 16000000.pva0: initialized␍␊
[11:09:46:573] [ 5.042153] nvdla 15880000.nvdla0: Adding to iommu group 49␍␊
[11:09:46:578] [ 5.047523] nvdla 15880000.nvdla0: initialized␍␊
[11:09:46:583] [ 5.048370] nvdla 158c0000.nvdla1: Adding to iommu group 50␍␊
[11:09:46:589] [ 5.056199] nvdla 158c0000.nvdla1: initialized␍␊
[11:09:46:592] [ 5.056966] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 2␍␊
[11:09:46:597] [ 5.062595] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels␍␊
[11:09:46:605] [ 5.068913] tegra-fuse-burn efuse-burn: shutdown limit check disabled␍␊
[11:09:46:611] [ 5.075225] tegra-fuse-burn efuse-burn: Fuse burn driver initialized␍␊
[11:09:46:619] [ 5.081828] serial-tegra 3100000.serial: Adding to iommu group 2␍␊
[11:09:46:625] [ 5.088098] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 17, base_baud = 0) is a TEGRA_UART␍␊
[11:09:46:634] [ 5.097394] serial-tegra 3110000.serial: Adding to iommu group 2␍␊
[11:09:46:639] [ 5.102858] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 65, base_baud = 0) is a TEGRA_UART␍␊
[11:09:46:647] [ 5.111971] serial-tegra 3130000.serial: Adding to iommu group 2␍␊
[11:09:46:653] [ 5.117713] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 66, base_baud = 0) is a TEGRA_UART␍␊
[11:09:46:661] [ 5.126745] serial-tegra 3140000.serial: Adding to iommu group 2␍␊
[11:09:46:670] [ 5.132437] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 67, base_baud = 0) is a TEGRA_UART␍␊
[11:09:46:678] [ 5.141775] tegra23x-qspi 3270000.spi: Node prod_c_nonsecure has invalid entries␍␊
[11:09:46:684] [ 5.148382] tegra23x-qspi 3270000.spi: Node prod_c_nonsecure: Child has not proper setting␍␊
[11:09:46:692] [ 5.156776] tegra23x-qspi 3270000.spi: Node spi: Faild to read the Prod Setting.␍␊
[11:09:46:701] [ 5.164212] tegra23x-qspi 3270000.spi: Prod settings list not found␍␊
[11:09:46:707] [ 5.194859] tegra-xusb 3610000.xhci: Firmware timestamp: 2023-02-10 03:48:10 UTC, Version: 80.05 release␍␊
[11:09:46:717] [ 5.195114] tegra-xusb 3610000.xhci: xHCI Host Controller␍␊
[11:09:46:727] [ 5.195278] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1␍␊
[11:09:46:729] [ 5.196320] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810␍␊
[11:09:46:740] [ 5.202479] tegra-xusb 3610000.xhci: irq 232, io mem 0x03610000␍␊
[11:09:46:746] [ 5.208580] tegra-xusb 3610000.xhci: xHCI Host Controller␍␊
[11:09:46:751] [ 5.213828] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2␍␊
[11:09:46:757] [ 5.221265] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed␍␊
[11:09:46:765] [ 5.228672] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10␍␊
[11:09:46:773] [ 5.236748] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1␍␊
[11:09:46:782] [ 5.244101] usb usb1: Product: xHCI Host Controller␍␊
[11:09:46:785] [ 5.248908] usb usb1: Manufacturer: Linux 5.10.216-tegra xhci-hcd␍␊
[11:09:46:790] [ 5.255122] usb usb1: SerialNumber: 3610000.xhci␍␊
[11:09:46:796] [ 5.260547] hub 1-0:1.0: USB hub found␍␊
[11:09:46:799] [ 5.263807] hub 1-0:1.0: 4 ports detected␍␊
[11:09:46:804] [ 5.268294] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10␍␊
[11:09:46:812] [ 5.276214] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1␍␊
[11:09:46:818] [ 5.283472] usb usb2: Product: xHCI Host Controller␍␊
[11:09:46:824] [ 5.288461] usb usb2: Manufacturer: Linux 5.10.216-tegra xhci-hcd␍␊
[11:09:46:830] [ 5.294680] usb usb2: SerialNumber: 3610000.xhci␍␊
[11:09:46:835] [ 5.299864] hub 2-0:1.0: USB hub found␍␊
[11:09:46:838] [ 5.303266] hub 2-0:1.0: 4 ports detected␍␊
[11:09:46:843] [ 5.328573] tegra23x-oc-event soctherm-oc-event: Finished tegra23x overcurrent event probing␍␊
[11:09:46:852] [ 5.342302] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1998000 KHz, changing to: 1984000 KHz␍␊
[11:09:46:863] [ 5.344011] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 2000000 KHz, changing to: 1984000 KHz␍␊
[11:09:46:874] [ 5.345034] tegra194-cpufreq e000000.ccplex: probed with ICC, cl:3␍␊
[11:09:46:880] [ 5.345968] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator␍␊
[11:09:46:885] [ 5.350912] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:␍␊
[11:09:46:894] [ 5.356805] tegra194-pcie 14100000.pcie: IO 0x0030100000..0x00301fffff -> 0x0030100000␍␊
[11:09:46:902] [ 5.365201] tegra194-pcie 14100000.pcie: MEM 0x20a8000000..0x20afffffff -> 0x0040000000␍␊
[11:09:46:911] [ 5.373510] tegra194-pcie 14100000.pcie: MEM 0x2080000000..0x20a7ffffff -> 0x2080000000␍␊
[11:09:46:934] [ 5.488222] tegra194-pcie 14100000.pcie: Link up␍␊
[11:09:46:937] [ 5.489440] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00␍␊
[11:09:46:946] [ 5.489633] pci_bus 0001:00: root bus resource [bus 00-ff]␍␊
[11:09:46:959] [ 5.489772] pci_bus 0001:00: root bus resource [io 0x0000-0xfffff] (bus address [0x30100000-0x301fffff])␍␊
[11:09:46:960] [ 5.490026] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])␍␊
[11:09:46:971] [ 5.490304] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]␍␊
[11:09:46:977] [ 5.490550] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400␍␊
[11:09:46:985] [ 5.490850] pci 0001:00:00.0: PME# supported from D0 D3hot␍␊
[11:09:46:990] [ 5.494846] pci 0001:01:00.0: [17cb:1103] type 00 class 0x028000␍␊
[11:09:46:996] [ 5.495163] pci 0001:01:00.0: reg 0x10: [mem 0x00000000-0x001fffff 64bit]␍␊
[11:09:47:002] [ 5.496417] pci 0001:01:00.0: PME# supported from D0 D3hot D3cold␍␊
[11:09:47:010] [ 5.500344] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a81fffff]␍␊
[11:09:47:016] [ 5.500528] pci 0001:01:00.0: BAR 0: assigned [mem 0x20a8000000-0x20a81fffff 64bit]␍␊
[11:09:47:024] [ 5.500813] pci 0001:00:00.0: PCI bridge to [bus 01-ff]␍␊
[11:09:47:030] [ 5.500951] pci 0001:00:00.0: bridge window [mem 0x20a8000000-0x20a81fffff]␍␊
[11:09:47:035] [ 5.501144] pci 0001:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512␍␊
[11:09:47:044] [ 5.507898] pci 0001:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512␍␊
[11:09:47:052] [ 5.516750] pcieport 0001:00:00.0: Adding to iommu group 7␍␊
[11:09:47:058] [ 5.522223] pcieport 0001:00:00.0: PME: Signaling with IRQ 55␍␊
[11:09:47:064] [ 5.528050] pcieport 0001:00:00.0: AER: enabled with IRQ 55␍␊
[11:09:47:070] [ 5.534333] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator␍␊
[11:09:47:083] [ 5.540699] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:␍␊
[11:09:47:083] [ 5.546698] tegra194-pcie 14160000.pcie: IO 0x0036100000..0x00361fffff -> 0x0036100000␍␊
[11:09:47:091] [ 5.555183] tegra194-pcie 14160000.pcie: MEM 0x2428000000..0x242fffffff -> 0x0040000000␍␊
[11:09:47:100] [ 5.563840] tegra194-pcie 14160000.pcie: MEM 0x2140000000..0x2427ffffff -> 0x2140000000␍␊
[11:09:47:108] [ 5.624078] usb 1-2: new high-speed USB device number 2 using tegra-xusb␍␊
[11:09:47:127] [ 5.680227] tegra194-pcie 14160000.pcie: Link up␍␊
[11:09:47:129] [ 5.682844] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00␍␊
[11:09:47:138] [ 5.683032] pci_bus 0004:00: root bus resource [bus 00-ff]␍␊
[11:09:47:146] [ 5.683191] pci_bus 0004:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])␍␊
[11:09:47:152] [ 5.683462] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])␍␊
[11:09:47:163] [ 5.683749] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]␍␊
[11:09:47:171] [ 5.683996] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400␍␊
[11:09:47:177] [ 5.684302] pci 0004:00:00.0: PME# supported from D0 D3hot␍␊
[11:09:47:183] [ 5.688149] pci 0004:01:00.0: [1d97:1602] type 00 class 0x010802␍␊
[11:09:47:188] [ 5.688469] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]␍␊
[11:09:47:194] [ 5.694000] pci 0004:00:00.0: BAR 14: assigned [mem 0x2428000000-0x24280fffff]␍␊
[11:09:47:202] [ 5.694186] pci 0004:01:00.0: BAR 0: assigned [mem 0x2428000000-0x2428003fff 64bit]␍␊
[11:09:47:211] [ 5.694457] pci 0004:00:00.0: PCI bridge to [bus 01-ff]␍␊
[11:09:47:218] [ 5.694590] pci 0004:00:00.0: bridge window [mem 0x2428000000-0x24280fffff]␍␊
[11:09:47:222] [ 5.694784] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512␍␊
[11:09:47:230] [ 5.695052] pci 0004:01:00.0: Max Payload Size set to 256/ 512 (was 128), Max Read Rq 512␍␊
[11:09:47:239] [ 5.702711] pcieport 0004:00:00.0: Adding to iommu group 8␍␊
[11:09:47:244] [ 5.708188] pcieport 0004:00:00.0: PME: Signaling with IRQ 57␍␊
[11:09:47:250] [ 5.714025] pcieport 0004:00:00.0: AER: enabled with IRQ 57␍␊
[11:09:47:255] [ 5.719831] nvme 0004:01:00.0: Adding to iommu group 8␍␊
[11:09:47:261] [ 5.725196] nvme nvme0: pci function 0004:01:00.0␍␊
[11:09:47:267] [ 5.729591] nvme 0004:01:00.0: enabling device (0000 -> 0002)␍␊
[11:09:47:272] [ 5.735240] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator␍␊
[11:09:47:278] [ 5.742109] tegra194-pcie 141e0000.pcie: host bridge /pcie@141e0000 ranges:␍␊
[11:09:47:286] [ 5.745194] nvme nvme0: allocated 20 MiB host memory buffer.␍␊
[11:09:47:292] [ 5.748437] tegra194-pcie 141e0000.pcie: IO 0x003e100000..0x003e1fffff -> 0x003e100000␍␊
[11:09:47:300] [ 5.762512] tegra194-pcie 141e0000.pcie: MEM 0x3228000000..0x322fffffff -> 0x0040000000␍␊
[11:09:47:308] [ 5.764377] nvme nvme0: 8/0/0 default/read/poll queues␍␊
[11:09:47:312] [ 5.770991] tegra194-pcie 141e0000.pcie: MEM 0x2e40000000..0x3227ffffff -> 0x2e40000000␍␊
[11:09:47:320] [ 5.778766] nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15␍␊
[11:09:47:328] [ 5.781205] usb 1-2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice= 5.11␍␊
[11:09:47:336] [ 5.781207] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0␍␊
[11:09:47:342] [ 5.781208] usb 1-2: Product: USB2.0 Hub␍␊
[11:09:47:348] [ 5.781209] usb 1-2: Manufacturer: GenesysLogic␍␊
[11:09:47:351] [ 5.782265] hub 1-2:1.0: USB hub found␍␊
[11:09:47:356] [ 5.782912] hub 1-2:1.0: 4 ports detected␍␊
[11:09:47:359] [ 5.892070] tegra194-pcie 141e0000.pcie: Link up␍␊
[11:09:47:365] [ 5.894712] tegra194-pcie 141e0000.pcie: PCI host bridge to bus 0007:00␍␊
[11:09:47:370] [ 5.894905] pci_bus 0007:00: root bus resource [bus 00-ff]␍␊
[11:09:47:376] [ 5.895051] pci_bus 0007:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x3e100000-0x3e1fffff])␍␊
[11:09:47:387] [ 5.895301] pci_bus 0007:00: root bus resource [mem 0x3228000000-0x322fffffff] (bus address [0x40000000-0x47ffffff])␍␊
[11:09:47:399] [ 5.895567] pci_bus 0007:00: root bus resource [mem 0x2e40000000-0x3227ffffff pref]␍␊
[11:09:47:404] [ 5.895814] pci 0007:00:00.0: [10de:229a] type 01 class 0x060400␍␊
[11:09:47:409] [ 5.896120] pci 0007:00:00.0: PME# supported from D0 D3hot␍␊
[11:09:47:416] [ 5.900367] pci 0007:01:00.0: [8086:1531] type 00 class 0x020000␍␊
[11:09:47:423] [ 5.900670] pci 0007:01:00.0: reg 0x10: [mem 0x00000000-0x007fffff]␍␊
[11:09:47:429] [ 5.900953] pci 0007:01:00.0: reg 0x18: [io 0x0000-0x001f]␍␊
[11:09:47:435] [ 5.901165] pci 0007:01:00.0: reg 0x1c: [mem 0x00000000-0x00003fff]␍␊
[11:09:47:440] [ 5.904319] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using tegra-xusb␍␊
[11:09:47:448] [ 5.904705] pci 0007:01:00.0: PME# supported from D0 D3hot D3cold␍␊
[11:09:47:454] [ 5.920961] pci 0007:00:00.0: BAR 14: assigned [mem 0x3228000000-0x3228bfffff]␍␊
[11:09:47:460] [ 5.924554] pci 0007:00:00.0: BAR 13: assigned [io 0x200000-0x200fff]␍␊
[11:09:47:468] [ 5.930940] pci 0007:01:00.0: BAR 0: assigned [mem 0x3228000000-0x32287fffff]␍␊
[11:09:47:474] [ 5.937438] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice= 5.11␍␊
[11:09:47:482] [ 5.938140] pci 0007:01:00.0: BAR 3: assigned [mem 0x3228800000-0x3228803fff]␍␊
[11:09:47:490] [ 5.946520] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0␍␊
[11:09:47:496] [ 5.953891] pci 0007:01:00.0: BAR 2: assigned [io 0x200000-0x20001f]␍␊
[11:09:47:504] [ 5.961217] usb 2-1: Product: USB3.0 Hub␍␊
[11:09:47:508] [ 5.967631] pci 0007:00:00.0: PCI bridge to [bus 01-ff]␍␊
[11:09:47:513] [ 5.971543] usb 2-1: Manufacturer: GenesysLogic␍␊
[11:09:47:519] [ 5.976790] pci 0007:00:00.0: bridge window [io 0x200000-0x200fff]␍␊
[11:09:47:524] [ 5.976794] pci 0007:00:00.0: bridge window [mem 0x3228000000-0x3228bfffff]␍␊
[11:09:47:530] [ 5.985335] hub 2-1:1.0: USB hub found␍␊
[11:09:47:535] [ 5.987827] pci 0007:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512␍␊
[11:09:47:544] [ 5.996302] hub 2-1:1.0: 4 ports detected␍␊
[11:09:47:547] [ 5.999082] pci 0007:01:00.0: Max Payload Size set to 256/ 512 (was 128), Max Read Rq 512␍␊
[11:09:47:555] [ 6.012672] usb usb2-port2: config error␍␊
[11:09:47:561] [ 6.020278] pcieport 0007:00:00.0: Adding to iommu group 9␍␊
[11:09:47:566] [ 6.029504] pcieport 0007:00:00.0: PME: Signaling with IRQ 59␍␊
[11:09:47:572] [ 6.035247] pcieport 0007:00:00.0: AER: enabled with IRQ 59␍␊
[11:09:47:577] [ 6.041676] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator␍␊
[11:09:47:583] [ 6.047593] tegra194-pcie 140c0000.pcie: Using GICv2m MSI allocator␍␊
[11:09:47:588] [ 6.054613] tegra194-pcie 140c0000.pcie: host bridge /pcie@140c0000 ranges:␍␊
[11:09:47:597] [ 6.060185] tegra194-pcie 140c0000.pcie: IO 0x002c100000..0x002c1fffff -> 0x002c100000␍␊
[11:09:47:605] [ 6.068492] tegra194-pcie 140c0000.pcie: MEM 0x3828000000..0x382fffffff -> 0x0040000000␍␊
[11:09:47:614] [ 6.076977] tegra194-pcie 140c0000.pcie: MEM 0x3540000000..0x3827ffffff -> 0x3540000000␍␊
[11:09:47:622] [ 6.088228] usb 1-2.1: new high-speed USB device number 3 using tegra-xusb␍␊
[11:09:47:698] [ 6.252069] usb 1-2.1: new high-speed USB device number 4 using tegra-xusb␍␊
[11:09:47:802] [ 6.355685] usb 1-2.1: New USB device found, idVendor=1a86, idProduct=e018, bcdDevice= 3.40␍␊
[11:09:47:814] [ 6.355923] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0␍␊
[11:09:47:816] [ 6.356157] usb 1-2.1: Product: USB2.0 To Multi Serial Ports␍␊
[11:09:47:822] [ 6.356345] usb 1-2.1: Manufacturer: wch.cn␍␊
[11:09:48:640] [ 7.193775] tegra194-pcie 140c0000.pcie: Phy link never came up␍␊
[11:09:48:646] [ 7.194027] tegra194-pcie 140c0000.pcie: PCI host bridge to bus 0009:00␍␊
[11:09:48:652] [ 7.194237] pci_bus 0009:00: root bus resource [bus 00-ff]␍␊
[11:09:48:657] [ 7.194394] pci_bus 0009:00: root bus resource [io 0x300000-0x3fffff] (bus address [0x2c100000-0x2c1fffff])␍␊
[11:09:48:671] [ 7.194666] pci_bus 0009:00: root bus resource [mem 0x3828000000-0x382fffffff] (bus address [0x40000000-0x47ffffff])␍␊
[11:09:48:677] [ 7.194969] pci_bus 0009:00: root bus resource [mem 0x3540000000-0x3827ffffff pref]␍␊
[11:09:48:685] [ 7.195230] pci 0009:00:00.0: [10de:229c] type 01 class 0x060400␍␊
[11:09:48:691] [ 7.195535] pci 0009:00:00.0: PME# supported from D0 D3hot␍␊
[11:09:48:697] [ 7.202261] pci 0009:00:00.0: PCI bridge to [bus 01-ff]␍␊
[11:09:48:702] [ 7.202414] pci 0009:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512␍␊
[11:09:48:710] [ 7.202881] pcieport 0009:00:00.0: Adding to iommu group 11␍␊
[11:09:48:716] [ 7.203218] pcieport 0009:00:00.0: PME: Signaling with IRQ 63␍␊
[11:09:48:722] [ 7.203640] pcieport 0009:00:00.0: AER: enabled with IRQ 63␍␊
[11:09:48:727] [ 7.203997] pci_bus 0009:01: busn_res: [bus 01-ff] is released␍␊
[11:09:48:733] [ 7.204243] pci 0009:00:00.0: Removing from iommu group 11␍␊
[11:09:48:738] [ 7.204396] pci_bus 0009:00: busn_res: [bus 00-ff] is released␍␊
[11:09:48:744] [ 7.209514] vdd-3v3-sd: supplied by vdd-3v3␍␊
[11:09:48:750] [ 7.213987] tegra194-isp5 14800000.isp: initialized␍␊
[11:09:48:755] [ 7.217345] driver not enabled, cannot register any devices␍␊
[11:09:48:761] [ 7.225251] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized␍␊
[11:09:48:766] [ 7.229431] driver not enabled, cannot register any devices␍␊
[11:09:48:772] [ 7.235265] (NULL device *): fops function table already registered␍␊
[11:09:48:777] [ 7.242145] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized␍␊
[11:09:48:783] [ 7.247436] driver not enabled, cannot register any devices␍␊
[11:09:48:789] [ 7.253828] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator␍␊
[11:09:48:794] [ 7.259652] irq: IRQ305: trimming hierarchy from :interrupt-controller@f400000-1␍␊
[11:09:48:820] [ 7.373333] tegra194-pcie 140a0000.pcie: host bridge /pcie@140a0000 ranges:␍␊
[11:09:48:825] [ 7.373555] tegra194-pcie 140a0000.pcie: IO 0x002a100000..0x002a1fffff -> 0x002a100000␍␊
[11:09:48:834] [ 7.373806] tegra194-pcie 140a0000.pcie: MEM 0x3528000000..0x352fffffff -> 0x0040000000␍␊
[11:09:48:842] [ 7.374044] tegra194-pcie 140a0000.pcie: MEM 0x3240000000..0x3527ffffff -> 0x3240000000␍␊
[11:09:48:927] [ 7.480221] tegra194-pcie 140a0000.pcie: Link up␍␊
[11:09:48:930] [ 7.482249] tegra194-pcie 140a0000.pcie: PCI host bridge to bus 0008:00␍␊
[11:09:48:938] [ 7.482453] pci_bus 0008:00: root bus resource [bus 00-ff]␍␊
[11:09:48:948] [ 7.482598] pci_bus 0008:00: root bus resource [io 0x400000-0x4fffff] (bus address [0x2a100000-0x2a1fffff])␍␊
[11:09:48:952] [ 7.482858] pci_bus 0008:00: root bus resource [mem 0x3528000000-0x352fffffff] (bus address [0x40000000-0x47ffffff])␍␊
[11:09:48:963] [ 7.483134] pci_bus 0008:00: root bus resource [mem 0x3240000000-0x3527ffffff pref]␍␊
[11:09:48:972] [ 7.483377] pci 0008:00:00.0: [10de:229c] type 01 class 0x060400␍␊
[11:09:48:977] [ 7.483682] pci 0008:00:00.0: PME# supported from D0 D3hot␍␊
[11:09:48:983] [ 7.487548] pci 0008:01:00.0: [10ec:8168] type 00 class 0x020000␍␊
[11:09:48:988] [ 7.487847] pci 0008:01:00.0: reg 0x10: [io 0x0000-0x00ff]␍␊
[11:09:48:994] [ 7.488174] pci 0008:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]␍␊
[11:09:49:000] [ 7.488461] pci 0008:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]␍␊
[11:09:49:008] [ 7.489643] pci 0008:01:00.0: supports D1 D2␍␊
[11:09:49:012] [ 7.489756] pci 0008:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold␍␊
[11:09:49:019] [ 7.493789] pci 0008:00:00.0: BAR 14: assigned [mem 0x3528000000-0x35280fffff]␍␊
[11:09:49:025] [ 7.493969] pci 0008:00:00.0: BAR 13: assigned [io 0x400000-0x400fff]␍␊
[11:09:49:033] [ 7.495287] pci 0008:01:00.0: BAR 4: assigned [mem 0x3528000000-0x3528003fff 64bit]␍␊
[11:09:49:039] [ 7.503083] pci 0008:01:00.0: BAR 2: assigned [mem 0x3528004000-0x3528004fff 64bit]␍␊
[11:09:49:047] [ 7.510953] pci 0008:01:00.0: BAR 0: assigned [io 0x400000-0x4000ff]␍␊
[11:09:49:053] [ 7.517452] pci 0008:00:00.0: PCI bridge to [bus 01-ff]␍␊
[11:09:49:058] [ 7.522675] pci 0008:00:00.0: bridge window [io 0x400000-0x400fff]␍␊
[11:09:49:067] [ 7.529065] pci 0008:00:00.0: bridge window [mem 0x3528000000-0x35280fffff]␍␊
[11:09:49:073] [ 7.536425] pci 0008:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512␍␊
[11:09:49:081] [ 7.544964] pci 0008:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512␍␊
[11:09:49:089] [ 7.553628] pcieport 0008:00:00.0: Adding to iommu group 10␍␊
[11:09:49:095] [ 7.559278] pcieport 0008:00:00.0: PME: Signaling with IRQ 61␍␊
[11:09:49:100] [ 7.565106] pcieport 0008:00:00.0: AER: enabled with IRQ 61␍␊
[11:09:49:106] [ 7.571637] irq: IRQ307: trimming hierarchy from :pmc@c360000␍␊
[11:09:49:115] [ 7.576299] irq: IRQ308: trimming hierarchy from :interrupt-controller@f400000-1␍␊
[11:09:49:120] [ 7.583677] input: gpio-keys as /devices/platform/gpio-keys/input/input0␍␊
[11:09:49:126] [ 7.590804] tegra-se-nvhost 15810000.se: Adding to iommu group 51␍␊
[11:09:49:135] [ 7.596947] tegra-se-nvhost 15810000.se: initialized␍␊
[11:09:49:139] [ 7.609901] tegra-se-nvhost 15810000.se: tegra_se_probe: complete␍␊
[11:09:49:145] [ 7.610172] tegra-se-nvhost 15820000.se: Adding to iommu group 52␍␊
[11:09:49:151] [ 7.614171] tegra-se-nvhost 15820000.se: initialized␍␊
[11:09:49:159] [ 7.620203] tegra-se-nvhost 15820000.se: tegra_se_probe: complete␍␊
[11:09:49:162] [ 7.624886] tegra-se-nvhost 15840000.se: Adding to iommu group 53␍␊
[11:09:49:168] [ 7.631340] tegra-se-nvhost 15840000.se: initialized␍␊
[11:09:49:173] [ 7.637687] tegra-se-nvhost 15840000.se: tegra_se_probe: complete␍␊
[11:09:49:179] [ 7.642734] tegra_actmon d230000.actmon: in actmon_register()...␍␊
[11:09:49:184] [ 7.648392] tegra_actmon d230000.actmon: bwmgr_disable = 1␍␊
[11:09:49:190] [ 7.653943] tegra_actmon d230000.actmon: initialization Completed for the device mc_all␍␊
[11:09:49:198] [ 7.661830] hvc_sysfs: hypervisor is not present␍␊
[11:09:49:207] [ 7.666210] clk: Disabling unused clocks␍␊
[11:09:49:207] [ 7.703889] ALSA device list:␍␊
[11:09:49:210] [ 7.703962] No soundcards found.␍␊
[11:09:49:215] [ 7.704718] Freeing unused kernel memory: 4032K␍␊
[11:09:49:218] [ 7.704868] Run /init as init process␍␊
[11:09:49:221] [ 7.717601] Root device found: initrd␍␊
[11:09:49:224] insmod /lib/modules/5.10.216-tegra/kernel/drivers/net/ethernet/realtek/r8168/r8168.ko ␍␍␊
[11:09:49:232] [ 7.722180] r8168: module verification failed: signature and/or required key missing - tainting kernel␍␊
[11:09:49:243] [ 7.723401] r8168 0008:01:00.0: Adding to iommu group 10␍␊
[11:09:49:247] [ 7.723747] r8168 Gigabit Ethernet driver 8.053.00-NAPI loaded␍␊
[11:09:49:254] [ 7.723981] r8168 0008:01:00.0: enabling device (0000 -> 0003)␍␊
[11:09:49:260] [ 7.741499] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.␍␊
[11:09:49:271] [ 7.743839] r8168 Copyright (C) 2024 Realtek NIC software team <nicfae@realtek.com> ␍␊
[11:09:49:280] [ 7.743839] This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>. ␍␊
[11:09:49:288] [ 7.743839] This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>. ␍␊
[11:09:49:302] [ 7.765377] Mount initrd as rootfs and enter recovery mode␍␊
[11:09:49:308] enable_remote_access␍␍␊
[11:09:49:312] enable remote access␍␍␊
[11:09:49:312] insmod /lib/modules/5.10.216-tegra/kernel/drivers/mtd/mtd.ko ␍␍␊
[11:09:49:316] insmod /lib/modules/5.10.216-tegra/kernel/drivers/mtd/devices/qspi_mtd.ko ␍␍␊
[11:09:49:325] [ 7.788775] qspi_mtd spi6.0: MX25U51279G (65536 Kbytes)␍␊
[11:09:49:331] [ 7.791650] qspi_mtd spi6.0: mtd .name = spi6.0, .size = 0x4000000 (64MiB) .erasesize = 0x00010000 (64KiB) .numeraseregions = 0␍␊
[11:09:49:341] [ 7.806365] 1 fixed-partitions partitions found on MTD device spi6.0␍␊
[11:09:49:347] [ 7.809691] Creating 1 MTD partitions on "spi6.0":␍␊
[11:09:49:354] [ 7.814665] 0x000000000000-0x000004000000 : "Whole_flash0"␍␊
[11:09:49:359] insmod /lib/modules/5.10.216-tegra/kernel/drivers/spi/spi-tegra210-qspi.ko ␍␍␊
[11:09:49:364] insmod /lib/modules/5.10.216-tegra/kernel/drivers/hwmon/pwm-fan.ko ␍␍␊
[11:09:51:543] [ 10.096128] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:09:51:549] [ 10.096340] usb usb2-port2: config error␍␊
[11:09:55:616] [ 14.168290] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:09:55:621] [ 14.168519] usb usb2-port2: config error␍␊
[11:09:59:688] [ 18.240136] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:09:59:694] [ 18.240348] usb usb2-port2: config error␍␊
[11:10:03:761] [ 22.312132] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:10:03:767] [ 22.312348] usb usb2-port2: config error␍␊
[11:10:07:833] [ 26.384286] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:10:07:839] [ 26.384516] usb usb2-port2: config error␍␊
[11:10:11:906] [ 30.456290] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:10:11:911] [ 30.456515] usb usb2-port2: config error␍␊
[11:10:15:978] [ 34.528286] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:10:15:984] [ 34.528499] usb usb2-port2: config error␍␊
[11:10:20:051] [ 38.600293] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:10:20:056] [ 38.600517] usb usb2-port2: config error␍␊
[11:10:24:124] [ 42.672285] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:10:24:129] [ 42.672512] usb usb2-port2: config error␍␊
[11:10:28:196] [ 46.744285] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:10:28:202] [ 46.744497] usb usb2-port2: config error␍␊
[11:10:32:269] [ 50.816285] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:10:32:277] [ 50.816495] usb usb2-port2: config error␍␊
[11:10:36:341] [ 54.888292] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:10:36:351] [ 54.888516] usb usb2-port2: config error␍␊
[11:10:40:414] [ 58.960118] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:10:40:421] [ 58.960324] usb usb2-port2: config error␍␊
[11:10:44:486] [ 63.032287] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:10:44:493] [ 63.032500] usb usb2-port2: config error␍␊
[11:10:48:559] [ 67.104284] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:10:48:567] [ 67.104509] usb usb2-port2: config error␍␊
[11:10:49:365] No known UDC device found␍␍␊
[11:10:49:380] bash: cannot set terminal process group (-1): Inappropriate ioctl for device␍␍␊
[11:10:49:389] bash: no job control in this shell␍␍␊
[11:10:49:393] bash-5.0# [ 71.176293] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:10:52:637] [ 71.176503] usb usb2-port2: config error␍␊
[11:10:56:704] [ 75.248288] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:10:56:710] [ 75.248516] usb usb2-port2: config error␍␊
[11:11:00:777] [ 79.320290] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:11:00:785] [ 79.320516] usb usb2-port2: config error␍␊
[11:11:04:849] [ 83.392288] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:11:04:855] [ 83.392514] usb usb2-port2: config error␍␊
[11:11:08:921] [ 87.464130] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:11:08:930] [ 87.464356] usb usb2-port2: config error␍␊
[11:11:12:994] [ 91.536289] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:11:13:001] [ 91.536515] usb usb2-port2: config error␍␊
[11:11:17:067] [ 95.608290] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:11:17:076] [ 95.608493] usb usb2-port2: config error␍␊
[11:11:21:139] [ 99.680290] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:11:21:146] [ 99.680516] usb usb2-port2: config error␍␊
[11:11:25:212] [ 103.752133] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:11:25:219] [ 103.752342] usb usb2-port2: config error␍␊
[11:11:29:284] [ 107.824126] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:11:29:294] [ 107.824352] usb usb2-port2: config error␍␊
[11:11:33:357] [ 111.896295] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:11:33:366] [ 111.896508] usb usb2-port2: config error␍␊
[11:11:37:430] [ 115.968297] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:11:37:437] [ 115.968523] usb usb2-port2: config error␍␊
[11:11:41:502] [ 120.040134] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:11:41:510] [ 120.040347] usb usb2-port2: config error␍␊
[11:11:45:575] [ 124.112283] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:11:45:584] [ 124.112497] usb usb2-port2: config error␍␊
[11:11:49:647] [ 128.184289] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:11:49:655] [ 128.184503] usb usb2-port2: config error␍␊
[11:11:53:720] [ 132.256291] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:11:53:728] [ 132.256518] usb usb2-port2: config error␍␊
[11:11:57:792] [ 136.328131] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:11:57:798] [ 136.328345] usb usb2-port2: config error␍␊
[11:12:01:865] [ 140.400293] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:12:01:871] [ 140.400516] usb usb2-port2: config error␍␊
[11:12:05:938] [ 144.472291] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:12:05:947] [ 144.472519] usb usb2-port2: config error␍␊
[11:12:10:010] [ 148.544288] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:12:10:017] [ 148.544515] usb usb2-port2: config error␍␊
[11:12:14:083] [ 152.616291] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:12:14:090] [ 152.616499] usb usb2-port2: config error␍␊
[11:12:18:155] [ 156.688289] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:12:18:163] [ 156.688503] usb usb2-port2: config error␍␊
[11:12:22:228] [ 160.760288] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:12:22:235] [ 160.760502] usb usb2-port2: config error␍␊
[11:12:26:300] [ 164.832296] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:12:26:309] [ 164.832523] usb usb2-port2: config error␍␊
[11:12:30:373] [ 168.904299] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:12:30:379] [ 168.904512] usb usb2-port2: config error␍␊
[11:12:34:445] [ 172.976288] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:12:34:451] [ 172.976497] usb usb2-port2: config error␍␊
[11:12:38:518] [ 177.048291] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:12:38:525] [ 177.048518] usb usb2-port2: config error␍␊
[11:12:42:591] [ 181.120292] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:12:42:598] [ 181.120500] usb usb2-port2: config error␍␊
[11:12:46:663] [ 185.192132] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:12:46:670] [ 185.192341] usb usb2-port2: config error␍␊
[11:12:50:736] [ 189.264290] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:12:50:743] [ 189.264516] usb usb2-port2: config error␍␊
[11:12:54:808] [ 193.336134] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:12:54:817] [ 193.336347] usb usb2-port2: config error␍␊
[11:12:58:881] [ 197.408290] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:12:58:888] [ 197.408499] usb usb2-port2: config error␍␊
[11:13:02:953] [ 201.480289] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:13:02:960] [ 201.480502] usb usb2-port2: config error␍␊
[11:13:07:026] [ 205.552284] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:13:07:034] [ 205.552507] usb usb2-port2: config error␍␊
[11:13:11:099] [ 209.624291] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:13:11:108] [ 209.624518] usb usb2-port2: config error␍␊
[11:13:15:171] [ 213.696127] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:13:15:179] [ 213.696335] usb usb2-port2: config error␍␊
[11:13:19:244] [ 217.768287] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:13:19:249] [ 217.768514] usb usb2-port2: config error␍␊
[11:13:23:316] [ 221.840298] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:13:23:323] [ 221.840512] usb usb2-port2: config error␍␊
[11:13:27:389] [ 225.912288] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:13:27:398] [ 225.912500] usb usb2-port2: config error␍␊
[11:13:31:462] [ 229.984297] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:13:31:469] [ 229.984504] usb usb2-port2: config error␍␊
[11:13:35:534] [ 234.056290] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:13:35:542] [ 234.056503] usb usb2-port2: config error␍␊
[11:13:39:607] [ 238.128289] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:13:39:616] [ 238.128503] usb usb2-port2: config error␍␊
[11:13:43:679] [ 242.200288] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:13:43:687] [ 242.200514] usb usb2-port2: config error␍␊
[11:13:47:752] [ 246.272290] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:13:47:761] [ 246.272517] usb usb2-port2: config error␍␊
[11:13:51:825] [ 250.344286] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:13:51:830] [ 250.344500] usb usb2-port2: config error␍␊
[11:13:55:897] [ 254.416291] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:13:55:903] [ 254.416505] usb usb2-port2: config error␍␊
[11:13:59:970] [ 258.488285] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:13:59:978] [ 258.488511] usb usb2-port2: config error␍␊
[11:14:04:042] [ 262.560131] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:14:04:050] [ 262.560346] usb usb2-port2: config error␍␊
[11:14:08:115] [ 266.632289] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:14:08:122] [ 266.632495] usb usb2-port2: config error␍␊
[11:14:12:187] [ 270.704288] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:14:12:195] [ 270.704512] usb usb2-port2: config error␍␊
[11:14:16:260] [ 274.776290] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:14:16:268] [ 274.776514] usb usb2-port2: config error␍␊
[11:14:20:332] [ 278.848134] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:14:20:340] [ 278.848344] usb usb2-port2: config error␍␊
[11:14:24:405] [ 282.920290] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:14:24:412] [ 282.920518] usb usb2-port2: config error␍␊
[11:14:28:478] [ 286.992298] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:14:28:485] [ 286.992511] usb usb2-port2: config error␍␊
[11:14:32:550] [ 291.064300] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:14:32:558] [ 291.064514] usb usb2-port2: config error␍␊
[11:14:36:623] [ 295.136289] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:14:36:631] [ 295.136503] usb usb2-port2: config error␍␊
[11:14:40:696] [ 299.208287] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:14:40:704] [ 299.208514] usb usb2-port2: config error␍␊
[11:14:44:768] [ 303.280287] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:14:44:774] [ 303.280500] usb usb2-port2: config error␍␊
[11:14:48:841] [ 307.352288] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:14:48:846] [ 307.352516] usb usb2-port2: config error␍␊
[11:14:52:913] [ 311.424130] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:14:52:920] [ 311.424338] usb usb2-port2: config error␍␊
[11:14:56:986] [ 315.496288] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:14:56:996] [ 315.496502] usb usb2-port2: config error␍␊
[11:15:01:058] [ 319.568289] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:15:01:064] [ 319.568516] usb usb2-port2: config error␍␊
[11:15:05:131] [ 323.640287] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:15:05:136] [ 323.640493] usb usb2-port2: config error␍␊
[11:15:09:204] [ 327.712286] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:15:09:211] [ 327.712512] usb usb2-port2: config error␍␊
[11:15:13:276] [ 331.784284] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:15:13:284] [ 331.784510] usb usb2-port2: config error␍␊
[11:15:17:349] [ 335.856297] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:15:17:357] [ 335.856510] usb usb2-port2: config error␍␊
[11:15:21:421] [ 339.928119] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:15:21:433] [ 339.928335] usb usb2-port2: config error␍␊
[11:15:25:494] [ 344.000288] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:15:25:501] [ 344.000515] usb usb2-port2: config error␍␊
[11:15:29:566] [ 348.072286] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:15:29:574] [ 348.072513] usb usb2-port2: config error␍␊
[11:15:33:639] [ 352.144288] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:15:33:645] [ 352.144517] usb usb2-port2: config error␍␊
[11:15:37:712] [ 356.216287] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:15:37:718] [ 356.216496] usb usb2-port2: config error␍␊
[11:15:41:784] [ 360.288290] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:15:41:790] [ 360.288515] usb usb2-port2: config error␍␊
[11:15:45:857] [ 364.360289] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:15:45:863] [ 364.360513] usb usb2-port2: config error␍␊
[11:15:49:929] [ 368.432287] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:15:49:936] [ 368.432500] usb usb2-port2: config error␍␊
[11:15:54:002] [ 372.504288] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:15:54:010] [ 372.504501] usb usb2-port2: config error␍␊
[11:15:58:074] [ 376.576287] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:15:58:080] [ 376.576494] usb usb2-port2: config error␍␊
[11:16:02:147] [ 380.648289] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:16:02:153] [ 380.648504] usb usb2-port2: config error␍␊
[11:16:06:220] [ 384.720289] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:16:06:227] [ 384.720504] usb usb2-port2: config error␍␊
[11:16:10:292] [ 388.792130] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:16:10:300] [ 388.792344] usb usb2-port2: config error␍␊
[11:16:14:365] [ 392.864297] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:16:14:371] [ 392.864507] usb usb2-port2: config error␍␊
[11:16:18:438] [ 396.936297] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:16:18:447] [ 396.936510] usb usb2-port2: config error␍␊
[11:16:22:510] [ 401.008286] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:16:22:521] [ 401.008499] usb usb2-port2: config error␍␊
[11:16:26:583] [ 405.080287] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:16:26:591] [ 405.080501] usb usb2-port2: config error␍␊
[11:16:27:367] [ 405.864142] usb usb2-port2: config error␍␊
[11:16:28:203] [ 406.700133] usb usb2-port2: config error␍␊
[11:16:29:035] [ 407.532131] usb usb2-port2: config error␍␊
[11:16:29:871] [ 408.368137] usb usb2-port2: config error␍␊
[11:16:33:944] [ 412.440288] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:16:33:951] [ 412.440514] usb usb2-port2: config error␍␊
[11:16:36:352] [ 414.848302] usb usb2-port2: config error␍␊
[11:16:36:396] [ 414.892098] usb usb2-port2: config error␍␊
[11:16:37:216] [ 415.712133] usb usb2-port2: config error␍␊
[11:16:38:048] [ 416.544134] usb usb2-port2: config error␍␊
[11:16:42:121] [ 420.616287] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:16:42:128] [ 420.616512] usb usb2-port2: config error␍␊
[11:16:44:529] [ 423.024135] usb usb2-port2: config error␍␊
[11:16:44:573] [ 423.068097] usb usb2-port2: config error␍␊
[11:16:45:397] [ 423.892140] usb usb2-port2: config error␍␊
[11:16:46:233] [ 424.728134] usb usb2-port2: config error␍␊
[11:16:50:306] [ 428.800288] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:16:50:313] [ 428.800499] usb usb2-port2: config error␍␊
[11:16:53:546] [ 432.040149] usb usb2-port2: config error␍␊
[11:16:53:590] [ 432.084098] usb usb2-port2: config error␍␊
[11:16:54:410] [ 432.904142] usb usb2-port2: config error␍␊
[11:16:58:483] [ 436.976290] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:16:58:493] [ 436.976516] usb usb2-port2: config error␍␊
[11:17:00:059] [ 438.552304] usb usb2-port2: config error␍␊
[11:17:00:103] [ 438.596097] usb usb2-port2: config error␍␊
[11:17:00:923] [ 439.416133] usb usb2-port2: config error␍␊
[11:17:01:763] [ 440.256134] usb usb2-port2: config error␍␊
[11:17:02:600] [ 441.092128] usb usb2-port2: config error␍␊
[11:17:06:672] [ 445.164289] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:17:06:679] [ 445.164514] usb usb2-port2: config error␍␊
[11:17:08:249] [ 446.740304] usb usb2-port2: config error␍␊
[11:17:08:300] [ 446.792124] usb usb2-port2: config error␍␊
[11:17:09:116] [ 447.608132] usb usb2-port2: config error␍␊
[11:17:09:953] [ 448.444133] usb usb2-port2: config error␍␊
[11:17:10:781] [ 449.272127] usb usb2-port2: config error␍␊
[11:17:14:853] [ 453.344289] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:17:14:859] [ 453.344503] usb usb2-port2: config error␍␊
[11:17:15:641] [ 454.132130] usb usb2-port2: config error␍␊
[11:17:16:470] [ 454.960133] usb usb2-port2: config error␍␊
[11:17:17:306] [ 455.796127] usb usb2-port2: config error␍␊
[11:17:18:142] [ 456.632134] usb usb2-port2: config error␍␊
[11:17:18:970] [ 457.460131] usb usb2-port2: config error␍␊
[11:17:23:043] [ 461.532301] usb usb2-port2: config error␍␊
[11:17:23:086] [ 461.576099] usb usb2-port2: config error␍␊
[11:17:27:160] [ 465.648287] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:17:27:178] [ 465.648499] usb usb2-port2: config error␍␊
[11:17:29:568] [ 468.056303] usb usb2-port2: config error␍␊
[11:17:29:615] [ 468.104123] usb usb2-port2: config error␍␊
[11:17:30:431] [ 468.920131] usb usb2-port2: config error␍␊
[11:17:31:268] [ 469.756133] usb usb2-port2: config error␍␊
[11:17:35:340] [ 473.828308] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?␍␊
[11:17:35:350] [ 473.828534] usb usb2-port2: config error␍␊
[11:17:36:128] [ 474.616106] usb usb2-port2: config error␍␊
[11:17:36:944] [ 475.432134] usb usb2-port2: config error␍␊
[11:17:37:789] [ 476.276129] usb usb2-port2: config error␍␊
[11:17:38:621] [ 477.108134] usb usb2-port2: config error␍␊
[11:17:39:453] [ 477.940134] usb usb2-port2: config error␍␊
In orin nx uart log,print usb2 port error,Please help me correct my incorrect configuration.
