Hi there,
I’ve stumbeld over some really odd behaviour that I thought is worth bringing up here.
We’re building an application that records streams of attached cameras to compressed video files, using Argus and the multimedia framework on a Jetson Xavier.
All works well until I make use of a specific feature, setting the clip rectangle to define the relevant image area to record using setSourceClipRect().
Let’s say we have a sensor delivering 1936x1100 and we want to crop out the inner 1920x1080 pixels (btw. it’s a shame that we can’t just drop pixels on the edges), I calculate the source clip rectangle to be ~ (0.004132, 0.009091, 0.995868, 0.990909). I pass it to the function, it returns STATUS_OK and everything looks fine until I try to acquire a buffer, which hangs forever.
Now the funny thing is that if I take a value with a lower float resolution, it seems to work fine: (0.004, 0.009, 0.996, 0.991) works nicely. I tried just rounding the precision and it works, but only for some clipping numbers, eg it wouldn’t work for clipping 1920x640.
I suspect it might be that the resulting stream size has to be even or something like this?
Anyway, would be great if this would be just working. I want to mention that this happens only when using STREAM_TYPE_BUFFER & BUFFER_TYPE_EGL_IMAGE, I had no such problems when using STREAM_TYPE_EGL and acquired the images using a frame consumer.
Hi Shane,
thanks for your reply. I’m not sure if I understand your proposed solution, though. as I wrote, I use the buffer stream type, which doesn’t have the setResolution function in it’s interface.
setResolution() exists only as a member of IEGLOutputStreamSettings. No other class or interface in the Argus API has it.
I’m using a buffer output stream, and the only settings interface available to me is IBufferOutputStreamSettings. I actually tried acquiring the IEGLOutputStreamSettings interface, but the cast failed (as I would expect it). So it looks like this function won’t work for me and I need to use the clip rectangle (available on the IStreamSettings interface), but this is broken as I described in my original post.
I wasn’t able to reproduce the issue in the denoise sample. This doesn’t surprise me, as this sample uses STREAM_TYPE_EGL, which worked fine also for me, as I wrote in the original post.
BUT I managed to nicely repro the issue in the eglimage sample, which uses a buffer output stream! I just added the creation of the source clip rectangle in the proper place, and when I start the sample with a capture resolution of 1920x1080, it freezes in the startup. You can find my changed sample here: main.cpp (16.4 KB)
The changes I did are marked with
// BEGIN YAAK repro clip rect issue
and
// END YAAK repro clip rect issue
It’s important to start the sample with 1920x1080 resolution. I suspect it is also important that the sensor delivers a slightly higher resolution than 1920x1080. I’m using a D3 Engineering D3RCM-IMX390-953, which is built around the Sony IMX390 image sensor, which delivers a native resolution of 1936x1100.
I hope this information helps us tracking down this issue!
