Setting breakpoints
I wonder if anyone had any pointers to detailed information about setting breakpoints in C/C++ code, e.g.
  • setting watch/breakpoints on data/routines within namespaces
  • setting breakpoints in C++ classes, especially ctors/dtors
  • setting breakpoints in all routines of a given (undecorated) name
  • setting breakpoints in one routine, where duplicate (undecorated) names exist
  • setting breakpoints in template functions
Cheers
Tim
Hi Tim,
We have been working on improvements to our C++ debugging support, but unfortunately it isn’t yet complete. We plan to support most of what you have listed. Responses to specific inquiries follow:
    Qualifying the names of routines and data by namespace is not yet supported.
    In 7.1, you can do this by qualifying the name with the class, e.g. for the constructor of class foo you would set the breakpoint on foo::foo. In the GUI you would just point to it and click in the events column.
    You currently have to do this one-by-one
    The debugger will prompt you asking which member function you want to set the breakpoint in. I don’t think it will currently disambiguate names outside of a single class, so you may want to qualify the routine name using the class name.
    We don’t yet have support for setting a breakpoint on a template function by name. In many cases you can step into a template function and set breakpoints while you are in the scope of the function.
–Don[/quote]
[/quote][/quote]
