Set usermeta inside gst-nvinfer
• Hardware Platform (Jetson / GPU) Jetson
• DeepStream Version 6.2
• JetPack Version (valid for Jetson only) 5.0.1
• TensorRT Version
• Issue Type( questions, new requirements, bugs) question
I tried to set usermeta data in my custom-parser function but found it is not possible to access batchmeta in the function.
But is it possible to set usermeta data inside the gst_nvinfer_output_loop in gstnvinfer.cpp?
Yes, of course, but have you ever referred to deepstream-user-metadata-test? It is no problem to add user meta in custom-parser function.
You can add it in nvinfer src pad probe function.
