• Hardware Platform (Jetson / GPU) RTX 2060
• DeepStream Version 5.0
• TensorRT Version 7.1.1
• NVIDIA GPU Driver Version (valid for GPU only) 460
• Issue Type( questions, new requirements, bugs) Question
I want to set all the properties of deepstream-config file via code in C++.
I am trying to use g_object_set() on following properties but I am getting following error
GLib-GObject-WARNING **: 15:22:33.780: g_object_set_is_valid_property: object class ‘GstNvInfer’ has no property named ‘model-color-format’
The properties I am trying to set are
[property]
model-color-format=0
labelfile-path=labels.txt
network-mode=0
num-detected-classes=80
gie-unique-id=1
is-classifier=0
maintain-aspect-ratio=1
output-blob-names=output;
parse-bbox-func-name=
custom-lib-path=
cluster-mode=2
net-scale-factor = 0.0001
[class-attrs-all]
pre-cluster-threshold=0.25
I am referring to sample code deepstream-app-test3 for example.
How can I achieve that?
